Hva betyr bursdagen din? Og andre quiz-er.
svamp
Jeg fant en side med en del tester på, så nå tenkte jeg at jeg skulle ta en skikkelig oivind_dahle. :D
Her er noen av testene:
What does your birthday mean? (Hva betyr fødselsdatoen din?)
What gender is your brain? (Hvilket kjønn er hjernen din?)
How's your taste in music? (Hvilken musikksmak har du?)
Til slutt en som kan være til hjelp for ofre av den nye epidemien i OT-baren:
What rejected crayon are you?
Your Taste in Music:
Progressive Rock: High Influence
90's Alternative: Medium Influence
Classic Rock: Low Influence
With a birthday on the 5th of the month you are inclined to work well with people and enjoy them.
You are talented and versatile, very good at presenting ideas.
You may have a tendency to get itchy feet at times and need change and travel.
You tend to be very progressive, imaginative and adaptable.
Your mind is quick, clever and analytical.
A restlessness in your nature may make you a bit impatient and easily bored with routine.
You may have a tendency to shirk responsibility
Og rosa tegnestift.
Endret av Jan-Erik
Heavy Metal: Highest Influence
80's Rock: Low Influence
Adult Alternative: Low Influence
Alternative Rock: Low Influence
Hair Bands: Low Influence
What Gender Is Your Brain?
Your Brain is 33.33% Female, 66.67% Male
You have a total boy brain
Logical and detailed, you tend to look at the facts
And while your emotions do sway you sometimes...
You never like to get feelings too involved
Endret av Røvenskiold
80's Alternative: Low Influence
90's Alternative: Low Influence
...Men var litt få alternativ på den listen, syns jeg.
Musikk: (stemmer bra)
90's Alternative: Highest Influence
90's Rock: Medium Influence
Alternative Rock: Medium Influence
Classic Rock: Medium Influence
Punk: Medium Influence
Bursdag: (noe korrekt, noe bullshit)
Your birth on the 27th day of the month (9 energy) adds a tone of selflessness and humanitarianism to your life path.
Certainly, you are one who can work very well with people, but at the same time you need a good bit of time to be by yourself to rest and meditate.
There is a very humanistic and philanthropic approach in most of things that you do.
This birthday helps you be broadminded, tolerant, generous and very cooperative.
You are the type of person who uses persuasion rather than force to achieve your ends.
You tend to be very sensitive to others' needs and feelings, and you able to give much in the way of friendship without expecting a lot in return.
Kjønn:
Your Brain is 46.67% Female, 53.33% Male
80's Rock: Medium Influence
Adult Alternative: Medium Influence
80's R&B: Low Influence
90's Rock: Low Influence
Old School Hip Hop: Low Influence
Progressive Rock: Low Influence
Classic Rock: High Influence
80's Pop: Medium Influence
Progressive Rock: Medium Influence
Heavy Metal: Low Influence
Hmm. Merkelig. Tror den testen er 'litt' dårlig. Bommer ganske grovt.
Your Birthdate: May 20
Your birth on the 20th day of the month adds a degree of emotion, sensitivity, and intuition to your reading.
The 2 energy provided here is very social, allowing you to make friends easily and quickly.
Yet you are apt to have a rather nervous air in the company of a large group.
You have a warmhearted nature and emotional understanding that constantly seeks affection.
You are very prone to become depressed and moody, as emotions can turn inward and cause anxiety and mental turmoil.
It can be hard for you to bounce back to reality when depression sets in.
When things are going well, you can go just as far the other way and become extremely affectionate.
Your Brain is 40.00% Female, 60.00% Male
(Jeg krysset kun av for Slayer.)
Your birthday suggests that are executive ability and leadership qualities in your makeup.
A birthday on day 1 of any month gives a measure of will power and self-confidence, and very often a rather original approach.
This 1 energy may diminish your ability and desire to handle details, preferring instead to paint with a broad brush.
You may be sensitive, but your feelings stay rather repressed.
80's Rock: High Influence
90's Pop: Low Influence
Your Brain is 26.67% Female, 73.33% Male
Dance: Low Influence
Ska: Low Influence
Your Birthdate: June 24
Born on the 24th, you have a greater capacity for responsibility and helping others than your may have realized.
You may also become the mediator and peacemaker in inharmonious situations.
Devoted to family, you tend to manage and protect.
This birth date adds to the emotional nature and perhaps to the sensitivities.
Affections are important to you; both the giving and the receiving.
Endret av Rune_F
Your Birthdate: March 5
Grå farge
