Flere og flere pakker blir 'kept back' i Sarge
Har igrunn veldig lite erfaring akkurat med Debian, men la inn Sarge på en server for noen mnd siden. Har vært endel oppdateringer, men det regnet jeg igrunn med siden den ikke er stable ennå. Ønsket uansett ikke legge inn Woody siden den er så gammel.
Det jeg stusser over er rett og slett at hver gang jeg er innom og oppdaterer med apt-get så blir det bare flere pakker som holdes igjen. Skal jeg i det hele tatt bry meg om dette? Skyldes det kompatibilitetsproblemer mellom pakker? Blir det fikset bare jeg venter en stund, eller må jeg gjøre noen manuelle grep etterhvert?
Mener å ha hørt at apt-get dist-upgrade kanskje kunne gjøre susen, men jeg trodde egentlig den var til å oppgradere til en helt ny versjon (f.eks woody->sarge).
apt-get update oppdaterer bare de pakkene du har, og vil ikke resolve nye dependencies.
apt-get dist-upgrade vil også resolve og hente ned dependencies.
Fra man sidene:
      upgrade
              upgrade  is  used to install the newest versions of all packages
              currently installed on the system from the sources enumerated in
              /etc/apt/sources.list.  Packages  currently  installed  with new
              versions available are retrieved and upgraded; under no  circum-
              stances  are  currently  installed packages removed, or packages
              not already installed retrieved and installed. New  versions  of
              currently  installed  packages  that  cannot be upgraded without
              changing the install status of another package will be  left  at
              their current version. An update must be performed first so that
              apt-get knows that new versions of packages are available.
      dist-upgrade
              dist-upgrade  in addition to performing the function of upgrade,
              also intelligently handles changing dependencies with  new  ver-
              sions  of  packages;  apt-get  has a "smart" conflict resolution
              system, and it will attempt to upgrade the most important  pack-
              ages  at  the  expense  of less important ones if necessary. The
              /etc/apt/sources.list file contains a  list  of  locations  from
              which  to  retrieve  desired package files. See also apt_prefer-
              ences(5) for a mechanism for overriding the general settings for
              individual packages.
Endret av Terrasque
