Hvordan lage exstra batteri til Nintendo DS
What you’ll need for this is:
+A DS or SP charger with their nutty proprietary plug on the end.
+A Radio Shack battery enclosure for 4 AA batteries (or AAA if you want it even more compact, but don’t mind it being weak)
+Electrical Tape
+Wire Strippers
+Swiss Army Knife/Utility Knife or Toolkit
+Soldering Iron + Solder - Optional (gasp!)
+Batteries
So all the above should be readily available. Lay it all out on a table in front of you and let’s get started.
Step 1. Grab that DS charger
Grab your Nintendo DS AC adaptor and pick a good spot to hack the end off. It’s a pretty long cord so I just chose to do it in the middle. Use your knife for a clean cut right down the middle.
Step 2. Get your battery case ready
Get your neat little case and hack off the ground wire, we won’t need it. Then unscrew the cover and keep it off until you put your batteries in.
Step 3. Stripping away and connecting
Strip away the wire a little bit, you’ll see a green wire inside. Strip that very carefully and reveal it’s golden insides. Then, take your red connector on your battery case. You can either solder it for a secure permanent connection, or just bundle the wires together tightly, cap them, and use a little tape to clean up.
Step 4. Finishing up and powering it up
Wrapping up, you can either tape the short wires from the battery case to the side or you can go further like we did and drill a little hole for them to go into. The finished product should look like this. Small enough to fit in your pocket and good for a little extra juice (not 9 hours of gaming mind you). You can even customize it if you want and it works by connecting it to your DS or SP, and hitting the “On/Off” switch on the battery case. Sweet, simple, and snazzy.
Dette er uten garanti fra meg :p
Takk til
Gutta bak Furiousdogs.com
Anngående batteri og DS foresten. Kjøpte meg DS her i statene for et par dager siden, og lurte bare på en ting, laderen er ikke slik som på PSP hvor du kun kan dra ut den amerikanske kontakten, og sette inn en vanlig 220 volts norsk kontakt inn i adapteren. Det er bare en amerikansk ledning fra støpselet til maskinen. Og står ikke at den tar 220 volt, kun 110. Hadde egentlig bare tenkt til å kjøre en støpseladatpter. Men vil det funke? :ermm:
Mange adaptere støtter faktisk 220 og 110V spenning, bortsett fra at selve kontakten ser annerledes ut. I slike tilfeller er det nok med en konverter som kun endrer på formen til kontakten. Dette er altså ikke tilfellet med deg, og jeg vil fraråde deg å prøve... Istedenfor så kan du helle betale 250kr for en lader til GameBoy SP, og være sikker på at ingenting smeller.
