Den frie kafeen
Ingen som har noen tips da? Litt kjipt å ikke fått se hva jeg lager :p
mplayer output:
bjorninge@bjorninge-laptop:~/Desktop$ mplayer screencast-bjorninge-2006-09-17-21 -44.ogg
MPlayer 2:0.99+1.0pre7try2+cvs20060117-0ubuntu8 © 2000-2006 MPlayer Team
CPU: Intel Pentium M Dothan (Family: 6, Stepping: 8)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
91 audio & 204 video codecs
Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup scripts.
Opening joystick device /dev/input/js0
Can't open joystick device /dev/input/js0: No such file or directory
Can't init input joystick
Setting up LIRC support...
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support.
You will not be able to use your remote control.
Playing screencast-bjorninge-2006-09-17-21-44.ogg.
[Ogg] stream 0: video (Theora v3.2.0), -vid 0
Ogg file format detected.
VIDEO:  [theo]  1024x768  24bpp  10.000 fps    0.0 kbps ( 0.0 kbyte/s)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
[theora @ 0x86fd3e8]Missing extradata!
Could not open codec.
VDecoder init failed :(
Opening video decoder: [theora] Theora/VP3
VDec: vo config request - 1024 x 768 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
VO: [xv] 1024x768 => 1024x768 Planar YV12
Selected video codec: [theora] vfm: theora (Theora (free, reworked VP3))
Audio: no sound
Starting playback...
X11 error: BadAlloc (insufficient resources for operation)
MPlayer interrupted by signal 6 in module: vo_check_events
- MPlayer crashed. This shouldn't happen.
  It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
  gcc version. If you think it's MPlayer's fault, please read
  DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
  won't help unless you provide this information when reporting a possible bug.
bjorninge@bjorninge-laptop:~/Desktop$ mplayer screencast-bjorninge-2006-09-17-21-44.ogg
Audio: no sound
bjorninge@bjorninge-laptop:~/Desktop$ vlc screencast-bjorninge-2006-09-17-21-44.ogg
VLC media player 0.8.4 Janus
X Error of failed request:  BadAlloc (insufficient resources for operation)
  Major opcode of failed request:  141 (XVideo)
  Minor opcode of failed request:  19 ()
  Serial number of failed request:  81
  Current serial number in output stream:  82
bjorninge@bjorninge-laptop:~/Desktop$ totem screencast-bjorninge-2006-09-17-21-44.ogg
The program 'totem' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadAlloc (insufficient resources for operation)'.
  (Details: serial 67 error_code 11 request_code 141 minor_code 19)
  (Note to programmers: normally, X errors are reported asynchronously;
  that is, you will receive the error a while after causing it.
  To debug your program, run it with the --sync command line
  option to change this behavior. You can then get a meaningful
  backtrace from your debugger if you break on the gdk_x_error() function.)
For meg ser det ut til at det er for lite minne tilgjengelig, men dette kan da ikke stemme. Andre filmer som ikke er i ogg funker da perfekt. :(
Ser ikke ut som Slackware 11.0 noen gang blir ferdig, rc5 er ute :)
6888568[/snapback]
Det kan tenkes at de har støtt på en del problemer, at de trenger mer testing.
6890306[/snapback]
Egentlig ikke, ble lagt til et par nye programmer og SMP-kernel. Trenger litt tid til å modnes ;)
Første gang SMP er lagt til i Slackware ja.
6890555[/snapback]
Tidligere har du måttet kompilere selv om du har hatt mer enn en prosessor eller hatt lyst til å bruke HyperThreading?
6895431[/snapback]
Redd for det, ja. Ikke at det har vært det største problemet, vi Slackware-brukere finner alltid en løsning. Men likevel...
6890555[/snapback]
6895431[/snapback]
6895453[/snapback]
Nettopp hvorfor Slackware i det store og hele er fint å lære på (når du først har fått det grunnleggene ala "hva i alledager er BASH"), men i praktisk bruk foretrekker nå i allefall jeg å slippe å koke opp løsninger selv når jeg kan finne ferdiglagde og ferdigtestede. Jeg bruker Linux pga friheten deg gir meg, samt kraften. Altså av praktiske grunner, ikke for å leke mest mulig tid for å få ting til å funke som jeg vil.
