Prøver å instalere på en via epia
Fant dette, skevet av Judd:
On Wed, Dec 01, 2004 at 11:21:33AM -0800, Judd Vinet wrote:
> The Nehemiah core is a second-generation C3 chip, which IIRC, has the
> required CMOV instruction that the earlier chips lacked.
To clarify, here's an excerpt from a FAQ[1].
[snip]
12.2. Is the C3 Pentium compatible?
Yes. But Samuel 2, Ezra, Ezra T C3 processors have a problem with the
cmpxchg8b (i.e. CMOV) opcode. Nehemiah and Antaur processors are not
affected.
    The identification issue is that the C3 is identifying itself as
686. According to the Intel IA32 documentation, this is correct: C3 does
not implement conditional moves*, and do not pretend to implement
conditional moves. The Intel documentation states that you should check
before doing conditional moves, and that cmov implementation in the
processor is optional. The GNU compiler people have assumed that all
686's implement cmov's, so code compiled for the i686 architecture may
not execute on the C3. Code generated by GCC does not check for these
optional features as the intel documentation says you should. When
downloading binaries for the C3, don't go higher than the i586 level.
When building, you may want to target the 586 or even the 486, because
of the way the C3 is built internally: It's not an athlon, more like a
486-586 cross.
[/snip]
Så det betyr vel at den er 686, men ikke virker alikevel :) Tester med en ny kjærne nå!!
Har tenkt å benchmarke. Min via er bare på 500mhz og så har jeg en bærbar celeron på 450, så kan jeg sammenligne litt. Noen tips til benchmark i tillegg til mprime. Btw kabbis, hk, minne, psu, hd drøyt 2000 ikke så ille for et leketøy. Og helt vifteløst :)
Du må definitivt prøve linuxbios på den der, jeg har selv lyst til å kjøpe noe lignende selv (hvis jeg hadde hatt råd..). Hvilken nettbutikk brukte du?
Har lurt på hvor det ble av gedoe, var spent på den. Trodde den skulle selges løst og passe på socetA. Egentlig hadde jeg nesten glemt den. Syntes de kortene var dyre. Har nå kjørt mprime, overaskende dårlig av via faktisk. Celeronen var nesten 3x raskere :( Men den funker fint til mit bruk. Har ikke instalert X, så får ikke noe slikt intrykk av den. Kan prøve noen tester ala dette hvis noen gir meg litt hint på komandoene:
time dd if=/dev/random of=storfil # men hvordan lage en på f.eks 2gb.
time tar --bzip2 -cf storfil.tar.bz2 storfil
Den bærbare er denne:
Lifebook b2154
men med 196 mb ram og ny 40 gb harddisk.
Via'en er denne:
VIA EPIA ML5000EA, m/Via Eden CPU 533MHz
Crucial PC2100 DDR-DIMM 256MB CL2.5
og ny 40 gb 2.5" hd
Så de skulle være veldig sammenlignbare.
Leste litt på linuxbios, men ble ikke helt fristet, hva skulle det være godt for? Virker som noe som kan være greit for clustere eller kanskje terminaler. Kjøpte som vanlig alt hos komplett (handleliste), men så fant jeg et demobrukt kabinett til 400 inklusive stømforsyning, så strømforsyningen går i retur. Hadde egentlig tenkt å putte alt i et gammel radio-kabinett eller lignende.
Tanken av å ha en fri biosimplementasjon burde vel i seg selv være fristende, men rask oppstartstid hadde heller ikke gjort no.
The primary motivation behind the project was the desire to have the operating system gain control of a cluster node from power on. Other beneficial consequences of using LinuxBIOS include needing only two working motors to boot (cpu fan and power supply), fast boot times (current fastest is 3 seconds), and freedom from proprietary (buggy) BIOS code, to name a few.
Fra http://www.bglug.ca/articles/linux_boot_process.html:
The BIOS provides a number of routines and services that are mostly useless to the Linux kernel. A large part of the BIOS exists to support legacy systems like DOS. There is an obvious advantage here to eliminating this excess code and the LinuxBIOS project shows just how much advantage there is.
LinuxBIOS [http://www.linuxbios.org/] is an effort to provide the bare minimum to initialize the motherboard and allow a Linux kernel to boot. On some boards, stripping out these excess functions has made room for the Linux kernel, allowing it to be run directly from EEPROM. One humourous bug that had to be worked around is that some hard drives are unable to initialize themselves fast enough for the kernel.
Men når det er sagt trodde jeg du hadde en vanlig epia, epia ml tror jeg ikke er støttet..
