World of Warcraft i Wine [Problem]
Får denne feilmeldinga..
nvoking /usr/lib/wine/wine.bin WoW.exe ...
Please use the registry key HKEY_CURRENT_CONFIG\Software\Fonts\LogPixels
to set the screen resolution and remove the "Resolution" entry in the config fil e
fixme:opengl:query_function_pbuffer gl_version is: "1.3.4769 (X4.3.0-8.8.25)"
fixme:opengl:query_function_pbuffer glx_exts is: "GLX_EXT_visual_info GLX_EXT_vi sual_rating GLX_EXT_import_context GLX_ARB_get_proc_address GLX_ARB_multisample "
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798f5c4,0x00000000), stub!
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798f6c4,0x00000000), stub!
fixme:user:EnumDisplayDevicesA ((nil),0,0x7798fa80,0x00000000), stub!
fixme:d3d:IWineD3DImpl_GetDeviceCaps Caps support for directx9 is nonexistent at the moment!
fixme:system:SystemParametersInfoW Unimplemented action: 113 (SPI_SETMOUSESPEED)
err:x11settings:X11DRV_ChangeDisplaySettingsExW No matching mode found! (NoRes)
fixme:d3d9:IDirect3DDevice9Impl_CreateSurface (0x77c62338) call to IWineD3DDevic e_CreateRenderTarget failed
fixme:msvcrt:_XcptFilter (-1073741819,0x7798f5a8)semi-stub
fixme:thread:GetThreadTimes Cannot get kerneltime or usertime of other threads
Wine failed with return code
