OPPDATERE FIRMWARE SX1
JEG SKAL OPPDATERE FIRMWAREN PÅ MIN SX1. JEG SKJØNNER IKKE HVORFOR JEG IKKE FÅR TIL DETTE. "HVIS JEG SKAL SJEKKE HVILKEN FIRMWARE VERSJON JEG HAR, PRESSER JEG #06# OG SÅ TRYKKE PÅ INFO" STÅR DET I VEILEDNINGEN, MEN HVILKEN KNAPP ER DET?
- You need to check which firmware variant is used on your SX1.
- You can find out the software variant of your phone, if you press *#06# in the idle screen and then select INFO.
SVN: xx is the software release number in the phone.
If you scroll a little bit down with the joystick, you will find "Rolf Variant Name:"
This is the name of the software variant and only the same version can be updated into your phone.
Gjest
