Minne til Acer Ferrari 3400
Støtter den PC3200?  :blush:
Den støtter det ikke, så brikkene vil kjøre på PC2700-hastighet uansett...
Tullprat, Acer Ferrari 3200/3400 kjører PC3200 (DDR400) minne på full hastighet. Jeg bruker selv 2 stk. Corsair XMS3200LL 512MB på min og de kjører på full hastighet uten noen problemer. For dem som ønsker 2GB DDR400-minne så finnes det to gode alternativer:
http://forum.hardware.no/index.php?showtop...0entry3619022
Det høres fint ut ;) hvor setter jeg i minnet?
Sjekk min guide her for hvordan du gjør dette:
http://notebookforums.com/showthread.php?p=361430#post361430
A. Memory upgrade
I. Upgrading the first memory slot located at the base (see also p. 48-49 in the printed User's Guide):
1. Remove the two screws holding the memory cover on the bottom panel
2. Remove the memory cover
3. Pop out the memory module then remove it
4. Replace the memory module and reassemble everything[/indent]
II. Upgrading the second memory slot located under the keyboard:
1. Remove the four screws that secure the middle cover (the one with the power & launch keys); two on each of the hinges on the back of the LCD screen
2. Remove the two screws marked with a 'K' on the bottom panel
3. Open the LCD screen as far back as it will go
4. Gently detach the middle cover upward and outwards with the assistance of a plastic flat head screw driver
5. Remove the three screws that secure the keyboard
6. Slide out the keyboard towards the LCD screen
7. Pop out the memory module then remove it
8. Replace the memory module and reassemble everything
Hvis du har flere spørsmål om Acer Ferrari 3400 så er du hjertelig velkommen til å poste dem i denne samle-tråden:
http://forum.hardware.no/index.php?showtopic=242658
:thumbup:
Endret av snorreh
