World of Warcraft på Wine. Hjelp
Hei.
Har orginalt skrevet dette på et Engelsk linux forum, men fikk ikke posta der.
Har ikke tid til å oversette til norsk:
Hi.
Finally im using linux again.
But i want to play WoW.
Well, so i tried.
I installed it without any problems.
I had some problems running it, but it went ok.
Well, there i was, at the login screen.
It was bugged, but i found the buttons and made my way to the log-in screen. I typed in my username and password, without seeing what i was writing, cause the graphics was bugged.
Well, i came through that too. And then it was the update`s turn. I waited about 45mins, and it finished.
Then, the problem appared. I had to install the update.
And that didnt work.
LOG:
kristian@ABIT:~/.wine/fake_windows/Program Files/World of Warcraft$ wine Wow.exe -opengl
Invoking /usr/lib/wine/wine.bin Wow.exe -opengl ...
Please use the registry key HKEY_CURRENT_CONFIG\Software\Fonts\LogPixels
to set the screen resolution and remove the "Resolution" entry in the config file
fixme:opengl:query_function_pbuffer gl_version is: "1.3.4769 (X4.3.0-8.8.25)"
fixme:opengl:query_function_pbuffer glx_exts is: "GLX_EXT_visual_info GLX_EXT_visual_rating GLX_EXT_import_context GLX_ARB_get_proc_address GLX_ARB_multisample "
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798f5e8,0x00000000), stub!
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798f6c4,0x00000000), stub!
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798fa80,0x00000000), stub!
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798fa20,0x00000000), stub!
fixme:system:SystemParametersInfoW Unimplemented action: 113 (SPI_SETMOUSESPEED)
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798fa0c,0x00000000), stub!
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798f1f0,0x00000000), stub!
fixme:system:SystemParametersInfoW Unimplemented action: 112 (SPI_GETMOUSESPEED)
fixme:sync:CreateIoCompletionPort (0xffffffff, (nil), 00000000, 00000000): stub.
fixme:wininet:InternetSetOptionW Option INTERNET_OPTION_CONNECT_TIMEOUT (5000): STUB
fixme:wininet:InternetSetOptionW Option 6 STUB
fixme:wininet:InternetSetOptionW Option 45 STUB
fixme:imm:ImmGetContext (0x10022): stub
fixme:imm:ImmAssociateContextEx (0x10022, (nil), 16): stub
fixme:debug_buffer:RtlCreateQueryDebugBuffer (0, 0): stub
fixme:debug_buffer:RtlCreateQueryDebugBuffer (96, 0): returning 0x63652058
fixme:debug_buffer:RtlQueryProcessDebugInformation (8, 80000001, 0x63652058): stub
fixme:debug_buffer:RtlDestroyQueryDebugBuffer (0x63652058): stub
fixme:thread:GetThreadTimes Cannot get kerneltime or usertime of other threads
fixme:thread:NtQueryInformationThread info class 9 not supported yet
You need to install the Mozilla ActiveX control to
use Wine's builtin CLSID_WebBrowser from SHDOCVW.DLL
fixme:shdocvw:WBPCI2_GetGUID stub: dwGuidKind = 1, pGUID = {00000000-0000-0000-0000-000000000000}fixme:shdocvw:WBPCI2_GetGUID Wrongly returning IPropertyNotifySink interface {9bfbbc02-eff1-101a-84ed-00aa00341d07}
fixme:shdocvw:WBQA_QuickActivate stub: QACONTAINER = 0x6c4ee3a8, QACONTROL = 0x6c4ee3e0
fixme:shdocvw:WBPSI_Load stub: LPSTORAGE = 0x6c4ee474
fixme:shdocvw:WBCP_Advise stub: IUnknown = 0x77c72df0, connection cookie = 0
fixme:shdocvw:WBOOBJ_SetExtent stub: (0x6a28f7e0, 1, (15690 x 6535))
fixme:shdocvw:WBOOBJ_DoVerb : stub iVerb = -5
fixme:shdocvw:WBOOBJ_DoVerb stub for OLEIVERB_INPLACEACTIVATE
fixme:shdocvw:WBOOBJ_DoVerb : stub iVerb = -3
fixme:shdocvw:WBOOBJ_DoVerb stub for OLEIVERB_HIDE
fixme:shdocvw:WBOIPO_SetObjectRects stub PosRect = 0x77c72d48, ClipRect = 0x77c72d48
fixme:shdocvw:WBOC_GetControlInfo stub: LPCONTROLINFO = 0x77c72d90
fixme:shdocvw:WBOIPO_GetWindow stub HWND* = 0x6c4ee4a4
fixme:shdocvw:WBOC_FreezeEvents stub: bFreeze = 1
fixme:shdocvw:WBCP_Unadvise stub: cookie to disconnect = 77c72d68
fixme:shdocvw:WBCP_Unadvise stub: cookie to disconnect = 1
fixme:shdocvw:WBOIPO_InPlaceDeactivate stub
fixme:shdocvw:WBOOBJ_SetClientSite stub: (0x6a28f7e0, (nil))
fixme:debug_buffer:RtlCreateQueryDebugBuffer (96, 0): returning 0x77c5f880
fixme:debug_buffer:RtlQueryProcessDebugInformation (33, 80000001, 0x77c5f880): stub
fixme:debug_buffer:RtlDestroyQueryDebugBuffer (0x77c5f880): stub
Wine failed with return code 1
PLEASE, help me!
SCREEN:
