Direct X video noen options not supported o_O
gamerman
Hei
Jeg bruker Everest home edition for å sjekke visse ting på dataen min da jeg kom over optionen Direct X > DirectX Video :
Field Value
DirectDraw Device Properties
DirectDraw Driver Name display
DirectDraw Driver Description Primary Display Driver
Hardware Driver ati2dvag.dll
Hardware Description RADEON X800 XT Platinum Edition
Direct3D Device Properties
Available Local Video Memory 243688 KB
Available Non-Local Video Memory (AGP) 119759 KB
Rendering Bit Depths 16, 32
Z-Buffer Bit Depths 16, 24, 32
Min Texture Size 1 x 1
Max Texture Size 2048 x 2048
Vertex Shader Version 2.0
Pixel Shader Version 2.0
Direct3D Device Features
Additive Texture Blending Supported
AGP Texturing Supported
Anisotropic Filtering Supported
Bilinear Filtering Supported
Cubic Environment Mapping Supported
Cubic Filtering Not Supported ( ? )
Decal-Alpha Texture Blending Supported
Decal Texture Blending Supported
Directional Lights Supported
DirectX Texture Compression Supported
DirectX Volumetric Texture Compression Not Supported ( ? )
Dithering Supported
Dot3 Texture Blending Supported
Dynamic Textures Not Supported ( ? )
Edge Antialiasing Not Supported ( ? )
Environmental Bump Mapping Supported
Environmental Bump Mapping + Luminance Supported
Factor Alpha Blending Supported
Geometric Hidden-Surface Removal Not Supported ( ? )
Guard Band Supported
Hardware Scene Rasterization Supported
Hardware Transform & Lighting Supported
Legacy Depth Bias Supported
Mipmap LOD Bias Adjustments Supported
Mipmapped Cube Textures Supported
Mipmapped Volume Textures Supported
Modulate-Alpha Texture Blending Supported
Modulate Texture Blending Supported
Non-Square Textures Supported
N-Patches Not Supported ( ? )
Perspective Texture Correction Supported
Point Lights Supported
Point Sampling Supported
Projective Textures Supported
Quintic Bezier Curves & B-Splines Not Supported ( ? )
Range-Based Fog Supported
Rectangular & Triangular Patches Not Supported ( ? )
Rendering In Windowed Mode Supported
Scissor Test Not Supported ( ? )
Slope-Scale Based Depth Bias Not Supported ( ? )
Specular Flat Shading Supported
Specular Gouraud Shading Supported
Specular Phong Shading Not Supported ( ? )
Spherical Mapping Supported
Spot Lights Supported
Stencil Buffers Supported
Sub-Pixel Accuracy Supported
Table Fog Supported
Texture Alpha Blending Supported
Texture Clamping Supported
Texture Mirroring Supported
Texture Transparency Supported
Texture Wrapping Supported
Triangle Culling Not Supported ( ? )
Trilinear Filtering Supported
Two-Sided Stencil Test Not Supported ( ? )
Vertex Alpha Blending Supported
Vertex Fog Supported
Vertex Tweening Supported
W-Based Fog Supported
W-Buffering Not Supported ( ? )
Z-Based Fog Supported
Z-Bias Supported
Z-Test Supported
Supported FourCC Codes
AI44 Supported
ATIC Supported
AYUV Supported
DDES Supported
DXT1 Supported
DXT2 Supported
DXT3 Supported
DXT4 Supported
DXT5 Supported
IF09 Supported
IMC4 Supported
NV11 Supported
NV12 Supported
NV21 Supported
PBSM Supported
UYVY Supported
VBID Supported
XENC Supported
YUY2 Supported
YV12 Supported
YVU9 Supported
Kan noen forklare meg hvorfor noen er : not supported og hva disse betyr .....
Endret av gamerman
