Pokemon Leaf: Kos fange eg Deoxys?
wilai
eg har begynt å spele litt pokemon igjen
for eg fikk dei nye pokemon spele av min farmor
(til farmoren min:eg er ikkje liten alså)
og eg vil fange Deoxys men eg komme ikkje lenger på den gåten
på den bilder der?
eg har google mange time nå men alle dei How To guide funke joo ikkje
GameFAQs.com er fint å ha ;)
Fant dette her. Tror det skal stemme bra:
When you get to the island, you will first notice that there is no music. Your
GBA [sP] isn't broken, so don't dismantle it or anything to try and fix it.
You'll also see a triangle-shaped plot of land and a black triangle in dead
center. Your job is to manipulate the movements of this triangle so it ends up
one square above center, but red instead of black. As long as you don't turn
unnecessarily (you have to start over if you turn even once out of line), you
can simply walk to the triangle as it moves. When you touch the triangle, press
A to move it to another location.
Start at the bottom of the triangle.
One step down and all the way left.
Three steps right and all the way up.
Five steps down and all the way right.
Three steps up and all the way left.
All the way right.
Two steps left and all the way down.
All the way right.
Three steps left and face down.
This will make the triangle red and one square above center. Now you can save.
If you step on the dock, you'll have to start over. Examine the triangle one
more time. The ground will shake and the triangle explodes. Deoxys will attack.
Deoxys is Lv.30 when you attack it. Here's its moveset:
FireRed
Taunt - Foe can only use moves that cause direct damage for two turns.
Psychic - 10% chance of lowering the foe's Special Defense by 1 level.
Superpower - Lowers user's Attack and Defense by 1 level.
Pursuit - Doubles in base power if used on a foe that's switching out.
LeafGreen
Spikes - Each new foe's entry takes 3-4% HP in damage. Can be used three times.
Snatch - Steal the foe's recovery or stat-boosting attack.
Knock Off - Foe drops held item. This item is returned after the battle.
You'll notice that no matter which version you have, Deoxys has its Ruby &
Sapphire battle sprite when you encounter it. This isn't a glitch. It was
intentional, and it will change to the appropriate sprite upon capture. In
fact, Deoxys already has the stats of your respective version, so battle it
with that in mind.
Assuming your levels are around 40, FireRed's Deoxys can rip you apart in
seconds with Psychic. Don't forget: there's _monster_ Special Attack backing it
up. It puts Dark-types to shame with Superpower, one of the most powerful
Fighting-type attacks. If your Pokemon are below Lv.50, it's suggested to get
out and train until you pass that mark or get very close to it so you'll have
less trouble. Otherwise, you can get a high-level Xatu. Catch Natu, its pre-
evolution, in Ruin Valley. Inflict your condition and throw, throw, throw. Not
much else to say.
When compared to FireRed's Deoxys, the one in LeafGreen seems wimpy. Its only
threat is Psychic, and doesn't have the raw power that the FireRed one has to
inflict massive damage. However, Deoxys is still a legendary Pokemon, and
Psychic is still capable of hurting. Pursuit, oh no. No STAB means weak damage.
At any rate, you can easily beat its HP into the red and toss until it's yours.
That's all for Birth Island.
http://db.gamefaqs.com/portable/gbadvance/...emon_frlg_e.txt
Fikk lyst til og spille pokemon selv nå :blush:
Når nerdene endelig får fingeren ut og lager en GBA emu til PSP så blir det nok masse pokemon spilling på meg ja :yes: (gidder jo ikke og drasse med meg GBA :p )
da Passe VisualBoyAdvance deg
har prøvd det og er veldig enkel
Fungerer nok ikke på PSP det du ;)
Men det ser meget lyst ut nå utifra dette :cool:
  • 2 uker senere...
