HK med S-ATA2 og DDR2
Skal kjøpe meg et nytt HK som stiller to krav! Det skal ha støtte for S-ATA2 og ta DDR2 minne. Vil helst ha et nytt og godt skjermkort! Pris er ikke noe problem.
Noen tips?
EDIT: Ser også på muligheten for vanlig DRR SDRAM, men er litt usikker på hvilken type RAM som er best idag?
Endret av Glisevask
CPU:
LGA775 socket for Intel® Pentium 4/Celeron CPU
Compatible with Intel® 6XX, 5XX and 3XX processors
Intel ®Hyper-Threading Technology ready
Supports Intel® Enhanced Memory 64 Technology(EM64T)
Supports Enhanced Intel SteepStep® Technology(EIST)
Intel new next generation CPUs enabling ( subject to Intel CPU availability and NVIDIA chipset supportability )
Chipset:
nVIDIA nForce4 SLI - Intel Edition ( Crush 19 )
nVIDIA MCP-04
Front Side Bus 1066 / 800MHz
Memory:
Dual channel memory architecture
4 x 240-pin DIMM sockets support
max. *8GB / 4GB DDR2 667/533/400 non-ECC memory ( 8GB DDR2 support for 64 bit OS platform only )
Native DDR2 720 support
Expansion Slots:
2 x PCI Express x16 slot
- SLI mode : x8 , x8
- Normal (Single VGA) mode : x16, x1
2 x PCI Express x1
3 x PCI
Storage/RAID:
nForce4 Storage:
- 4 x SATAII
- 2 x UltraDMA 133/100/66/33
- NVRAID : RAID0, RAID1, RAID 0+1, Software RAID 5 and JBOD span cross SATA and PATA
Silicon Image 3132R RAID controllers :
- 2 x SATAII
- RAID 0, 1 and exteral SATA connectability
LAN:
nForce4 built-in Gbit MAC with external Marvell PHY :
- NV ActiveArmor
- NV Firewall
- AI NET2
Intel PCI Gbit LAN controller
IEEE 1394 TI 1394 controller supports 2 x 1394 ports
USB Max. 10 USB2.0 ports
Back Panel I/O Ports:
1 x Parallel
1 x Optical + 1 x Coaxial S/PDIF Output
1 x PS/2 Keyboard
1 x PS/2 Mouse
2 x RJ45
4 x USB 2.0/1.1
1 x External SATA
1 x IEEE1394
8-Channel Audio I/O
Internal I/O Connectors:
1 x SLI selector card connector
3 x USB 2.0 connector supports additional 6 USB 2.0 ports
1 x IEEE1394 connector
1 x COM connector
1 x GAME/MIDI connector
CPU Fan / 2x Chassis Fan/ Power Fan/ Chipset Fan connectors
Front panel audio connector
Chassis Intrusion connector
CD audio-in connector
24-pin ATX Power connector
4-pin ATX 12V Power connector
4-pin EZ Plug power connector
Form Factor ATX Form Factor, 12"x 9.6"(30.5cm x 24.5cm)
Det er jo ett bra hovedkort, du får tak i det på pcutstyr.no
- 1024 Megabytes of memory in a 240-pin DDR2 DIMM
- Implemented using 32M x 8 DDR2 SDRAMs
- 100% tested at 538MHz in high performance DDR2 motherboards
- High-efficiency aluminium XMS2 heatsink
- 24 activity LED's showing memory activity on each bank
- Legendary Corsair reliability and service
- Lifetime warranty
Kanskje ikke så veldig bra latency, men det er greit nok til å være ddr2. Ellers må du opp i en mye høyere sum.
