emerge torsmo-cvs feiler
har prøvd å fulgt denne guiden på å installere torsmo-cvs, men den feiler når eg skal emerge:
Calculating dependencies ...done!
>>> emerge (1 of 1) app-admin/torsmo-cvs-091304 to /
>>> md5 files ;-) torsmo-cvs-091304.ebuild
>>> md5 files ;-) files/digest-torsmo-cvs-091304
>>> md5 files ;-) files/torsmo-cvs-setlocale.patch
>>> md5 files ;-) files/cvs_addused.patch
>>> md5 files ;-) files/cvs_mozilla.patch
>>> md5 files ;-) files/torsmo-cvs-double-buffer.patch
>>> Unpacking source...
* Fetching CVS module torsmo into /usr/portage/distfiles/cvs-src/torsmo-cvs ... * Running  cvs -q -f -z3 -d ":pserver:anonymous:@cvs.sourceforge.net:/cvsroot/torsmo" login
Logging in to :pserver:[email protected]:2401/cvsroot/torsmo
* Running  cvs -q -f -z3 -d ":pserver:[email protected]:/cvsroot/torsmo" update -dP torsmo
* Copying torsmo from /usr/portage/distfiles/cvs-src/torsmo-cvs ...
* CVS module torsmo is now in /var/tmp/portage/torsmo-cvs-091304/work
* Applying cvs_addused.patch ...
* Failed Patch: cvs_addused.patch !
*  ( /usr/local/portage/app-admin/torsmo-cvs/files/cvs_addused.patch )
* Include in your bugreport the contents of:
*   /var/tmp/portage/torsmo-cvs-091304/temp/cvs_addused.patch-13746.out
!!! ERROR: app-admin/torsmo-cvs-091304 failed.
!!! Function epatch, Line 358, Exitcode 0
!!! Failed Patch: cvs_addused.patch!
!!! If you need support, post the topmost build error, NOT this status message.
/var/tmp/portage/torsmo-cvs-091304/temp/cvs_addused.patch-13746.out ser sånn ut:
***** cvs_addused.patch *****
PATCH COMMAND:  patch -p0 -g0 < /usr/local/portage/app-admin/torsmo-cvs/files/cvs_addused.patch
patching file torsmo.c
Hunk #1 FAILED at 300.
Hunk #2 FAILED at 546.
Hunk #3 FAILED at 565.
Hunk #4 FAILED at 947.
Hunk #5 FAILED at 968.
5 out of 5 hunks FAILED -- saving rejects to file torsmo.c.rej
PATCH COMMAND:  patch -p1 -g0 < /usr/local/portage/app-admin/torsmo-cvs/files/cvs_addused.patch
missing header for unified diff at line 3 of patch
can't find file to patch at input line 3
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|--- torsmo.c	2004-08-19 15:39:31.297468784 -0400
|+++ torsmo_new.c	2004-08-19 15:58:17.597245192 -0400
No file to patch.  Skipping patch.
5 out of 5 hunks ignored
PATCH COMMAND:  patch -p2 -g0 < /usr/local/portage/app-admin/torsmo-cvs/files/cvs_addused.patch
PATCH COMMAND:  patch -p3 -g0 < /usr/local/portage/app-admin/torsmo-cvs/files/cvs_addused.patch
PATCH COMMAND:  patch -p4 -g0 < /usr/local/portage/app-admin/torsmo-cvs/files/cvs_addused.patch
noen som vet kordan eg kan få til dette? :ermm:
Endret av Pinguvin
Du kan kommentere ut patchen i .ebuild-en og prøve på nytt. Sannsynligvis er patchen utdatert.
Det er bra noen distroer har ressurser til å patche feil som ikke er blitt fikset upstream ennå, men å patche en ustabil cvs, er nok noe dristig.
Endret av drall
Typisk Gentoo, patcher alt til døde  :p
Installer den vanlige versjonen. Er det noen grunn til at du trenger CVS versjonen?
eg kunne ikke midtstille den vanlige men det ser ut som det går ann med cvs'en :blush:
Forandrer eg på noe i ebuilden klager den på at filstørrelsen ikke stemmer :(
Da tipper jeg du gjør noe feil. Det du skal kommentere ut er "epatch-linjen", men det er klart det kan være andre ting som skaper problemer likevel.
Jeg vet ikke hvilken filstørrelse du refererer til og det er en stund siden jeg har brukt gentoo, men kanskje du kan prøve å regenerere digesten slik: "emerge torsmo-cvs-091304 --digest".
Det finnes ingen torsmo-cvs ebuild i gentoo, så det blir feil å skylde på gentoo for at dette ikke fungerer.
