Lang USB-kabel (ca. 12 m)
Vi har nokon dansematter (positivegaming.com) som vert kopla til PC med eit adapter for USB. Med bruk mot storskjerm skulle eg gjerne ha forlenga kabelen og ideelt skulle denne vert ca. 12 m lang. Finnes det USB-forlengarar som ikkje koster skjorta som kanskje kunne fungert?
2 x 12 meter eller kanskje ein hub?
PS! Det er straum der som mattene skal koplast til, så aktivt utstyr er heilt OK!
Det du må passe på når det gjelder USB-kabler er at de kan ikke være lengre enn fem meter uten aktiv forsterkning av signalene.
Det vil si at for hver femte meter må du enten ha en hub med egen(!) strømforsyning, eller en form for aktiv signalforsterker. I praksis er det som oftest like billig (eller billigere) og kjøpe hub, særlig hvis du allerede har kablene.
2.   I want to build a cable longer than 5 meters, why won't this work?
A:   Even if you violated the spec, it literally wouldn't get you very far. Assuming worst-case delay times, a full speed device at the bottom of 5 hubs and cables has a timeout margin of 280ps. Reducing this margin to 0ps would only give you an extra 5cm, which is hardly worth the trouble.
3.   What about using USB signal repeaters to make a cable longer than 5 meters?
A:   Don't bother. The best solution is self-powered hub with a fixed 10m cable that had a one-port bus powered hub in the middle. The maximum range will still have to deal with the timeout, so any out of spec tweaking of the terminations between the two hubs and the timing budget still won't yield more than 5cm of extra distance. A better solution is described in the following question.
4.  I really need to put a USB device more than 30 meters away from my PC. What should I do?
A:  Build a USB bridge that acts as a USB device on one side and has a USB host controller at the other end. Use a long-haul signaling protocol like Ethernet or RS-485 in the middle. Using cables or short-haul fiber, you can get ranges upwards of a kilometer, though there's no reason why the long-haul link in the middle of the bridge couldn't be a pair of radio transceivers or satellite modems.
Embedded host solutions capable of doing this already exist. Also, two PCs connected via USB Ethernet adapters are essentially a slave/slave version of this master/slave bridge.
Kjelde: http://www.usb.org/developers/usbfaq/#cab1
Endret av zeph
Takker for utfyllande svar!
Ein må altså ikkje gå over 5 meter, evt. 5,05 meter med modifikasjon. Skal eg nå 12 meter, må eg altså ha tre USB-hub'ar som går på straum.
Er det sånn at det er like strengt på USB 1.1-utstyr som Playstation -> USB-adapter, tastatur og mus?
Eg kan kanskje surra små usb-HUBar med straumkabel i ei pølse... hmm...
