Den frie kafeen
Noen som kjenner til PhotoPearls ?
Det følger med et Windows-program som jeg gjerne skulle fått til å virke med Wine, installasjonen går greit men ikke kjøring
administrator@BygdePC:~/.wine/drive_c/Programfiler/PhotoPearls$ wine PhotoPearls.exe
libGL warning: 3D driver claims to not support visual 0x46
err:richedit:ReadStyleSheet ReadStyleSheet: skipping optional destination
err:menubuilder:extract_icon32 found no icon
err:menubuilder:InvokeShellLinker failed to fork and exec wineshelllink
err:menubuilder:extract_icon32 LoadLibraryExW (L"C:\\Programfiler\\PhotoPearls\\eula.rtf") failed, error 193
err:menubuilder:ExtractFromICO Invalid ico file format
administrator@BygdePC:~/.wine/drive_c/Programfiler/PhotoPearls$ libGL warning: 3D driver claims to not support visual 0x46
fixme:actctx:QueryActCtxW 00000000 (nil) (nil) 2 0x34ee94 48 0x34eed0
fixme:actctx:QueryActCtxW 00000000 (nil) (nil) 2 0x34eeb0 48 0x34eee4
fixme:virtual:NtAllocateVirtualMemory MEM_WRITE_WATCH type not supported
fixme:actctx:QueryActCtxW 00000000 (nil) (nil) 2 0x34f488 48 0x34f4c4
fixme:actctx:QueryActCtxW 00000000 (nil) (nil) 2 0x34f4a4 48 0x34f4d8
fixme:actctx:QueryActCtxW 00000000 (nil) (nil) 1 0x34f52c 8 0x34f53c
fixme:shell:URL_ParseUrl failed to parse L"mscorlib.resources"
fixme:sync:CreateIoCompletionPort (0xffffffff, (nil), 00000000, 00000000): stub.
fixme:advapi:RegisterEventSourceA ((null),".NET Runtime"): stub
fixme:advapi:RegisterEventSourceW (L"",L".NET Runtime"): stub
fixme:advapi:ReportEventW (0xcafe4242,0x0001,0x0000,0x00000000,(nil),0x0001,0x00000000,0x7befe8d4,(nil)): stub
err:eventlog:ReportEventW L".NET Runtime version 1.1.4322.2032- Setup Error: Failed to load resources from resource file\nPlease check your Setup"
fixme:advapi:DeregisterEventSource (0xcafe4242) stub
Fatal stack overflow error.
På siden deres står det at det sikkert ikke går, men det er jo lov å prøve....
Kjører Ubuntu Edgy Eft.
Endret av -XaHc-
Du kan jo sjekke applikasjonsdatabasen hos www.winehq.com for å se om andre har fått det til å virke. Eller oppdatere Wine til nyeste versjon (hvilken versjon kjører du?) og se om det blir bedre. :)
7385398[/snapback]
Den nyeste i pakkebrønnen til Ubuntu... 0.9.22 ,den nyeste er vel 0.9.26
Kan man installere .NET Runtime til Wine? Har ett program her som kan installere VB6 Runtime og C++ Runtime
Endret av -XaHc-
Av ren nyskjerrighet, noen som vet hvordan det er med objorkum? Vet jo han forsvant på grunn av sykdom, men... tja. Nyskjerrighet. Trivelig kar :)
7378755[/snapback]
Lurer på det samme.. En meget dyktig og hyggelig kar ja! Hadde vært koselig å se han tilbake :)
7385398[/snapback]
7385700[/snapback]
For å installere vb6 putter du vb6.dll (eller noe sånt, knabbes fra en windows-boks) i system32-mappa.
Tenkte jeg bare skulle spørre litt kjapt om hvordan man formaterer en usbdisk i Ubuntu?
Skal installere DSL (http://www.damnsmalllinux.org/wiki/index.php/Installing_to_a_USB_Flash_Drive) på en 128mb minnepenn og har liten erfaring med linux.
7396620[/snapback]
Vel, nøyaktig hva lurer du på.
Hvilke kommandoer en bruker for å følge den guiden du linker til?
Download the dsl-embedded zipfile
Tipper det er denne du trenger, hvis du ikke har den allerede.
Create a FAT16 partition on the pendrive. Mount it.
Bruk programmet gparted. Burde ligge i pakkebrønn.
Unzip the dsl-embedded.zip file onto this.
Husker ikke hva det winzip-aktige programmet heter i Ubuntu. Men du skal ha et GUI program som kan pakke opp zip-filer
Via kommandolinja bruker du unzip:
unzip -d dsl-3.1-embedded.zip /sti/til/USBpennen
Unmount the pendrive
Burde ikke være vanskelig ( umount /sti/til/USBpennen )
run "syslinux -s /dev/sdX1" (without the quotes) to make it bootable.
Sier også seg selv, men i Ubuntu bør du vel legge til en sudo forran:
sudo syslinux -s /dev/sdX1
You can now boot via QEMU (from within Linux or windows), OR as native from the USB drive.
For at maskina skal kunne boote fra BUSpenn må BIOS være satt opp for det.
Lykke til.
vet noen om gode programmer for latex-kompilering? driver og eksperimenterer og lærer meg latex, trenger et program for å kompilere til pdf. fint om det støtter auto-fullføring av kommandoer.
kjører for øvrig xubuntu, så eneste kravet er at det må kjøre fint i det :)
