ny pce som plutselig drop ned til 20 fps?
Yonaz
Hei
Har har amd 3200 socket 939 , ati radeon 9800 xt , 300 w strømforsyning og msi
MSI K8N NEO2 Platinum hovedkort .
Har 100 fps konstant i 20 min og så plutselig får jeg 20 - 30 fps i counter-strike noen som har peiling på hvor for?
noen som vet hvilket program "svchost.exe" er?? lurer bare :D
"Svchost.exe" (Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup, Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services, so that separate services can be run depending on how and where Svchost.exe is started. This allows for better control and debugging
