Den frie kafeen
dukker den opp når du tar dmesg i terminalen?
stale@grete:~$ dmesg | grep usb
[ 14.808614] usbcore: registered new interface driver usbfs
[ 14.808654] usbcore: registered new interface driver hub
[ 14.838617] usbcore: registered new device driver usb
[ 15.617073] usb usb1: configuration #1 chosen from 1 choice
[ 15.776730] usb usb2: configuration #1 chosen from 1 choice
[ 15.936420] usb usb3: configuration #1 chosen from 1 choice
[ 16.050256] usb usb4: configuration #1 chosen from 1 choice
[ 16.684786] usb 3-1: new low speed USB device using ohci_hcd and address 2
[ 16.904441] usb 3-1: configuration #1 chosen from 1 choice
[ 29.827708] usbcore: registered new interface driver hiddev
[ 29.835301] input: Microsoft Microsoft Wireless Optical Desktop® 2.10 as /devices/pci0000:00/0000:00:03.2/usb3/3-1/3-1:1.0/input/input4
[ 29.850874] input,hidraw0: USB HID v1.11 Keyboard [Microsoft Microsoft Wireless Optical Desktop® 2.10] on usb-0000:00:03.2-1
[ 29.894892] input: Microsoft Microsoft Wireless Optical Desktop® 2.10 as /devices/pci0000:00/0000:00:03.2/usb3/3-1/3-1:1.1/input/input5
[ 29.922760] input,hidraw1: USB HID v1.11 Mouse [Microsoft Microsoft Wireless Optical Desktop® 2.10] on usb-0000:00:03.2-1
[ 29.922794] usbcore: registered new interface driver usbhid
[ 29.922799] /build/buildd/linux-2.6.24/drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
[ 242.347201] usb 2-3: new low speed USB device using ohci_hcd and address 2
[ 242.561873] usb 2-3: configuration #1 chosen from 1 choice
[ 242.707624] usb 2-3: USB disconnect, address 2
[ 289.045307] usb 1-2: new low speed USB device using ohci_hcd and address 2
[ 289.259955] usb 1-2: configuration #1 chosen from 1 choice
[ 289.403973] usb 1-2: USB disconnect, address 2
[ 310.010774] usb 2-3: new low speed USB device using ohci_hcd and address 3
[ 310.225394] usb 2-3: configuration #1 chosen from 1 choice
[ 310.245884] input: Logitech USB-PS/2 Optical Mouse as /devices/pci0000:00/0000:00:03.1/usb2/2-3/2-3:1.0/input/input6
[ 310.270403] input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:00:03.1-3
[ 318.249039] usb 2-3: USB disconnect, address 3
[ 326.077209] usb 4-8: new high speed USB device using ehci_hcd and address 12
[ 326.211149] usb 4-8: configuration #1 chosen from 1 choice
[ 341.548986] usb 4-8.4: new low speed USB device using ehci_hcd and address 13
[ 341.646582] usb 4-8.4: configuration #1 chosen from 1 choice
[ 341.975101] usb 4-8.4: USB disconnect, address 13
[ 2971.830508] usb 4-8: USB disconnect, address 12
[ 3417.057658] usb 2-3: new low speed USB device using ohci_hcd and address 4
[ 3417.272412] usb 2-3: configuration #1 chosen from 1 choice
[ 3420.702110] usb 2-3: USB disconnect, address 4
[ 3421.320694] usb 2-3: new low speed USB device using ohci_hcd and address 5
[ 3421.501153] usb 2-3: device descriptor read/64, error -62
[ 3421.784613] usb 2-3: device descriptor read/64, error -62
[ 3422.064079] usb 2-3: new low speed USB device using ohci_hcd and address 6
[ 3422.243734] usb 2-3: device descriptor read/64, error -62
[ 3422.531181] usb 2-3: device descriptor read/64, error -62
[ 3422.810650] usb 2-3: new low speed USB device using ohci_hcd and address 7
[ 3423.217865] usb 2-3: device not accepting address 7, error -62
[ 3423.395937] usb 2-3: new low speed USB device using ohci_hcd and address 8
[ 3423.804733] usb 2-3: device not accepting address 8, error -62
[ 3430.372181] usb 2-3: new low speed USB device using ohci_hcd and address 9
[ 3430.586906] usb 2-3: configuration #1 chosen from 1 choice
[ 3438.321188] usb 2-3: USB disconnect, address 9
[ 3439.806125] usb 2-3: new low speed USB device using ohci_hcd and address 10
[ 3440.388997] usb 2-3: device not accepting address 10, error -62
[ 3441.870175] usb 2-3: new low speed USB device using ohci_hcd and address 12
[ 3442.084317] usb 2-3: configuration #1 chosen from 1 choice
[ 3442.240619] usb 2-3: USB disconnect, address 12
[ 3479.138854] usb 2-3: new low speed USB device using ohci_hcd and address 13
[ 3479.353570] usb 2-3: configuration #1 chosen from 1 choice
[ 3560.282824] usb 2-3: USB disconnect, address 13
[81508.847726] usb 1-2: new low speed USB device using ohci_hcd and address 3
[81509.062382] usb 1-2: configuration #1 chosen from 1 choice
[81819.865994] usb 1-2: USB disconnect, address 3
[81833.567899] usb 1-3: new low speed USB device using ohci_hcd and address 4
[81833.782566] usb 1-3: configuration #1 chosen from 1 choice
Går det å installere BackTracker3 lokalt på pcen?
Orker ikke tøve med Live cd hver gang man skal bruke noen av verktøyene. Har Laptop så det kan bli litt vanskelig å huske å ta den med seg overalt.
