Jeg vil se på .wmv og .avi filmer :/
Hvordan kan jeg få sett på .wmv og .avi filmer på min Ubuntu maskin? når jeg kjører en .wmv fil står det bare: could not open file; reason unknown
Helst vil jeg kan kjøre de i totem, siden den er på ubuntu fra før ;)
Er veldig ny på Linux BTW :D
hemm.. får denne meldingen da jeg skriver sudo apt-get install w32codecs:
root@SaiLAPTOP:/home/saimann # sudo apt-get install w32codecs
Reading Package Lists... Done
Building Dependency Tree... Done
E: Couldn't find package w32codecs
prøvde det jeg. Da fikk jeg dette: ser fortsatt ut som den ikke finner den :(
W: Couldn't stat source package list http://us.archive.ubuntu.com hoary/main Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_hoary_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://us.archive.ubuntu.com hoary/restricted Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_hoary_restricted_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://us.archive.ubuntu.com hoary-updates/main Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_hoary-updates_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://us.archive.ubuntu.com hoary-updates/restricted Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_hoary-updates_restricted_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://us.archive.ubuntu.com hoary/universe Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_hoary_universe_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.ubuntu.com hoary-security/main Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_hoary-security_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.ubuntu.com hoary-security/restricted Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_hoary-security_restricted_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://security.ubuntu.com hoary-security/universe Packages (/var/lib/apt/lists/security.ubuntu.com_ubuntu_dists_hoary-security_universe_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list http://archive.ubuntu.com hoary/multiverse Packages (/var/lib/apt/lists/archive.ubuntu.com_ubuntu_dists_hoary_multiverse_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list ftp://ftp.nerim.net stable/main Packages (/var/lib/apt/lists/ftp.nerim.net_debian-marillat_dists_stable_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list ftp://ftp.nerim.net unstable/main Packages (/var/lib/apt/lists/ftp.nerim.net_debian-marillat_dists_unstable_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list ftp://ftp.nerim.net testing/main Packages (/var/lib/apt/lists/ftp.nerim.net_debian-marillat_dists_testing_main_binary-i386_Packages) - stat (2 No such file or directory)
W: You may want to run apt-get update to correct these problems
jaok, har kommet til 6'ern der jeg skal skrive: gpg --armor --export 1F41B907 | sudo apt-key add -
root@SaiLAPTOP:/home/saimann # gpg --armor --export 1F41B907 | sudo apt-key add -
sudo: apt-key: command not found
gpg: [stdout]: write error: Broken pipe
gpg: iobuf_flush failed on close: file write error
hm..
Litt off topic dette, men duverden som det frister med å legge inn Linux når man leser poster som dette! :p
Jaok! skal vi se, nå fikk jeg disse meldingene:
sudo apt-get install gstreamer0.8-plugins
root@SaiLAPTOP:/home/saimann # sudo apt-get install gstreamer0.8-plugins
gstreamer0.8-plugins is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 710 not upgraded.
W: Couldn't stat source package list cdrom://Ubuntu 5.04 _Hoary Hedgehog_ - Release i386 (20050407) hoary/main Packages (/var/lib/apt/lists/Ubuntu%205.04%20%5fHoary%20Hedgehog%5f%20-%20Release%20i386%20(20050407)_dists_hoary_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list cdrom://Ubuntu 5.04 _Hoary Hedgehog_ - Release i386 (20050407) hoary/restricted Packages (/var/lib/apt/lists/Ubuntu%205.04%20%5fHoary%20Hedgehog%5f%20-%20Release%20i386%20(20050407)_dists_hoary_restricted_binary-i386_Packages) - stat (2 No such file or directory)
w32codecs is already the newest version.
og på sudo apt-get install w32codecs:
ser dette riktig ut?
Litt off-topic dette også. Men jeg ble så lei av at Bill Gates fortalte meg hele tiden at jeg skulle kontakte systemadministrator og at "minne ikke kunne være written", så det frister ikke å gå tilbake :p
I motsetning til de dusinvis med postene som WIndowsbrukere har om Spyware, virus, feilmeldinger som ikke gir mening, programvare som koster mange tusen, og stadige hardwareoppdateringer fordi operativsystemet deres blir mer krevende.
Joa, jeg har veldig lyst på Windows.
</offtopic>
jaok, har fjerna linja og fikk dette:, men totem sier fortsatt at jeg ikke kan spille den!
root@SaiLAPTOP:/etc/apt # sudo apt-get install w32codecs
