Tinker Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 På min opprinnelige Slackware current hadde jeg NVIDIA Linux 100.14.19 driver installert. Etter kjerneoppdatering (slackpkg) til 2.6.23 forsvant denne. Så prøver jeg å installere den på nytt med den nye kjernen, men får feilmeldinger: ta4: SATA link down (SStatus 0 SControl 310) ata4: EH complete ata4: hard resetting port ata4: SATA link down (SStatus 0 SControl 310) ata4: EH complete ata5: hard resetting port ata5: SATA link down (-> Kernel module compilation complete. ERROR: Unable to load the kernel module 'nvidia.ko'. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if a driver such as rivafb/nvidiafb is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA graphics device(s). Please see the log entries 'Kernel module load error' and 'Kernel messages' at the end of the file '/var/log/nvidia-installer.log' for more information. -> Kernel module load error: insmod: error inserting './usr/src/nv/nvidia.ko': -1 Invalid module format -> Kernel messages:SStatus 0 SControl 310) ata5: EH complete ata5: hard resetting port ata5: SATA link down (SStatus 0 SControl 310) ata5: EH complete ata6: hard resetting port ata6: SATA link down (SStatus 0 SControl 310) ata6: EH complete ata6: hard resetting port ata6: SATA link down (SStatus 0 SControl 310) ata6: EH complete ip_tables: © 2000-2006 Netfilter Core Team Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (16384 buckets, 65536 max) NET: Registered protocol family 10 lo: Disabled Privacy Extensions eth0: no IPv6 routers present i2c_core: exports duplicate symbol i2c_smbus_xfer (owned by kernel) nvidia: version magic '2.6.23.1-smp SMP mod_unload 686 ' should be '2.6.23.9-smp SMP mod_unload 686 ' ERROR: Installation has failed. Please see the file '/var/log/nvidia-installer.log' for details. You may find suggestions on fixing installation problems in the README available on the Linux driver download page at www.nvidia.com. Her fra /etc/X11/xorgconfig: Section "Device" #VideoRam 262144 # Insert Clocks lines here if appropriate Identifier "NVIDIA GeForce" Driver "nvidia" EndSection Section "Screen" Identifier "Screen 1" Device "NVIDIA GeForce" Kortet er et XFX 6600GT (nVidia GeForce6600GT) Søker rundt, men klarer ikke sammenfatte det til noe konstruktivt, og spør derfor her om gode råd! Lenke til kommentar
stigfjel Skrevet 2. desember 2007 Rapporter Del Skrevet 2. desember 2007 (endret) Til dere som bruker et PVR-kort fra Hauppauge: har dere merket at det er en bug i ivtv-driveren som gjør at hvis man f.eks. ser på TV, avslutter MythTV og senere setter på en DVD, spiller av en fil eller starter MythTV på nytt så får man misfarging på skjermen, eller at MythTV får maskinen til å kræsje totalt? Har vært plaget av dette i lengre tid nå, og aner ikke hva feilen er. Edit: har sett dette både i Slackware med 2.6.21 (ivtv 0.10.6) og Debian Testing med 2.6.22 (ivtv 1.0 og integrert i kjernen). Endret 2. desember 2007 av stigfjel Lenke til kommentar
olear Skrevet 3. desember 2007 Rapporter Del Skrevet 3. desember 2007 På min opprinnelige Slackware current hadde jeg NVIDIA Linux 100.14.19 driver installert. Etter kjerneoppdatering (slackpkg) til 2.6.23 forsvant denne. Så prøver jeg å installere den på nytt med den nye kjernen, men får feilmeldinger Når du oppgraderer kernel må du passe på at du oppgraderer alle pakker relatert til dette. Det vil si kernel, moduler, headers, source og glibc (+ drivere du muligens bruker som ikke følger med kernel). Hvis kernel-source stemmer med den kjørende kernel er det bare å rekompilere nvidia-driveren (nvidia-installer sier i fra hvis det er noe tull). Lenke til kommentar
Tinker Skrevet 3. desember 2007 Rapporter Del Skrevet 3. desember 2007 Takk igjen, nå er det ok! Lenke til kommentar
Mato Skrevet 3. desember 2007 Rapporter Del Skrevet 3. desember 2007 noen som vet om det finnes noe program til ubuntu som lar meg justere fsb ? trenger og overklokke systemt mitt litt og biosen min suger balle , kan bare juster fbs minimalt , og neste hakk opp er for mye :/ Lenke til kommentar
Manuel Skrevet 3. desember 2007 Rapporter Del Skrevet 3. desember 2007 (endret) noen som vet om det finnes noe program til ubuntu som lar meg justere fsb ? trenger og overklokke systemt mitt litt og biosen min suger balle , kan bare juster fbs minimalt , og neste hakk opp er for mye :/ Jeg vet ikke om det finnes noen standard her, men et søk på google ga dette. Jeg har ikke prøvd det selv, så jeg vet ikke om dette programmet fungerer. Siden dette ikke ser ut til å være veldig maskinvarespesifikt så må det nok gå over SMB, evt. I^2C. Men bruker du distributøren sin kjernekonfigurasjon så er dette garantert støttet, om enn kanskje ikke av hovedkortet. Virker ikke programmet så kan du alltids sende en klage til hovedkortprodusenten! Endret 3. desember 2007 av Manuel Lenke til kommentar
