2500 3dmarks
Hei, er det normalt å få 2500 3dmarks med dette oppsettet:
AMD Duron 800mhz
512 SD-ram
Geforce 2 pro 64mb
Abit KT7e (motherboard)
45gb 7200RPM WD
Windows 2000
og nyeste Detonator drivere!
Synes det er litt lite, kan jeg forvente mer eller må jeg se veien etter ny prosessor ?
Heisan!
Jeg hadde for ikke så lenge siden et system som ligna ganske mye på ditt (på spec-siden mener jeg).
Jeg scora 2984 med dette oppsettet:
Abit KA7-100
Classic athlon K7
CL GF2 GTS 32MB (ikke pro)
256 MB PC133 Mosel ram.
Brukte denne oppskriften, se under(på engelsk). Noen kommentarer; Driverne jeg brukte var 10.80, kan hende du får mer ut av 21.80 eller 22.80:
First BIOS:
1. Set dram clock: hclk+pciclk
2. Disable video bios shadow
3. Set dram timing to 8ns (ignore fast and turbo to begin with)
4. Set sdram cycle length to 2 (cas2)
5. Enable fast r-w turnaround
6. Disable video ram cacheable
7. Set AGP aperture size to half your system ram, or as close as you get.
8. Enable AGP 4x, of course
9. Disable AGP master wait-state read, making it use only one ws
10. Disable AGP master wait-state write, making it use only one ws
11. Set PnP OS installed to NO, even though you have a PnP OS. Windows screws up PnP-settings, let the bios do the job.
12. You really should download the latest BIOS, there are some fancy new features for setting your L2 cache if you are going to overclock your CPU.
Then windows:
1. Install the 5.13 drivers (6.18 is good too, do some experimenting, find out what your system likes best)
2. In display > properties > settings > advanced > GeForce 2 gts > additional properties > Direct 3D setting: Set mipmap to best performance, unhook any options (check boxes)
3. Open GL settings: V-sync off and no antialiasing.
4. And as always: Use ctrl+alt+del, make sure nothing but explorer, systray and powerstrip is running. (You can restart after you have run 3Dmark)
Then Powerstrip (you have downloaded it?):
1. Run Powerstrip, then right-click the Powerstrip icon > advanced options > performance (rock 'n' roll, baby) you're ready to overclock, use the sliders as much as you dare (make sure you have decent cooling though, I run 220/383)
2. Right-click Powerstrip again choose diagnostics. Check that you are running AGP 4x. You might want to try fast protocol, but my system locks up with this. Notice the IRQ number, make sure no other device is sharing this IRQ.
That's all I can think of, but there is probably a lot more... Good luck
BTW. Make sure you got decent cooling before overclocking your video card more than 7-8%
  • 1 måned senere...
Jeg faar 2500 poeng i 3DMark2001 med foelgende oppsett:
P3 800@800
Asus P3V4X
512 MB 133Mhz RAM
Asus V6800 GeForce 256 64MB RAM
Win2k Pro
DirectX 8.1
Nvidia 23.11
4in1 4.36
Hvis folk faar saa daarlige poeng med GF2, saa er det noe galt med kortene deres, eller noen av de andre delene i PC'en.
PS: Ingen komponenter er OC!!!
Jeg får 5115 poeng i default settings.
3dmark2001
_________________
Abit KT7A-RAID
AMD Athlon XP1600+ 1.4 GHz 266 MHz bus
Thermal Integration CPU-Vifte A/7/370
Gainward Geforce2 ti500xp 64mb ddr
512MB PC133 Original SDRAM
Western Digital Caviar 60GB IDE 7200RPM
ASUS DVD-rom IDE 16x/48x
<font class=editedby>[ Denne Melding var redigert av: Agger på 2002-01-10 13:37 ]</font>
[ Denne Melding var redigert av: agger på 2002-08-31 23:50 ]
Får 3011 med konfigurasjonen under. Og ja, det er på default innstillinger i 3dmark2001... Detonator 22.80 og VIA 4.36. Er ganske stolt av denne.
Dette resultatet er altså uten artifacts (G1 DDR på 140/340), men med en del artifacts får jeg 3150. Kortet er da på 150/350.
