hvorfor funker ikke skjermoppløsningen?
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following commands:
# cp /etc/X11/xorg.conf /etc/X11/xorg.conf.custom
# sudo sh -c 'md5sum /etc/X11/xorg.conf >/var/lib/xfree86/xorg.conf.md5sum'
# sudo dpkg-reconfigure xserver-xorg
Section "Files"
FontPath "unix/:7100" # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
# paths to defoma fonts
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID"
EndSection
Section "Module"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "no"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "Emulate3Buttons" "true"
Option "ZAxisMapping" "4 5"
EndSection
Section "Device"
Identifier "NVIDIA Corporation NV34 [GeForce FX 5200]"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "Q770"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "NVIDIA Corporation NV34 [GeForce FX 5200]"
Monitor "Q770"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1024x768" "800x600" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Legg merke til at du kjører default depth på 24
DefaultDepth 24
Dermed gjelder:
Depth 24
EndSubSection
Da endrer du Modes linja til å passe med den/de oppløsningen(e) som du vil ha:
F.eks:
Modes "1600x1400" "1280x1024" "1024x768" "800x600" "640x480"
for å redigere filen må du logge deg inn som root i terminal:
(su root)
Så skrive:
nano -w /etc/X11/xorg.conf
da trykker du på pil ned, for å finne der hvor det står:
Depth 24
EndSubSection
og legger til
etter "Modes"
Så, når du er ferdig å skrive, trykker du på 'CTRL+X' og så 'y'
Ok?
PS: Kanskje litt hissig å skrive 1600 oppløsning, hvis ikke skjermen tåler det. Skriv heller bare "1280x1024". (Antar at du har vanlig CRT skjerm som støtter den oppløsningen. Hva hadde du i Windows?)
Endret av krigun
Ok, poenget er, at du må legge til noe i /etc/X11/xorg.conf filen.
Den filen har ikke du som vanlig bruker skriverettigheter på, så derfor må man gjøre sånt i terminal.
(Jeg vet ikke, men kanskje ubuntu har noe GUI verktøy for formålet?)
uansett, så må du logge deg inn som root. Skjønner? (su root)
Og da kan vi redigere filen med et program som heter nano.
prøv å skriv nano i terminal, da ser du at det er et enkelt tekst-behandlings program.
Du avslutter nano med CTRL+X og y for å lagre endringer, n for ikke å lagre. Dette står på skjermen.
Bare følg instruksjonene ovenfor, se om du får det til.
Ubuntu har ikkje aktivert root-kontoen. Rediger fila på denne måten (skriv i ein terminal):
sudo gedit /etc/X11/xorg.conf
No har du alt grafisk.
Så går du ned til
Depth 24
EndSubSection
Og endrar til f.eks:
Depth 24
Modes "1280x1024" "1024x768" "800x600" "640x480"
EndSubSection
Om du vil ha 1280x1024 som oppløsning.
