Trenger hjelp til bruker-registrerings-script
HTML-form, nybruker.php:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Untitled Document</title>
</head>
<body>
<?PHP
// Connect to your database here...
$host = "XXX";
$user = "XXX";
$password = "XXX";
$connection = mysql_connect($host,$user,$password)
or die ("kunne ikke koble til server");
$db = mysql_select_db("hesjevo_klevjer",$connection)
or die ("Kunne ikke koble til database");
$result = mysql_query("SELECT * FROM brukere");
$num_rows = mysql_num_rows($result);
echo
<form action="nybrukeraction.php" method="POST">
<table width="200" border="0" cellspacing="0" cellpadding="0">
 <tr>
 <!--Bruker id-->
   <td width="25">Brukernavn:</td>
   <td><input type="text" name="brukernavn" size="25" maxlenght="8"/><img src="1.gif" width="1" height="2"></td>
 </tr>
   <tr>
   <td width="25">Brukerid:</td>
   <td>
 <input type="text" name="brukerid" size="25" value="<?php echo ($num_rows + 1) ?>" maxlenght="4"/>
 </tr>
    <tr>
   <td width="25">Dato registrert</td>
   <td><input type="text" name="startdato" value="<?php $date=date("d.m.y H:i"); echo $date; ?>" size="25" maxlenght="8"/><img src="1.gif" width="1" height="2"></td>
 </tr>
   <tr>
   <td width="25">Fornavn:</td>
   <td><input type="text" name="fornavn" size="25" maxlenght="8"/><img src="1.gif" width="1" height="2"></td>
 </tr>
 <tr>
   <td width="25">Etternavn:</td>
   <td><input type="text" name="etternavn" size="25" maxlenght="8"/><img src="1.gif" width="1" height="2"></td>
 </tr>
 <tr>
   <td width="25">Gate:*</td>
   <td><input type="text" name="gate" size="25" maxlenght="30"/><img src="1.gif" width="1" height="2"></td>
 </tr>
 <tr>
   <td width="25">Gatenummer:*</td>
   <td align="center"><input type="text" name="gatenummer" size="25" maxlenght="3"/><img src="1.gif" width="1" height="2"></td>
 </tr>
 <tr>
   <td width="25">Postnummer:*</td>
   <td><input type="text" name="postnummer" size="25" maxlenght="4"/><img src="1.gif" width="1" height="2"></td>
 </tr>
 <tr>
   <td width="25">Postadresse:*</td>
   <td><input type="text" name="postadresse" size="25" maxlenght="20"/><img src="1.gif" width="1" height="2"></td>
 </tr>
 <tr>
   <td width="25">Email:*</td>
   <td><input type="text" name="email" size="25" maxlenght="40"/><img src="1.gif" width="1" height="2"></td>
 </tr>
   <tr>
   <td width="25">Telefon:*</td>
   <td><input type="text" name="telefon" size="25" maxlenght="8"/><img src="1.gif" width="1" height="2"></td>
 </tr>
     <tr>
   <td width="25">Kjønn:<img src="1.gif" width="1" height="2"></td>
   <td><select name="kjonn">>
     <option value="gutt"/>gutt
  <option value="jente"/>jente
  </select>	</td>
 </tr>
     <tr>
   <td width="25">Alder:<img src="1.gif" width="1" height="2"></td>
   <td><select name="alder">
<option value="15"/>15
<option value="16"/>16
<option value="17"/>17
<option value="18"/>18
<option value="19"/>19
<option value="20"/>20+
</select></tr>
     <tr>
       <td width="25" rowspan="2"><img src="1.gif" width="1" height="4"><input type="submit" value="Meld deg inn"></td>
     </tr>
</table>
</form>
</body>
</html>
nybrukeraction.php:
<html>
<head>
</head>
<body>
<?php
if($_POST['brukernavn']
&& $_POST['fornavn']
&& $_POST['etternavn']
&& $_POST['passord']
&& $_POST['gjentapassord']
&& $_POST['gateadresse']
&& $_POST['gatenummer']
&& $_POST['postnummer']
&& $_POST['postadresse']
&& $_POST['email']
&& $_POST['telefon']
&& $_POST['kjonn']
&& $_POST['alder'])
$email_sjekk = ereg("^[^@ ()$#><;%*?&+='\{}æøåÆØÅ]+@[^@()$#><;%*?&+='\{}æøåÆØÅ]+\.[^@()$#><;*%?&+='\{}æøåÆØÅ\.]+$",
$_POST['epost']);
if($email_sjekk == "1")
if($_POST['passord'] == $_POST['gjentapassord'])
$host = "XXX";
$user = "XXX";
$password = "XXX";
$db = "brukere";
$connection = @mysql_connect($hostname, $user, $password) or die("Sliter med å koble til databasen");
@mysql_select_db($db);
$sjekker_brukernavn = @mysql_query("SELECT brukernavn FROM brukere WHERE
brukernavn='$_POST[brukernavn]'");
if(@mysql_num_rows($sjekker_brukernavn) == 0)
$passord = crypt($_POST['passord']);
$legger_inn_info = @mysql_query( "INSERT INTO brukere (fornavn, etternavn, epost, brukernavn, passord, gateadresse, gatenummer, postnummer postadresse, email, telefon, kjonn, alder) VALUES ('$fornavn', '$etternavn', '$epost', '$brukernavn', '$passord', '$gateadresse', '$gatenummer',
'$postnumme', '$postadresse', '$email', '$telefon', '$kjonn', '$alder')");
if(@mysql_affected_rows($legger_inn_info) == "0")
print("Noe føkka seg opp. Prøv på nytt");
else
print("Det funka fett");
else
print("Finn et annet brukernavn, og slutt å kopiere andre");
else
print("Skriv like passord");
else
print("Hvis du prøver å føkke til systemet, får du ikke bli medlem. Skriv rikgtig email.<br>\n");
else
print("Fyll ut alt");
</body>
</html>
Databasen brukere inneholder:
