Robin B Skrevet 16. mai 2005 Del Skrevet 16. mai 2005 (endret) Ser ut til at det kommer adapter. Albatron Technology, a leading IT solutions provider, recently announced the world's first AGP-8x to PCI-Express bridge card. The "ATOP"(AGP-To-PCIe) bridge card will allow a user to use their existing AGP-8x VGA card in a mainboard designed for PCI-Express resulting in considerable savings in upgrade expenditures.Because the AGP 8x standard has been around for a while and continues to provide more than adequate graphics performance, there still exists a large base of users with very capable AGP 8x VGA cards. Until now consumers have been hesitant to upgrade to a mainboard with the PCI-Express standard because it would also mean having to purchase a new PCIe VGA card. With the ATOP card you can now upgrade to a PCI-Express mainboard, continue to use your existing AGP-8x card and worry about purchasing a new PCI-Express VGA card at a later time. Your AGP-8x card simply piggybacks on the ATOP card's AGP-8x slot located on the top edge. The ATOP card is then plugged into the mainboard's PCI-Express slot. The only other installation requirements are replacing the bracket on the AGP-8x card with an ATOP bracket and installing the appropriate driver. The ATOP bridge is the perfect solution for cost conscious users caught in the middle of the PCI-Express, AGP-8x transition. With the ATOP, you can have the best of both worlds in addition to reducing expenditures and extending the life of your original investments. http://www.albatron.com.tw/english/news/ne...asp?news_id=167 Endret 16. mai 2005 av Robin B Lenke til kommentar
ChainDoG Skrevet 16. mai 2005 Del Skrevet 16. mai 2005 det der så litt jalla ut.. :!: Lenke til kommentar
Baleni Skrevet 16. mai 2005 Del Skrevet 16. mai 2005 (endret) hmm..enig med ChainDoG men hadde det kommet og funka hadde det jo vært genialt fordi som ikke kan oppgradere alt på en gang sånn som meg Endret 16. mai 2005 av Baleni Lenke til kommentar
Robin B Skrevet 16. mai 2005 Forfatter Del Skrevet 16. mai 2005 Blir ytelsen på høyde med et Agp hovedkort og adapteren ikke koster skjorta så er det en grei løsning for dem som ikke ønsker å kvitte seg med Agp kortet. Så hvordan den ser ut er helt underordnet. Lenke til kommentar
AndersT2 Skrevet 16. mai 2005 Del Skrevet 16. mai 2005 (endret) Ser mildt sakt jalla ut spør du meg. hvordan vil det funke med ett x850xt pe kort tro? Endret 16. mai 2005 av AndersT2 Lenke til kommentar
