ECS K7S5A2 SiS735-hovedkort
Novec
PC Hardware har tatt en titt på ECS sitt siste skudd på stammen, det SiS735-baserte K7S5A2. Kan være verdt å se på:
I was pleased to see that ECS included several memory timings templates. In the Advanced Chipset Features you can find two main settings: Advanced Dram Control 1 and Advanced Dram Control 2. Under these menus you can access several memory settings which are not documented, so I was just able to suppose what these settings really are. The four templates mentioned earlier are called Safe, Normal, Fast and Ultra. We will see in benchmarks if these affect performance.
Hvis noen lurte på det, gjelder dette både DDR og SDR SDRAM. Testen ligger her:
http://www.pchardware.ro/Reviews/review.php?id=129
