VMware - problem
Har installert VMware i min SuSe 9.3 Pro, men når jeg skal konfigurere VMware kommer følgende melding:
linux:/usr/src/linux # vmware-config.pl
Making sure services for VMware Workstation are stopped.
Stopping VMware services:
  Virtual machine monitor                                             done
Trying to find a suitable vmmon module for your running kernel.
None of the pre-built vmmon modules for VMware Workstation is suitable for your
running kernel.  Do you want this program to try to build the vmmon module for
your system (you need to have a C compiler installed on your system)? [yes]
Using compiler "/usr/bin/gcc". Use environment variable CC to override.
What is the location of the directory of C header files that match your running
kernel? [/usr/src/linux/include]
Extracting the sources of the vmmon module.
Building the vmmon module.
Using 2.6.x kernel build system.
make: Entering directory `/tmp/vmware-config2/vmmon-only'
make -C /usr/src/linux/include/.. SUBDIRS=$PWD SRCROOT=$PWD/. modules
make[1]: Entering directory `/usr/src/linux-2.6.11.4-20a'
WARNING: Symbol version dump /usr/src/linux-2.6.11.4-20a/Module.symvers is  missing; modules will have no modversions.
 CC [M]  /tmp/vmware-config2/vmmon-only/linux/driver.o
 CC [M]  /tmp/vmware-config2/vmmon-only/linux/hostif.o
In file included from /tmp/vmware-config2/vmmon-only/linux/hostif.c:68:
/tmp/vmware-config2/vmmon-only/include/pgtbl.h: In function `PgtblVa2PTELocked':
/tmp/vmware-config2/vmmon-only/include/pgtbl.h:81: warning: passing arg 1 of `pmd_offset' from incompatible pointer type
 CC [M]  /tmp/vmware-config2/vmmon-only/common/cpuid.o
 CC [M]  /tmp/vmware-config2/vmmon-only/common/memtrack.o
 CC [M]  /tmp/vmware-config2/vmmon-only/common/phystrack.o
 CC [M]  /tmp/vmware-config2/vmmon-only/common/task.o
 CC [M]  /tmp/vmware-config2/vmmon-only/common/vmx86.o
 LD [M]  /tmp/vmware-config2/vmmon-only/vmmon.o
 Building modules, stage 2.
 MODPOST
 CC      /tmp/vmware-config2/vmmon-only/vmmon.mod.o
 LD [M]  /tmp/vmware-config2/vmmon-only/vmmon.ko
make[1]: Leaving directory `/usr/src/linux-2.6.11.4-20a'
cp -f vmmon.ko ./../vmmon.o
make: Leaving directory `/tmp/vmware-config2/vmmon-only'
The module loads perfectly in the running kernel.
This program previously created the file /dev/vmmon, and was about to remove it.
Somebody else apparently did it already.
Extracting the sources of the vmnet module.
Building the vmnet module.
make: Entering directory `/tmp/vmware-config2/vmnet-only'
 CC [M]  /tmp/vmware-config2/vmnet-only/driver.o
 CC [M]  /tmp/vmware-config2/vmnet-only/hub.o
 CC [M]  /tmp/vmware-config2/vmnet-only/userif.o
In file included from /tmp/vmware-config2/vmnet-only/userif.c:45:
/tmp/vmware-config2/vmnet-only/pgtbl.h: In function `PgtblVa2PTELocked':
/tmp/vmware-config2/vmnet-only/pgtbl.h:81: warning: passing arg 1 of `pmd_offset' from incompatible pointer type
/tmp/vmware-config2/vmnet-only/userif.c: In function `VNetCopyDatagramToUser':
/tmp/vmware-config2/vmnet-only/userif.c:563: warning: implicit declaration of function `skb_copy_datagram'
 CC [M]  /tmp/vmware-config2/vmnet-only/netif.o
 CC [M]  /tmp/vmware-config2/vmnet-only/bridge.o
 CC [M]  /tmp/vmware-config2/vmnet-only/procfs.o
 LD [M]  /tmp/vmware-config2/vmnet-only/vmnet.o
 MODPOST
Warning: could not open /tmp/vmware-config2/vmnet-only/includeCheck.h: No such file or directory
 CC      /tmp/vmware-config2/vmnet-only/vmnet.mod.o
 LD [M]  /tmp/vmware-config2/vmnet-only/vmnet.ko
cp -f vmnet.ko ./../vmnet.o
make: Leaving directory `/tmp/vmware-config2/vmnet-only'
Unable to make a vmnet module that can be loaded in the running kernel:
insmod: error inserting '/tmp/vmware-config2/vmnet.o': -1 Unknown symbol in module
There is probably a slight difference in the kernel configuration between the
set of C header files you specified and your running kernel.  You may want to
rebuild a kernel based on that directory, or specify another directory.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Execution aborted.
Noen som vet hva jeg må gjøre? Har prøvde d å kjøre make cloneconfig og make prepare, men ingen av delene fungerte.
