Mpeg2 og Premiere?
Sjekk følgende link:
http://www.techtv.com/products/digitalcameras/story/0,23008,3367391,00.html
Der står det blant annet følgende:
Although equipped with an i.Link (aka FireWire, 1394) port and USB, you'll need to load a special driver onto your PC to grab the video because the camera uses Sony's own hybrid MPEG-2 video compression. Only Sony's bundled video-editing software, MovieShaker, knows how to operate the video. If you want to use Adobe Premier, Vegas Video, or other PC-based editing software, you'll first have to save the video in the DV format -- which will result in additional lost picture information due to compression incompatibility.
_________________
mvh MagneH
[ Denne Melding var redigert av: MagneH på 2002-07-10 09:48 ]
