N/B strap CPU as? Hva er det?
Knugo
N/B Strap CPU As
Common Options : By CPU, PSB400, PSB533, PSB800
Quick Review
This BIOS feature allows you to circumvent the CPU-to-DRAM ratio limitation found in the newer Intel i865/i875-series of chipsets. In those chipsets, Intel has chosen to limit the choices of available CPU-to-DRAM ratios.
