Hvordan lyssabler fungerer (Star wars)
Ni kon
Hei hei.
Meg igjen. Denne gangen med en totalt unyttig post igjen. Her har dere siden som viser hvordan en lyssabel virker. Absolutt et must for dere Star Wars fans som lager lyder og fekter rundt med armene. Og i stede for å kjøpe disse på leketøysbutikker kan du nå eie de selv!!
The big advantage of using a lightsaber, of course, is that you can both cut and toast the bagel in one stroke.
NB!!
Important Safety Information
A lightsaber is not a toy! Keep it out of reach of children at all times. Lightsaber locks are required in most states.
There are two ends to any lightsaber -- one end has the belt ring, while the other end houses the blade arc tip and blade emitter. NEVER point the blade emitter of a lightsaber toward your own body. NEVER look down the "barrel" of a lightsaber, even if you are "sure" it is in safe mode. If you accidentally activate the lightsaber, serious injury could result.