Mato Skrevet 3. desember 2007 Rapporter Del Skrevet 3. desember 2007 (endret) takker , men jeg vet ikke helt hvordan jeg bruker det , var ikke akkurat noe manual med , virker som jeg må gjette meg til hvordan det virker EDIT: greit jeg tror jeg er inne på noe her , men langt fra sikker , det kommer med en makefile , som jeg regner med jeg må bruke for og instaler det når jeg kjører man -k makefile får jeg opp at jeg kan execute den på forskellige måter , men ingen av dem vil gjøre noe med fila . hvorfor kan ikke linux ting komme en en veiledning ? kunne da iverfall vært en link med noe info om instalering med . jaja ta meg en google runde i morgen EDIT2 : tja da har jeg lest meg litt opp på make , og det er komandoen for og kompliteren dette til et programm , men jeg får bare en meget lang feilmelding ( eventuelt mange ^^ ) [ make -C pll all make[1]: Entering directory `/home/mato/div stuff/lfsb-0.4.1/src/pll' gcc -O2 -g0 -s -std=c99 -Wall -pedantic -finline -c *.c In file included from i2c.h:15, from cy28331.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from cy28331.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ cy28331.c:13:18: error: math.h: No such file or directory cy28331.c: In function ‘cy28331_SetFSB’: cy28331.c:72: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ cy28331.c:95: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ cy28331.c:129: warning: implicit declaration of function ‘fabs’ cy28331.c:129: warning: incompatible implicit declaration of built-in function ‘fabs’ cy28331.c:30: warning: unused variable ‘i’ cy28331.c: In function ‘cy28331_GetFSB’: cy28331.c:166: warning: unused variable ‘i’ In file included from i2c.h:15, from ics9148-04.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9148-04.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9148-04.c: In function ‘ics9148_04_SetFSB’: ics9148-04.c:55: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9148-04.c: In function ‘ics9148_04_GetFSB’: ics9148-04.c:75: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9148-26.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9148-26.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9148-26.c: In function ‘ics9148_26_SetFSB’: ics9148-26.c:57: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9148-26.c: In function ‘ics9148_26_GetFSB’: ics9148-26.c:77: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9148-36.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9148-36.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9148-36.c: In function ‘ics9148_36_SetFSB’: ics9148-36.c:57: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9148-36.c: In function ‘ics9148_36_GetFSB’: ics9148-36.c:77: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9148-58.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9148-58.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9148-58.c: In function ‘ics9148_58_SetFSB’: ics9148-58.c:58: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9148-58.c: In function ‘ics9148_58_GetFSB’: ics9148-58.c:78: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9150-08.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9150-08.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9150-08.c: In function ‘ics9150_08_SetFSB’: ics9150-08.c:57: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9150-08.c: In function ‘ics9150_08_GetFSB’: ics9150-08.c:77: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9248-110.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9248-110.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9248-110.c: In function ‘ics9248_110_SetFSB’: ics9248-110.c:82: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9248-110.c: In function ‘ics9248_110_GetFSB’: ics9248-110.c:102: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9248-114.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9248-114.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9248-114.c: In function ‘ics9248_114_SetFSB’: ics9248-114.c:76: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9248-114.c: In function ‘ics9248_114_GetFSB’: ics9248-114.c:96: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9248-141.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9248-141.