Endret av Sn3ipen
Må IGJEN få skryte av Ubuntu :) Testet noen gamle versjoner men ble for mye tull med repositories og feile oppdateringer. Ubuntu 8.04 LTS Edition er genialt stabil på min gamle laptop. alt funker smooth
Men har et lite problem , skal bruke arpwatch for å se om noen sniffer nettverket mitt så :
$ sudo apt-get install arpwatch
Gikk fint. men :
# arpwatch -i ath0
så får jeg bare feilmeldinger . kan jeg kansje ikke overvåke wifi med arpwatch?
Gjest Slettet+9871234
Er du sikker på at ath0 er eit nettverkskort?
Køyr sudo ifconfig i terminalen for å sjekke
Tøft. Har ein laptop med eit Atheros-kort, men fekk ikkje eingong av/på-ljoset til å fungere så eg lar han berre køyre Vista. Der fungerer i det minste nettverkskortet (men ikkje ljoden).
Har omsider fått meg en ny tv, så starter i den anledning med blanke ark igjen på mediasenter- maskinen med Kubuntu 8.04.1.
Bortsett fra at fonter på innloggingskjerm er uleselig små, så står det 1080P når jeg kommer til skrivebord, og alt i orden. Etter at jeg enabler Catalyst driveren får jeg fortsatt satt det til 1920x1080, men jeg får da ca 2cm oppe og nede, og 3cm på hver side som er svart, og dette selv om det i ATI driveren er satt ”fit to screen”.
Om det har noe med saken å gjøre er det en Sony W4000, og den er satt opp med pixel mapping 1:1, og DVI-HDMI mellom denne og X1800XT. Kan jo endre moduser på tv, men enten blir det for lite, eller går utenfor skjermen, eller i lavere oppløsning, så langt jeg har prøvd. Er satt opp med siste driver via Envy, som vel er 8.4 om jeg ikke husker helt feil.
Er dette noe slags gjenganger problem, eller noe som har en åpenbar løsning hører jeg gjerne om det?
Og en liten ting til, har også en gyromus til dette systemet, og i Vista skrur jeg ned farten litt, samt på med ”pekerpresisjon” for å få den brukbar. I Kubuntu kan man jo justere akselerasjon, samt hvor mange pixler man må flytte før akselerasjonen begynner, men selv med dette er det litt vanskelig med presisjonen.
Så, spørsmålet blir om det er noe config fil eller et eller annet jeg kan gjøre for å justere litt utenfor den skalaen i kontrollpanelet, eller endre arbeidsområdet for skala?
Til de av dere som har iPod og bruker Ubuntu, hvilket programm bruker dere for å laste over musikk?
Kjører rockbox på min iPod, så jeg flytter bare filene over som vanlig. Hvis du foretrekker standard OS-et er gtkpod ganske kurant.
Du kan jo prøve 8.6. De er ikke så vanskelig og installere manuelt. Bruk ATI wiki sidene. De har forandret rimelig mye siden 8.4.
Får se om jeg prøver det, prøvde faktisk såvidt for en stund siden men fikk ikke helt til å følge instruksen på ATI siden til tross for at det så nokså enkelt ut, skrev sikker noe feil eller noe sånt. Prøve med Wiki neste gang.
Fungerer dette Compiz Fusion greiene hos deg med Catalyst 8.6 eller? Jeg prøvde å sette på det, men det var visst ikke så lurt. Fikk et fint oppstartsbilde, men så ble det bare hvit skjerm, så logget inn fra en annen maskin og fikk fjernet det igjen. (kjører KDE da, det fungerer vel bedre i Gnome har jeg fått intrykk av...?)
Men fikk løst dette problemet med svarte kanter rundt skjerm til slutt gjennom aticonfig i terminal, der kan man endre X og Y posisjon, og X og Y oppløsning manuelt. Selv om alt tydet på at skjermen sto 1920x1080 var det i aticonfig 1810x980 eller noe litt rart tall.
Så da er det muse-config igjen, det har jeg ikke funnet ut av enda, men det dukker vel opp noe. :)
Jeg bruker litt av tråden her, og håper det er greit for å få svar her.
På svigermor in HP compaq nx9020 xubuntu laptop, så sitter det et intel grafikk kort
00:02.0 VGA compatible controller: Intel Corporation 82852/855GM Integrated Graphics Device (rev 02)
Hvis intel sine drivere er så fantastiske i forhold til linux hvordan får jeg de enabla? glxgears gir ca 150-160fps..
Skal bruke system() med PHP, og trenger sudo. Derfor må jeg mekke litt i /etc/sudoers for at www-data skal få lov å gjøre kommandoer uten å spørre om passord.
jeg har nå
Cmnd_Alias IR_CMDS = /etc/init.d/iguanaIR, /usr/sbin/lircd
og
www-data ALL=NOPASSWD: IR_CMDS
så har jeg
system( "sudo /etc/init.d/iguanaIR" );
denne virker
men
system( "sudo /usr/sbin/lircd" );
denne virker ikke
altså det går ikke med /usr/sbin/lircd i konsollen uten passord heller. Men /etc/init.d/iguanaIR virker
Endret av Ståle
Arti sak jeg oppdaget nå.
Har akkurat installert Slamd64 på hovedmaskin, og noe av det første jeg gjorde var å lage en opera pakke. Skjekket loggen for makepkg og la merke til en fil som het usr/lib/opera/9.51/operapluginwrapper-ia32-linux - hmmm...
Så jeg gikk inn på labs.adobe.com, lastet ned og installerte siste versjon av flash10beta, og, surprise surprise, youtube action i 64bits linux uten knot eller ndiswrapper.
yay opera :)
edit
hmm, dette har kanskje eksistert lengre enn det jeg trodde... nåja, kult uansett :)
Endret av olefiver
