Minne til Abit KG-7
arkela
Har et Abit KG7 hovedkort med 256 MB ram. Skal kjøpe 256 til, men er usikker på hva jeg kan bruke.
Brukte AIDA32 og fann ut dette:
Memory Module Properties
Module Name Apacer Tech.
Serial Number None
Module Size 256 MB (2 rows, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC2100 (133 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Normal (15.625 us), Self-Refresh
Highest CAS Latency 2.5 (7.0 ns @ 142 MHz)
2nd Highest CAS Latency 2.0 (7.5 ns @ 133 MHz)
Memory Module Features
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Memory Module Manufacturer
Company Name Apacer Technology Inc.
Product Information http://www.apacer.com/apacer_english/produ...eric_memory.asp
Må jeg ha Apacer minne? Eller? Er dette SD Ram eller DDR SD? Finner det ikke på komplett...