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9248-141.c: In function ‘ics9248_141_SetFSB’: ics9248-141.c:78: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9248-141.c: In function ‘ics9248_141_GetFSB’: ics9248-141.c:98: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9248-153.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9248-153.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9248-153.c: In function ‘ics9248_153_SetFSB’: ics9248-153.c:83: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9248-153.c: In function ‘ics9248_153_GetFSB’: ics9248-153.c:103: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9248-39.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9248-39.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9248-39.c: In function ‘ics9248_39_SetFSB’: ics9248-39.c:63: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9248-39.c: In function ‘ics9248_39_GetFSB’: ics9248-39.c:83: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9248-64.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9248-64.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9248-64.c: In function ‘ics9248_64_SetFSB’: ics9248-64.c:55: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9248-64.c: In function ‘ics9248_64_GetFSB’: ics9248-64.c:75: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics9250-08.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics9250-08.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics9250-08.c: In function ‘ics9250_08_SetFSB’: ics9250-08.c:63: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics9250-08.c: In function ‘ics9250_08_GetFSB’: ics9250-08.c:83: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics94215.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics94215.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics94215.c: In function ‘ics94215_SetFSB’: ics94215.c:85: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics94215.c: In function ‘ics94215_GetFSB’: ics94215.c:107: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ In file included from i2c.h:15, from ics94228.c:12: i2c-dev.h:27:25: error: linux/types.h: No such file or directory i2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory In file included from i2c.h:15, from ics94228.c:12: i2c-dev.h:38: error: expected specifier-qualifier-list before ‘__u16’ i2c-dev.h:50: warning: struct has no members i2c-dev.h:119: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:124: warning: union has no members i2c-dev.h:184: error: expected specifier-qualifier-list before ‘__u8’ i2c-dev.h:196: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_access’ i2c-dev.h:209: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_quick’ i2c-dev.h:214: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte’ i2c-dev.h:223: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte’ i2c-dev.h:229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_byte_data’ i2c-dev.h:239: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_byte_data’ i2c-dev.h:248: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_word_data’ i2c-dev.h:258: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_word_data’ i2c-dev.h:267: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_process_call’ i2c-dev.h:280: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_block_data’ i2c-dev.h:295: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_block_data’ i2c-dev.h:310: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_read_i2c_block_data’ i2c-dev.h:325: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_write_i2c_block_data’ i2c-dev.h:340: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘i2c_smbus_block_process_call’ ics94228.c: In function ‘ics94228_SetFSB’: ics94228.c:66: warning: implicit declaration of function ‘i2c_smbus_write_block_data’ ics94228.c: In function ‘ics94228_GetFSB’: ics94228.c:86: warning: implicit declaration of function ‘i2c_smbus_read_block_data’ make[1]: *** [pll] Error 1 make[1]: Leaving directory `/home/mato/div stuff/lfsb-0.4.1/src/pll' make: *** [pll] Error 2 er det noen som har noen peiling på hva som er galt , har prøvd og kjører make som sudo og vanlig uten at det har noe og si på resultatet . etter hva jeg skjønner utav dette så finner den ikke destinasjons folderene/ folderene / og eller filen den skal lage/ putte infoen inn i , men etter hva make dokkumentasjonen sier så burde make lage dette selv . Endret 4. desember 2007 av Mato Lenke til kommentar
Marsan Skrevet 4. desember 2007 Rapporter Del Skrevet 4. desember 2007 Jeg kom over en artikkel på it-avisen som tok for seg mac sin sterke økning i OS. De refererte kilden til denne siden: http://marketshare.hitslink.com/report.aspx?qprid=10 Er dette relle tall eller enda en spekulering? Lenke til kommentar
