Samsung SyncMaster 193P+
andekar
Någon som vet när denna kommer att börja säljas??
En 8ms PVA skärm... Nu börjar det hända en del... :-)
Spec:
Panel Type a-si TFT/PVA
Viewable Size 19"
Pixel Pitch 0.294mm
Brightness (Typical) 250 cd/m2
Contrast Ratio 1000:1
Viewing Angle (Horizontal/Vertical) 178°/178°
Aspect Ratio 5:4
Interface Analog/Digital
Response Time 8ms (G to G)
Native Resolution 1280 x 1024
Maximum Color 16.7M
Input Video Signal Analog RGB, DVI Digital Link
Sync Type Separate H/V, Composite H/V, SOG
Input Connectors 15-Pin D-Sub, S-Video, RCA Connector, TV (Antenna/Cable)
Max Power Consumption 40 Watts
VESA® Wall Mount 75mm
Emission Standard TCO ’99
