Hvilke HK type er det minste?
Av de med standariserte størrelser så vet jeg om følgende:
Facteur de forme  Dimensions  Emplacements
ATX  305 mm x 244 mm  AGP / 6 PCI
microATX  244 mm x 244 mm  AGP / 3 PCI
FlexATX  229 mm x 191 mm  AGP / 2 PCI
Mini ATX  284 mm x 208 mm  AGP / 4 PCI
Mini ITX  170 mm x 170 mm  1 PCI
Nano ITX  120 mm x 120 mm  1 MiniPCI
BTX  325 mm x 267 mm  7
microBTX  264 mm x 267 mm  4
picoBTX  203 mm x 267 mm  1
...AT: 12" x 13" [Obsolete, replaced by the Baby-AT, and ATX form factors]
...Baby AT: 11.2" wide x 8.2" deep
...microATX: 9.6" wide x 9.6" deep (244mm x 200mm).
...Mini-ATX: 11.2" wide x 8.2" deep.
...Flex ATX:9.0" wide x 7.5" deep (229mm x 190.5mm). Differs from microATX; new socketed processor, smaller, ATX 2.03 I/O panel
...NLX: From (9.0" wide x 13.6" deep) to (8.0" wide x 10.0" deep) and any size in between.
...LPX: 250mm x 220mm
...WTX: (workstations)
...ATX: 12" wide x 9.6" deep (305mm x 244mm).
...Extended ATX: 12" x 13.05" (W x H)
...BTX: (Balanced Technology Extended) 325.12mm wide x 266.70mm deep
........microBTX: (Balanced Technology Extended) 264.16mm wide x 266.70mm deep
........picoBTX: (Balanced Technology Extended) 203.20mm wide x 266.70mm deep
...ITX: 220mm x 170mm
........mini-ITX: 170mm x 170mm
........nano-ITX: TBD
Embedded Mother Board Formats:
........EBX; 8.00" x 5.75"
........ETX; (Embedded Technology eXtended) 95mm x 111.6mm (5.75 x 8 inches)
........ETXexpress; (Embedded Technology eXtended) 90mm x 125mm, based on the PCIexpress bus
........EPIC; System On Module - ETX) 4.528" x 6.496" (115mm x 165mm). Contains a PC/104 stack area
........SOM-ETX; System On Module - ETX) 4.50" x 3.70" (114mm x 95mm)
........5.25" Mini Module; 8.0" x 5.75" (203mm x 146mm)
kilde kilde2 kilde3 kilde4
Ellers så har jeg sett spesialdesignede "hovedkort" i størrelser under 10x10cm. Helt ned i ca 5x5cm om jeg husker riktig. Men disse er normalt med alt mulig innebygget, som ram, CPU, brikkesett, flashminne, osv og stappet full av små konnektorer over hele kortet. Jeg finner desverre ikke bilder av slike akkurat nå.
Edit: F.eks disse: embedded-systems-fig2.jpgpcm-3345_pcd-100_pcm-3640.jpg503.sm.jpg
Endret av Simen1
