Hvilken bios til executer 2 chip?
annbefaler X2 5028 GOLD biosen , (som du finner på bittorrent sider)
denne er ganske ny, (April 19th 2005)
We figured we should give the scene a boost with the release of a
decent bios that works on ALL chips (that support a 512k bios at least).
So you see, Xecuter even has some love for Xenium & Smartxx users :p
ALthough this release has gone "Gold" it is still a work in progress
and we have a lot of cool new stuff in the works. There will be a new
PC tool for the new X2CL series - basically being able to patch the
LBA48 function of the bios and also a nice PC & XBE GUI interface to
auto create your ini files / change settings on the fly.
Enjoy yet another fine Xecuter Bios Release
M8 biosen er eldre og er ikke like bra.
DATE: 08/11-2004 º
º º
º EvolutionX Proudly presents Evox M8+ BIOS. º
º º
º Now works on XBOX 1.6B also º
º º
º M8+.BIN Is a new BIOS based on the latest 5838 kernel, and has º
º the same features as M7, º
º It will work on XBOX versions (1.0, 1.1, 1.2, 1.3, 1.4, 1.5) º
º º
º M8+_16.BIN Is also based on the 5838 kernel and has the same º
º features as M7. º
º It will ONLY work on XBOX version 1.6 and 1.6B º
Endret av mago
