Den frie kafeen
Center er unmuta, men jeg får ingen lyd ut der.
Edit:
Eg har 7,1, men klarer meg med 5.1. Har upmix på forsterkeren :p
Men uten suben... må vel til meg custom routing eller noe sånt.
Noen som har erfaring?
Løsning
pcm.ch40dup {
    type route
    slave.pcm surround40
    slave.channels 4
    ttable.0.0 1
    ttable.1.1 1
    ttable.0.2 1
    ttable.1.3 1
pcm.ch51dup {
    type route
    slave.pcm surround51
    slave.channels 6
    ttable.0.0 1
    ttable.1.1 1
    ttable.0.2 1
    ttable.1.3 1
    ttable.0.4 0.5
    ttable.1.4 0.5
    ttable.0.5 0.5
    ttable.1.5 0.5
Det over skal i .asoundrc filen, samt du må velge device ch51dup, og ha surround satt til independ fremfor shared. :love:
MEN, 7.1 får jeg ikke, side-høytalerne er døde, bak foran, center og sub virker.
Endret av Frysning
Sendt til OCZ:
Klikk for å se/fjerne innholdet nedenfor
oczeuro @ ocztechnology . com
OCZ modules and OS compatibility.
I just saw the press release for PC2-6400 Platinum Vista Performance Edition 4GB (2x2048MB) dual channel kit here:
http://www.ocztechnology.com/aboutocz/press/2007/224
What makes these modules not suitable or badly optimized for other operating systems then Vista? How bad does they perform under other operating systems or do they work at all under other operating systems? Can you recommend other modules that does work good with a wide variety of operating systems?
regards
Simen Olsen
Dere må gjerne spørre dere også.
8896612[/snapback]
Jeg fikk svar:
Dear Mr. Olsen,
the „Vista Performance Edition“ in the product name does not mean the products will not run with different operating systems. In fact, they will perform exactly as good as in Vista in Linux, Windows XP or any other OS.
You wont experience any difficulties or performance issues with this kit in non-Vista operating systems.
Regards
Nico Stamp
Tech Support
OCZ Technology Group - www.ocztechnology.com
nstamp @ ocztechnology . com
OCZ memory modules and OS compatibility
I just read the press release for PC2-6400 Platinum Vista Performance Edition 4GB (2x2048MB) dual channel kit:
And I have a few questions:
1. I am a OCZ enthusiast, use only OCZ memory modules, but I am also a GNU/Linux enthusiast. Will these memory modules work on my systems, or must I switch my memory provider?
2. If these modules work on my systems, will they perform worse then under Windows Vista?
3. Are OCZ planning to release a similar dual channel kit optimized for GNU/Linux or UNIX-based operating systems?
4. Are damages caused by using the modules on a system not running Windows Vista covered by OCZ Lifetime Warranty?
Fortsetter min plagiering av Simen1 :)
Dear Mr. Iversen,
the „Vista Performance Edition“ in the product name does not mean the products will not run with different operating systems. In fact, they will perform exactly as good as in Vista in Linux, Windows XP or any other OS.  To answer your questions:
1.      Yes, the modules will just work fine with Linux.
2.      No, they will perform just as good as in Vista.
3.      Sorry, I can’t talk about that.
4.      An operaring system itself can’t do any damage to a memory module. Your lifetime warranty covers all operating systems.
Regards
Nico Stamp
Tech Support
min uthev
Arti å bli kalt Mr. ^_^
Endret av olefiver
Simen1: Grunnen til at det heter „Vista Performance Edition“ er vel snarere at OCZ mener man trenger 4GB RAM for å oppnå en viss performance i Vista  :wee:
8904508[/snapback]
Hehe, jeg ville ha det inn med teskje og provosere frem en eller annen uttalelse i den retninga og jammen klarte jeg ikke det:
Subject: Vedr. OCZ modules and OS compatibility.
Thanks for your response.
If the "Vista Performance Edition" performs equally in other OS, then why is
"Vista" used in the name? What makes this memory different from non Vista
labeled memory modules? Are you shure OCZ engineers didend differenciate
theese modules from comparable modules without the Vista label?
What about warranty? Does the lifetime warranty still apply if its used with
another OS?
regards
Simen Olsen
Mr. Olsen,
the "Vista" term just implies that this memory would fit Vista's extended
RAM consumption. Our Gold series for example doesn't contain real gold too
I assure you that this module is not different from other OCZ modules in
terms of OS compatibility. Your lifetime warranty wont be void if you use
any other operating systems.
Regards
Nico Stamp
Tech Support
Hehe "the "Vista" term just implies that this memory would fit Vista's extended
RAM consumption."
:mrgreen:
Det er bra at OCZ selv innrømmer at de bare spiller på gimmick og teit markedføring da (ikke at jeg klandrer dem for det). "Slutt å send meg e-post med spørsmål, den funker like bra for alle OS. Det er bare en gimmick overfor stakkars Vista-brukere for å selge mer!" :-)
endrebjorsvik: Slutt på kvakk-kvakks gode dager
8906534[/snapback]
Det blir ikke slutt på kvakk-kvakk, bare ekstern kvakk-kvakk. Kvakk-kvakk har faktisk blitt intern allerede. ;)
Edit: Men da kan den ikke snurre lenger. :hmm: Kanskje det var det du mente. Det er jo litt dumt.
Men kan ikke forumstyret gjøre noe mer fornuftig snart? F.eks redusere post-counteren?
Endret av endrebjorsvik
Hahaha! Fy flate så jeg begynte å le da jeg leste det! :lol:
8906463[/snapback]
Jeg lo bra jeg også. :D Skjønte at jeg hadde tøyd strikken med å leke dum langt nok for denne fyren.
Men ironisk nok tror jeg faktisk han tar feil på det punktet. Gullplattering er veldig vanlig innenfor elektrinikkbransjen. Faktisk så populært at 5% av gullproduksjonen i verden går med til elektronikk. Kontakter slik som de på minnemodulene tror jeg ofte er plattert med ekte gull for å unngå korrosjon og gjøre kontaktflaten bra. Det er bare snakk om milligram men likevel. Det er nok til at elektronikk er en attraktiv kilde for resirkulering.
Er du blitt lei av å bli beundret av forum-n00bs over din snart femsifret count? :p
BTW.
Noen som kjenner til en LiveCD distro som automagisk laster ivtv modul(er) ol. slik at jeg enkelt får testa om PVR350 kortet mitt faktisk funker?
Maskina skal kjøre Slack, men jeg vil bare teste litt først, før jeg starter å hacke opp et mediasenter.
8907137[/snapback]
Du kan gladelig få halvparten hvis du vil. Jeg må bare finne en måte å overføre på.
Enten må det skje noe med postcounten, ellers slutter jeg. Nå har jeg bare 620 igjen, så det begynner å haste.
Ubuntu får ikke røre noen av mine disker inntil jeg finner ut ihvertfall tre legitime rim på Ubuntu; altså aldri. Teite skrot-distro, ække muli' å rime på engang :p
Jeg laster nuh ned KnoppMyth og dyne:bolic som er livecder rettet direkte mot denne type oppsett. Hadde hadd GeexBox på lista også, men ser ut til sida nede...
Bare et spørsmål:
Jeg har to harddisker, en til OS/programvare og en til lagring av musikk/video/osv.
Begge er formatert i ext3. Jeg skal installere Arch over ubuntu på OS-disken, og lurer på om lagrings-disken bare kan mountes i Arch etter installasjon uten noe videre, eller må det noe mer til?
Mener det skal gå bra uten noe videre, men vil være på den sikre siden :p
Endret av Sapphire56
