Fixen for AGP og W2k+AMD
Roy1
Spørsmål om denne fixen som ska fixe memory corruption: http://support.microsoft.com/default.aspx?...b;EN-US;q270715
Hva betyr dette:
"The following workaround for this issue prevents Memory Manager from using the processor's Page Size Extension feature and may affect the performance of some programs, depending on the paging behavior. This registry value also limits non-paged pool to a maximum of 128 megabytes (MB) instead of 256 MB."
Betyr dette mye?
