Enhancing PDA Cassiopeia E-115 to use as GPS
ajocius
Hei,
Could not fine section for PDA discussions so decided to put this topic here.
Have PDA Cassiopeia E-115 :
http://www.geek.com/hwswrev/pda/casioe115/
It has place for memmory card, wondows for pocket PC.
Was wondering if this could be used as part of GPS solution. Understand I would need to add GPS antenna, probably extra memory card to squeeze a map in. Is it possible? If so, could someone advice on possible alternatives for GPS antenna, memmory, software?
Endret av ajocius