Simen1 Skrevet 4. desember 2007 Rapporter Del Skrevet 4. desember 2007 Alle sånne tall har et begrenset datagrunnlag. Den siden der har tydeligvis et datagrunnlag med en overrepresentasjon av windowsbrukere og IE-brukere etter det jeg har sett. Men det kan i det minste brukes til å detektere trender (økninger og minkninger). Den nettsiden presenterer nye data etter hvert månedsskifte. Men legg merke til at det er to grafer for Mac der. Mac OSX og Intel Mac OSX. Lenke til kommentar
pgdx Skrevet 5. desember 2007 Forfatter Rapporter Del Skrevet 5. desember 2007 Jeg kom over en artikkel på it-avisen som tok for seg mac sin sterke økning i OS. De refererte kilden til denne siden: http://marketshare.hitslink.com/report.aspx?qprid=10 Er dette relle tall eller enda en spekulering? Tallene kan i og for seg være så reelle som de bare vil, det som er spørsmålet er om utvalget kan generaliseres til populasjonen. Noen som kan tenke seg hvorfor Startsiden.nos logger er dårlig på å fortelle oss hvilke nettleser som er mest brukt? Tja, strengt tatt fordi de har avtaler med leverandører av Windows-maskiner, og setter IE opp med Startsiden som home page. Hva er problemet her? Jo, når folk laster ned Firefox fra nevnte maskiner, eller har maskiner som ikke er levert fra noen med avtale med Startsiden, så vil ikke Startsiden få like mange treff. Hvorfor er Slashdot en dårlig side å måle hvilke nettleser som er mest brukt? Lenke til kommentar
luser32 Skrevet 5. desember 2007 Rapporter Del Skrevet 5. desember 2007 (endret) Hvorfor er Slashdot en dårlig side å måle hvilke nettleser som er mest brukt? Jeg vet det, jeg vet det!!! Slashdot handler om "ting som betyr noe" - og størsteparten av verdens pc-brukere interesserer seg ikke for slikt. De liker heller ting med "tube" i seg. Endret 5. desember 2007 av luser32 Lenke til kommentar
Mato Skrevet 5. desember 2007 Rapporter Del Skrevet 5. desember 2007 ingen som har mulighet og peke meg litt i rett retning angående posten litt lengre oppe . jeg finner ikke så mye ut , har snart lest hele dokumentasjonen til GNUmake . Lenke til kommentar
olefiver Skrevet 5. desember 2007 Rapporter Del Skrevet 5. desember 2007 Hey Mato. Kan muligens hjelpe, men det hadde vært greit å vite HVA du forsøker å kompilere, og hvilken distro du skader heller ikke. Lenke til kommentar
Manuel Skrevet 5. desember 2007 Rapporter Del Skrevet 5. desember 2007 ingen som har mulighet og peke meg litt i rett retning angående posten litt lengre oppe . jeg finner ikke så mye ut , har snart lest hele dokumentasjonen til GNUmake . Du leter på feil sted. Hvis du ser på feilmeldingen som "make" ga deg, så er det egentlig kompilatoren som klager. Hvis du ser i filen i2c-dev.h, så vil du sannsynligvis finne #include-setninger med linux/types.h og så videre. Disse finner ikke make/kompilatoren på systemet ditt. Det mest sannsynlige er at du rett og slett mangler linux-headerene, eller så ligger de et annet sted enn /usr/lib. Avhengig av distroen du bruker, så må du installere "linux kernel headers" som tilsvarer (eller sånn ca) den kjernen du nå bruker. Lenke til kommentar
olefiver Skrevet 5. desember 2007 Rapporter Del Skrevet 5. desember 2007 (endret) Hmm. Mato får allerede slike feilmeldinger. siterer fra feil"loggen" han har i spoiler-tags i2c-dev.h:27:25: error: linux/types.h: No such file or directoryi2c-dev.h:28:23: error: sys/ioctl.h: No such file or directory Endret 5. desember 2007 av olefiver Lenke til kommentar
AudunSæther Skrevet 6. desember 2007 Rapporter Del Skrevet 6. desember 2007 Noen andre enn meg som har opplevd at Firefox har blitt fryktelig ustabil? Sitter med Ubuntu Gutsy, og Firefox låser seg rett som det der... riktignok oftest ved avspilling av flash, så det kan sannsynligvis være noe der.. Lenke til kommentar
BarteBaluba Skrevet 6. desember 2007 Rapporter Del Skrevet 6. desember 2007 Det er flash, får alle nettlesere til å bli ustabile. Lenke til kommentar
AudunSæther Skrevet 6. desember 2007 Rapporter Del Skrevet 6. desember 2007 Hadde ikke det problemet før Gutsy, men flash-versjonen er vel den samme vil jeg tro? Lenke til kommentar
Mato Skrevet 6. desember 2007 Rapporter Del Skrevet 6. desember 2007 (endret) jeg prøver og instalere dette http://sourceforge.net/projects/lfsb/ , og jeg sitter på Ubunru 7.10 Endret 6. desember 2007 av Mato Lenke til kommentar
BarteBaluba Skrevet 6. desember 2007 Rapporter Del Skrevet 6. desember 2007 jeg prøver og instalere dette http://sourceforge.net/projects/lfsb/ , og jeg sitter på Ubunru 7.10 Finn et repository som tilbyr pakker for ubuntu. Lenke til kommentar
