Noen spørsmål om AMD Turion
Turion kommer på sokkel 754, dvs. en minnekanal(939 har som kjent to). Litt mer utdypende om kjernen:
Anandtech : "Much as we suspected, all of the power optimizations that went "into" Turion 64 are all transistor level optimizations. Basically, selecting transistors that provide better thermal and power characteristics at the expense of lower switching frequencies. Given that the Turion 64 runs at multiple speed grades lower than the fastest desktop Athlon 64s, this trade-off makes sense, but it also means that Turion 64 is no Pentium M killer. There was one logic level optimization that went into Turion 64 and that was the support of a deeper C3 sleep state, but other than that, the Turion 64 is architecturally identical to a Socket-754 Athlon 64."
Endret av type_o_negative
