3000+ treffer veggen tidlig...
Prøvde dette;
  • FSB : 240
    Memory: 166/200 @ auto timings
    HTT multi : x4
Burde føre til;
CPU: 240 MHz x 9 = 2160 MHz
Memory: 240 x (166/200) = 200 -> 400 DDR speed (stock speed)
HTT : 240 x 4 = 960
Både RAM og HTT er på tilnærmet standardverdier. Er vell CPUen det står på da...?
Burde vel klare dette med en 3000+W (90nm)
Opp med volten?
Kjørte FSB - 220 uten prob. med samme innstillingene...
Takker! :woot:
Nyttig info:
Cool and Quiet enabled
CPU VID - Startup
SATA 1 og2 ikke i bruk
DOT av
Agg. timings av
AGP freq. : 67 (AGP låst -?)
hehe... liker at den er stille.... volten skal vel være 1.4... får se...
Før jeg får "det er PSUen din"-svar:
Review av kabbiset m/PSU
Power Supply and Cooling Results:
Normally, I don't believe in the cooling performance of a case.  All cases will perform well if there are intake and exhaust fans for proper airflow.  Since the Silentium was designed with cooling performance in mind, I decided to compare it to a standard ATX case.  A thermal probe was placed next to the CPU to measure CPU temps, and a probe is left hanging inside the middle of the case for case temperatures.  Room ambient temperature was kept consistent at 23°C.  Arctic Silver Ceramique was used for the CPU.  Testing was done without high end equipment simply because I do not have them.  It is just considered a rough estimate of the cooling performance you would get as you would test it yourself at home.  There is no scientific testing here.
Test System:
    * AMD Athlon64 3000+ Newcastle
    * Abit NF8
    * 2 x 512MB Centon Low Latency PC3200
    * ATI Radeon X800 Pro
    * NEC DVD-RW
    * Sony DVD-Rom
    * Sony Floppy
    * 1 x 36GB Western Digital Raptor
    * Arctic Cooling Silencer 64 Ultra TCL
Test Procedures for System Cooling:
    * Idling at desktop for 30 minutes
    * Full load with CPU Burn-in and 3DMark2001SE for 60 minutes
Test Procedures for Voltage Readings:
    * Full load with CPU Burn-in, 3DMark2001SE Nature test, and Prime95 torture test for maximum power
Running Stock:
    * AMD Athlon64 3000+ -- 2.0GHZ @ 1.5v
    * Centon Low Latency PC3200 -- 200HTT 1:1 200MHZ @ 2.5v
    * ATI Radeon X800 Pro -- 475/450
    * VAGP 1.5v
Running Overclocked:
    * AMD Athlon64 3000+ -- 2.5GHZ @ 1.7v
    * Centon Low Latency PC3200 -- 250HTT 1:1 250MHZ @ 2.8v
    * ATI Radeon X800 Pro -- 500/500
    * VAGP 1.6v
Kan ikke si at CPU'en din var særlig villig.
Oppsettet hos meg er som følger:
FSB: 280MHz * 9 = 2520MHz
RAM: 133. Auto timing
HTT: 2x
Spread Spectrum: Off
C'n'Q: Off
CPU V: 1.5V + Over VID 3.3%
Og dette kjører den uten problemer med boxed-kjøler
