magikern Skrevet 21. april 2005 Rapporter Del Skrevet 21. april 2005 prøvde å legge inn phppgadmin med apt-get, da fikk jeg dette: apt-get install phppgadmin Reading Package Lists... Done Building Dependency Tree... Done The following extra packages will be installed: php4-cgi php4-pgsql Suggested packages: phpdoc postgresql-doc The following NEW packages will be installed: php4-cgi php4-pgsql phppgadmin 0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded. Need to get 0B/1122kB of archives. After unpacking 2927kB of additional disk space will be used. Do you want to continue? [Y/n] y Preconfiguring packages ... (Reading database ... 34640 files and directories currently installed.) Unpacking php4-cgi (from .../php4-cgi_4%3a4.1.2-7.0.1_i386.deb) ... dpkg: error processing /var/cache/apt/archives/php4-cgi_4%3a4.1.2-7.0.1_i386.deb (--unpack): trying to overwrite `/usr/bin/php4', which is also in package php4-cli dpkg-deb: subprocess paste killed by signal (Broken pipe) Selecting previously deselected package php4-pgsql. Unpacking php4-pgsql (from .../php4-pgsql_3%3a4.1.2-4_i386.deb) ... Selecting previously deselected package phppgadmin. Unpacking phppgadmin (from .../phppgadmin_2.4.1-2_all.deb) ... Errors were encountered while processing: /var/cache/apt/archives/php4-cgi_4%3a4.1.2-7.0.1_i386.deb E: Sub-process /usr/bin/dpkg returned an error code (1) lurer da på den php4-cli, er det pakka for module versjonen av php4? eller er det noe annet som jeg kanskje kunne fjerna? har hørt tidligere at cgi vs module er en enten eller sak og av en grunn jeg ikke husker nå (da det har blitt noen år siden jeg satt opp den gjeldende maskinen) fant jeg ihvertfall ut at det skulle være bedre å bruke module, men om noen med gode argumenter mener at det er feil så si gjerne ifra... Lenke til kommentar
Gronz Skrevet 22. april 2005 Rapporter Del Skrevet 22. april 2005 (endret) dpkg --force-all -i /var/cache/apt/archives/php4-cgi_4%3a4.1.2-7.0.1_i386.deb Skal gå greit. Endret 22. april 2005 av Gimper Lenke til kommentar
zyp Skrevet 22. april 2005 Rapporter Del Skrevet 22. april 2005 php4-cli er kommandolinjeversjonen av php. Lenke til kommentar
magikern Skrevet 22. april 2005 Forfatter Rapporter Del Skrevet 22. april 2005 dpkg --force-all -i /var/cache/apt/archives/php4-cgi_4%3a4.1.2-7.0.1_i386.deb Skal gå greit. det funka fett, takk... Lenke til kommentar
magikern Skrevet 22. april 2005 Forfatter Rapporter Del Skrevet 22. april 2005 php4-cli er kommandolinjeversjonen av php. fant etterhvert ut av dette ja... Lenke til kommentar
