Amsn iorden, men ET er fortsatt på ville veier!
Amsn vil ikke la meg logge på!
jeg får skrivd inn nick og password, men den bare fryser mitt i oppkoblingen. hva kan jeg gjøre.
Enemy Territory klikker også med lyden. Lyden bare forsvinner når jeg skal starte programmet.
huff å huff
mvh Lolert
Endret av Lolert
Så dette kommer altså:
Versatec@versatec:~$ et
ET 2.60 linux-i386 Mar 10 2005
----- FS_Startup -----
Current search path:
/home/versatec/.etwolf/etmain/XWPpimpmyEt.pk3 (1 files)
/home/versatec/.etwolf/etmain/xposed.pk3 (75 files)
/home/versatec/.etwolf/etmain/voilegarde_b3.pk3 (236 files)
/home/versatec/.etwolf/etmain/venice.pk3 (330 files)
/home/versatec/.etwolf/etmain/transmitter-beta2.pk3 (105 files)
/home/versatec/.etwolf/etmain/townsquare_beta2.pk3 (27 files)
/home/versatec/.etwolf/etmain/temple_final.pk3 (57 files)
/home/versatec/.etwolf/etmain/tc_base.pk3 (63 files)
/home/versatec/.etwolf/etmain/svarvadel.pk3 (73 files)
/home/versatec/.etwolf/etmain/supplydepot2.pk3 (46 files)
/home/versatec/.etwolf/etmain/summer_palace_b1.pk3 (33 files)
/home/versatec/.etwolf/etmain/sp_delivery_rc2.pk3 (39 files)
/home/versatec/.etwolf/etmain/saberpeak_final.pk3 (243 files)
/home/versatec/.etwolf/etmain/rs_radars.pk3 (207 files)
/home/versatec/.etwolf/etmain/rommel_final_ETPRO_ONLY.pk3 (2 files)
/home/versatec/.etwolf/etmain/rommel_final_1107.pk3 (126 files)
/home/versatec/.etwolf/etmain/reactor_b1_ETPRO_ONLY.pk3 (2 files)
/home/versatec/.etwolf/etmain/reactor_b1.pk3 (73 files)
/home/versatec/.etwolf/etmain/password2_final.pk3 (101 files)
/home/versatec/.etwolf/etmain/pak2.pk3 (22 files)
/home/versatec/.etwolf/etmain/pak1.pk3 (10 files)
/home/versatec/.etwolf/etmain/pak0.pk3 (3725 files)
/home/versatec/.etwolf/etmain/pacman_v1.pk3 (37 files)
/home/versatec/.etwolf/etmain/northpole.pk3 (112 files)
/home/versatec/.etwolf/etmain/nf.pk3 (2 files)
/home/versatec/.etwolf/etmain/mp_tram.pk3 (83 files)
/home/versatec/.etwolf/etmain/mp_bin.pk3 (6 files)
/home/versatec/.etwolf/etmain/goldrush2_wx_beta2.pk3 (37 files)
/home/versatec/.etwolf/etmain/et_ice.pk3 (61 files)
/home/versatec/.etwolf/etmain/etmapscycle.pk3 (2 files)
/home/versatec/.etwolf/etmain/etmapcycle.pk3 (3 files)
/home/versatec/.etwolf/etmain/etmapcycle.4fda0897.pk3 (3 files)
/home/versatec/.etwolf/etmain/egnshrub.pk3 (2 files)
/home/versatec/.etwolf/etmain/Current.pk3 (1 files)
/home/versatec/.etwolf/etmain/complet66.pk3 (1 files)
/home/versatec/.etwolf/etmain/comp10.pk3 (1 files)
/home/versatec/.etwolf/etmain/cathedral_b4.pk3 (69 files)
/home/versatec/.etwolf/etmain/caen.pk3 (82 files)
/home/versatec/.etwolf/etmain/bwa10.pk3 (1 files)
/home/versatec/.etwolf/etmain/beach.pk3 (53 files)
/home/versatec/enemy-territory/etmain/voilegarde_b3.pk3 (236 files)
