csboy Skrevet 10. april 2005 Del Skrevet 10. april 2005 (endret) Antall Webpris Totalt MSI K8N NEO4 F, nForce4, Socket-939, ATX Raid, Lyd, 4xSATA, GbLAN, PCI-Ex16 Varenr.: 307784 Lagerstatus: 100+ stk på lager 899 899 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Corsair Value S PC3200 DDR-DIMM 1024MB Kit w/two matched Value Select 512MB Varenr.: 118737 Lagerstatus: 100+ stk på lager 999 999 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Sapphire Radeon X800XL 256MB GDDR3 PCI-Express,Tv-Out, DVI-I, Full-Retail Varenr.: 306372 Lagerstatus: 100+ stk på lager 2449 2449 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Western Digital Caviar 250GB SATA 8MB 7200RPM Varenr.: 118875 Lagerstatus: 40 stk på lager 1170 1170 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- AMD Athlon 64 3500+ 2.2GHz Socket 939, 512KB, BOXED m/vifte Varenr.: 307752 Lagerstatus: 500+ stk på lager 2090 2090 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Cooler Master Cavalier 3 Kabinett Sort Aluminium (Uten Strømforsyning) Varenr.: 303823 Lagerstatus: 100+ stk på lager 695 695 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Labtec Ultra Flat Keyboard, USB, PS/2 Varenr.: 306840 Lagerstatus: Ikke på lager. Ubekreftet 185 stk 2005-05-01 175 175 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Cooler Master Real Power 450W m/Strøm indikator Varenr.: 306517 Lagerstatus: 50-99 stk på lager 995 995 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Gainward Hollywood@Home 7.1 Lydkort PCI, Retail Varenr.: 122106 Lagerstatus: 50-99 stk på lager 329 329 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Er dette en god spille pc? Isåfall hva er flaskehalsen? Holder den til maks ytelse i cs 1.6? Pc`en skal ikke klokkes mye, kanske litte grann. Endret 10. april 2005 av csboy Lenke til kommentar
2 Fast 4 Biltema Skrevet 10. april 2005 Del Skrevet 10. april 2005 Ser bra ut den. Hvis du skal klokke ville jeg valgt pc 3500 eller høyere. Ps. Det er en Leif i "mne tilltelen din" (Tviler på at du får den PCn for 1000kr) Lenke til kommentar
Trost Skrevet 10. april 2005 Del Skrevet 10. april 2005 Ser bra ut den. Hvis du skal klokke ville jeg valgt pc 3500 eller høyere. Ps. Det er en Leif i "mne tilltelen din" (Tviler på at du får den PCn for 1000kr) er ikke max 1000kr han har skrevet, men max 1000k som altså er 1 million å det skal han nok klare. Lenke til kommentar
2 Fast 4 Biltema Skrevet 10. april 2005 Del Skrevet 10. april 2005 Ser bra ut den. Hvis du skal klokke ville jeg valgt pc 3500 eller høyere. Ps. Det er en Leif i "mne tilltelen din" (Tviler på at du får den PCn for 1000kr) er ikke max 1000kr han har skrevet, men max 1000k som altså er 1 million å det skal han nok klare. Velkommen til forumet Lenke til kommentar
Alph3z Skrevet 10. april 2005 Del Skrevet 10. april 2005 cs 1.6 er veldig avhengig av en god cpu, så der vil du få maks ytelse (og du ville hatt akkurat like bra ytelse med en 3200+ og et 6600GT) Hvis den kun brukes til cs 1.6, så trenger man ikke alt det nye Men skal du spille cs:source senere, og kanskje HL2 og andre litt mer krevende spill, kommer pcn til å bite kraftig ifra seg Lenke til kommentar
Phonix. Skrevet 10. april 2005 Del Skrevet 10. april 2005 ja, den pc'en er mer en god nok til å spille cs 1,6. Er ikke tvil. Kanskje velge litt dyrere(lavere timings) og eventuelt litt raskere ram? Lenke til kommentar
csboy Skrevet 10. april 2005 Forfatter Del Skrevet 10. april 2005 Ja, mente 10000kr, så jeg burde bytte til 6600GT og heller velge en bedre rambrikke? Blir vel flere spill, men det er mest viktig at den kan ligge stabilt på 100 fps i 1.6 Lenke til kommentar
Motig Skrevet 10. april 2005 Del Skrevet 10. april 2005 csboy? For et forferdelig nick... Lenke til kommentar
VegardStr Skrevet 10. april 2005 Del Skrevet 10. april 2005 så at du valgte et labtec tastatur.... eg gir deg et hint styr langt vekk fra labtec, det er et billigmerke og det virker ikke etter en uke, kjøpte en labtec mus en gang, og den gikk rett til helvette... Lenke til kommentar
Azton Skrevet 10. april 2005 Del Skrevet 10. april 2005 Tror det kommer til å bli en bra spillePC. Jeg ville nok holdt meg til X800XL kortet fremfor 6600GT. Value minnet fungerer nok greit det, men hvis du vil ha litt bedre kan jeg anbefale XMS serien til Corsair. Ganske greie minnebrikker. Koster ikke skjorta heller. - Azton Lenke til kommentar
Christian. Skrevet 10. april 2005 Del Skrevet 10. april 2005 Budskjett på 10000k eller 10000kr? Lenke til kommentar
csboy Skrevet 10. april 2005 Forfatter Del Skrevet 10. april 2005 csboy? For et forferdelig nick... Vet det Hadde max dårlig fantasi Lenke til kommentar
csboy Skrevet 10. april 2005 Forfatter Del Skrevet 10. april 2005 (endret) Noen forslag til åssen rambrikke jeg bør kjøpe? Og vil jeg få 100fps i cs 1.6 med dette skjermkortet. sry skrev feil, mente 10000kroner Endret 10. april 2005 av csboy Lenke til kommentar
VegardStr Skrevet 10. april 2005 Del Skrevet 10. april 2005 Kjøp denne brikken, er ikke så altfor dyr heller, bestilte den i dag fra PS data.no https://prisguiden.no/produkt/2740 Lenke til kommentar
