Jeg vil se på .wmv og .avi filmer :/
root@SaiLAPTOP:/home/saimann # sudo apt-get install gstreamer0.8-plugins
Reading Package Lists... Done
Building Dependency Tree... Done
gstreamer0.8-plugins is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 710 not upgraded.
hemm.. trenger jeg og reboote forresten?
prøvde forresten en .mpg fil, og det gikk ikke heller
Endret av SaiMANN
#ubuntu sier at du må installere totem-xine, så prøv det.
dette fikk jeg når jeg instalerte totem-xine. ser ut som den ikke fikk instalert alt
root@SaiLAPTOP:/home/saimann # apt-get install totem-xine
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  totem-xine: Depends: libgnome-desktop-2 (>= 2.9.91) but 2.8.1-0ubuntu1 is to b e installed
              Depends: libgnomevfs2-0 (>= 2.9.90) but 2.8.2-0ubuntu1 is to be in stalled
              Depends: libnautilus-extension1 (>= 2.9.1) but it is not going to be installed
E: Broken packages
  totem-xine: Depends: libgnome-desktop-2 (>= 2.9.91) but 2.8.1-0ubuntu1 is to be installed
              Depends: libgnomevfs2-0 (>= 2.9.90) but 2.8.2-0ubuntu1 is to be installed
E: Broken packages
hemm.. :(
kanskje jeg kan prøve og avinstallere alt totem ting jeg har instalert, og instalere på nytt?
eller er det bare bullshit? :/
Hadde vel vært en bedre løsning å reinstallere alt. Tror Ubuntu-installasjonen din er ganske ødelagt.
ja jøss.. :p
tok en agt-get update også prøvde jeg "apt-get install totem-xine".
Reading package lists... Done
Building dependency tree... Done
The following extra packages will be installed:
  libmodplug0 libxine1
The following packages will be REMOVED:
  totem-gstreamer
The following NEW packages will be installed:
  libmodplug0 libxine1 totem-xine
0 upgraded, 3 newly installed, 1 to remove and 0 not upgraded.
Need to get 4516kB of archives.
After unpacking 9429kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Get:1 http://us.archive.ubuntu.com hoary/main libmodplug0 1:0.7-3 [118kB]
Get:2 http://us.archive.ubuntu.com hoary/main libxine1 1.0-1ubuntu3 [3749kB]
Get:3 http://us.archive.ubuntu.com hoary/universe totem-xine 1.0.1-0ubuntu1 [649 kB]
Fetched 4516kB in 1m23s (53.8kB/s)
Preconfiguring packages ...
dpkg: totem-gstreamer: dependency problems, but removing anyway as you request:
totem depends on totem-gstreamer (= 1.0.1-0ubuntu1) | totem-xine (= 1.0.1-0ubun tu1); however:
  Package totem-gstreamer is to be removed.
  Package totem-xine is not installed.
(Reading database ... 67514 files and directories currently installed.)
Removing totem-gstreamer ...
Selecting previously deselected package libmodplug0.
(Reading database ... 67410 files and directories currently installed.)
Unpacking libmodplug0 (from .../libmodplug0_1%3a0.7-3_i386.deb) ...
Selecting previously deselected package libxine1.
Unpacking libxine1 (from .../libxine1_1.0-1ubuntu3_i386.deb) ...
Selecting previously deselected package totem-xine.
Unpacking totem-xine (from .../totem-xine_1.0.1-0ubuntu1_i386.deb) ...
Setting up libmodplug0 (0.7-3) ...
Setting up libxine1 (1.0-1ubuntu3) ...
Setting up totem-xine (1.0.1-0ubuntu1) ...
Dette så vel mer riktig ut? skal det gå ann og bare kjøre en .wmv eller .mpg fil i totem nå?
"Kommando" staves med K. En "commando" er en elitesoldat.
<offtopic>
Streng tatt er vel "kommando" norsk, mens "commando" er engelsk. Det heter kommandosoldat på norsk også... ;)
</offtopic>
Hva er egentlig forskjellen på å skrive "apt-get ..." og "sudo apt-get ..."?
<offtopic>
</offtopic>
"sudo apt-get" gir deg root-tilgang. Sånn hvis du ikke alllerede er innlogget som root i terminalet.
"sudo" er forkortelse for "super user do", altså "gjør dette som super user". Det vil si root. Sånn systemet er i Ubuntu så finnes det egentlig ikke en root-konto, man bare skriver inn passordet sitt ved bruk av sudo for å vise systemet at man er den rette brukeren. (root-kontoen kan aktiveres, men det tar vi ikke her, hvis man på død og liv vil ha et shell med super user-rettigheter kan man skrive "sudo -s -H")
Eller "sudo -i". Skal visst være litt sikrere enn "sudo -s".