/home/versatec/enemy-territory/etmain/venice.pk3 (330 files)
/home/versatec/enemy-territory/etmain/transmitter-beta2.pk3 (105 files)
/home/versatec/enemy-territory/etmain/townsquare_beta2.pk3 (27 files)
/home/versatec/enemy-territory/etmain/temple_final.pk3 (57 files)
/home/versatec/enemy-territory/etmain/tc_base.pk3 (63 files)
/home/versatec/enemy-territory/etmain/svarvadel.pk3 (73 files)
/home/versatec/enemy-territory/etmain/supplydepot2.pk3 (46 files)
/home/versatec/enemy-territory/etmain/summer_palace_b1.pk3 (33 files)
/home/versatec/enemy-territory/etmain/sp_delivery_rc2.pk3 (39 files)
/home/versatec/enemy-territory/etmain/saberpeak_final.pk3 (243 files)
/home/versatec/enemy-territory/etmain/rs_radars.pk3 (207 files)
/home/versatec/enemy-territory/etmain/rommel_final_ETPRO_ONLY.pk3 (2 files)
/home/versatec/enemy-territory/etmain/rommel_final_1107.pk3 (126 files)
/home/versatec/enemy-territory/etmain/reactor_b1_ETPRO_ONLY.pk3 (2 files)
/home/versatec/enemy-territory/etmain/reactor_b1.pk3 (73 files)
/home/versatec/enemy-territory/etmain/password2_final.pk3 (101 files)
/home/versatec/enemy-territory/etmain/pak2.pk3 (22 files)
/home/versatec/enemy-territory/etmain/pak1.pk3 (10 files)
/home/versatec/enemy-territory/etmain/pak0.pk3 (3725 files)
/home/versatec/enemy-territory/etmain/pacman_v1.pk3 (37 files)
/home/versatec/enemy-territory/etmain/northpole.pk3 (112 files)
/home/versatec/enemy-territory/etmain/nf.pk3 (2 files)
/home/versatec/enemy-territory/etmain/mp_tram.pk3 (83 files)
/home/versatec/enemy-territory/etmain/mp_bin.pk3 (6 files)
/home/versatec/enemy-territory/etmain/goldrush2_wx_beta2.pk3 (37 files)
/home/versatec/enemy-territory/etmain/et_ice.pk3 (61 files)
/home/versatec/enemy-territory/etmain/etmapcycle.pk3 (3 files)
/home/versatec/enemy-territory/etmain/etmapcycle.4fda0897.pk3 (3 files)
/home/versatec/enemy-territory/etmain/complet66.pk3 (1 files)
/home/versatec/enemy-territory/etmain/comp10.pk3 (1 files)
/home/versatec/enemy-territory/etmain/cathedral_b4.pk3 (69 files)
/home/versatec/enemy-territory/etmain/caen.pk3 (82 files)
/home/versatec/enemy-territory/etmain/bwa10.pk3 (1 files)
/home/versatec/enemy-territory/etmain/beach.pk3 (53 files)
12223 files in pk3 files
execing default.cfg
couldn't exec language.cfg
execing profiles/Emil/etconfig.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
------- Input Initialization -------
Joystick is not active.
Bypassing CD checks
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
...loading libGL.so.1: Initializing OpenGL display
...setting mode 4: 800 600
Using XFree86-VidModeExtension Version 2.2
XF86DGA Mouse (Version 2.0) initialized
XFree86-VidModeExtension Activated at 800x600
Using 8/8/8 Color bits, 24 depth, 0 stencil display.
GL_RENDERER: GeForce FX 5700/AGP/SSE2/3DNOW!
Initializing OpenGL extensions
...using GL_S3_s3tc
...ignoring GL_EXT_texture_env_add
...using GL_ARB_multitexture
...using GL_EXT_compiled_vertex_array
...ignoring GL_NV_fog_distance
...ignoring GL_EXT_texture_filter_anisotropic
Initializing GLX extensions
...using GLX_SGI_swap_control
...using GLX_SGI_video_sync
XF86 Gamma extension initialized
GL_VENDOR: NVIDIA Corporation
GL_VERSION: 1.5.3 NVIDIA 71.74
GL_EXTENSIONS: GL_ARB_depth_texture GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_paletted_texture GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_shared_texture_palette GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
GLX_EXTENSIONS: GLX_EXT_visual_info GLX_EXT_visual_rating GLX_SGIX_fbconfig GLX_SGIX_pbuffer GLX_SGI_video_sync GLX_SGI_swap_control GLX_ARB_multisample GLX_NV_float_buffer GLX_ARB_get_proc_address
GL_MAX_TEXTURE_SIZE: 4096
GL_MAX_ACTIVE_TEXTURES_ARB: 4
PIXELFORMAT: color(24-bits) Z(24-bit) stencil(0-bits)
MODE: 4, 800 x 600 fullscreen hz:N/A
GAMMA: hardware w/ 0 overbright bits
CPU:
rendering primitives: single glDrawElements
texturemode: GL_LINEAR_MIPMAP_LINEAR
picmip: 0
texture bits: 0
multitexture: enabled
compiled vertex arrays: enabled
texenv add: disabled
compressed textures: enabled
anisotropy: 1.0
NV distance fog: disabled
Initializing Shaders
----- finished R_Init -----
------- sound initialization -------
/dev/dsp: Input/output error
Could not mmap /dev/dsp
Sound memory manager started
Sys_LoadDll(/home/versatec/.etwolf/etmain/ui.mp.i386.so)...
Sys_LoadDll(/home/versatec/.etwolf/etmain/ui.mp.i386.so) failed:
"/home/versatec/.etwolf/etmain/ui.mp.i386.so: cannot open shared object file: No such file or directory"
Sys_LoadDll(/home/versatec/enemy-territory/etmain/ui.mp.i386.so)... ok
Sys_LoadDll(ui) found **vmMain** at 0xad834f40
Sys_LoadDll(ui) succeeded!
--- Common Initialization Complete ---
Opening IP socket: localhost:27960
Hostname: localhost.localdomain
Alias: localhost
Alias: versatec
IP: 127.0.0.1
Started tty console (use +set ttycon 0 to disable)
^5PunkBuster Client: PunkBuster Client (v1.167 | A0) Enabled
^5PunkBuster Client: Game Version [ET 2.60 linux-i386 Mar 10 2005]
^5PunkBuster Client: Not Connected to a Server
Resolving etmaster.idsoftware.com
etmaster.idsoftware.com resolved to 192.246.40.60:27951
----- CL_Shutdown -----
RE_Shutdown( 1 )
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 135
Minor opcode of failed request: 10
Serial number of failed request: 291
Shutdown tty console
versatec@versatec:~$
Sound Issues
I found that sound did not work for my setup, giving me the following error:
/dev/dsp: Input/output error Could not mmap /dev/dsp
To resolve this issue I simply typed from root terminal the following:
echo "et.x86 0 0 direct" > /proc/asound/card0/pcm0p/oss
fra: http://ubuntuforums.org/showthread.php?t=5...enemy+territory
du kan også ta en titt her: http://ubuntuforums.org/showthread.php?t=1...enemy+territory
og her: http://ubuntuforums.org/showthread.php?t=3...enemy+territory
og for den saks skyld resten av ubuntu forumet
Endret av Pinguvin
Sound Issues
TAKKER DEG SÅ SINNSYK!!!!!
btw, jeg leita i stressa tilværelse på linux \ ubuntu foruma, så kanskje derfor jeg ikke så dt.
Takk for svar fra alle :D:yes: :!:
