Den frie kafeen
god jul alle sammen!!
dessverre har det seg sånn at jeg fikk en DVD-brenner til jul, og skulle selvfølgelig teste denne. funka greit, fikk brent til DVD+RW, men får ikke slettet fra den. Legger ved en liten logg:
hakon@ubuntu:~$ sudo cdrecord dev=/dev/cdrom blank=fast
Cdrecord-Clone 2.01.01a01 (i686-pc-linux-gnu) Copyright (C) 1995-2004 Joerg Schi lling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
     and thus may have bugs that are not present in the original version.
     Please send bug reports and support requests to <[email protected]. org>.
     The original author should not be bothered with problems of this version.
cdrecord: Warning: Running on Linux-2.6.12-10-686
cdrecord: There are unsettled issues with Linux-2.5 and newer.
cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
scsidev: '/dev/cdrom'
devname: '/dev/cdrom'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Linux sg driver version: 3.5.27
Using libscg version 'ubuntu-0.8ubuntu1'.
cdrecord: Warning: using inofficial version of libscg (ubuntu-0.8ubuntu1 '@(#)sc sitransp.c      1.91 04/06/17 Copyright 1988,1995,2000-2004 J. Schilling').
Device type    : Removable CD-ROM
Version        : 0
Response Format: 2
Capabilities   :
Vendor_info    : '_NEC    '
Identifikation : 'DVD_RW ND-3540A '
Revision       : '1.01'
Device seems to be: Generic mmc2 DVD-R/DVD-RW.
cdrecord: Found DVD+ media but DVD+R/DVD+RW support code is missing.
cdrecord: If you need DVD+R/DVD+RW support, ask the Author for cdrecord-ProDVD.
cdrecord: Free test versions and free keys for personal use are at ftp://ftp.ber lios.de/pub/cdrecord/ProDVD/
cdrecord: Sorry, no CD/DVD-Recorder or unsupported CD/DVD-Recorder found on this  target.
cdrecord: This version of cdrecord does not include DVD-R/DVD-RW support code.
cdrecord: See /usr/share/doc/cdrecord/README.DVD.Debian for details on DVD suppo rt.
Using generic SCSI-3/mmc   CD-ROM driver (mmc_cd).
Driver flags   : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Starting to write CD/DVD at speed 48 in real BLANK mode for single session.
Last chance to quit, starting real write    0 seconds. Operation starts.
This drive or media does not support the 'BLANK media' command
cdrecord: Cannot blank disk, aborting.
cdrecord: Some drives do not support all blank types.
cdrecord: Try again with cdrecord blank=all.
God jul!
Da jeg installerte Ubuntu Linux, installerte jeg det på en egen harddisk (IDE) som stod som Master. Når jeg har byttet mellom Linu og Windows i det siste har jeg bare byttet om på IDE-kabelen, siden begge to står som master. Hvis jeg da setter Windows-disken som Slave og setter kabelen i begge to, vil jeg da Linux boote automatisk, og i tillegg ikke gjøre noen som helst form for forandringer på Windows-disken?
Jeg tenker på å gjøre det for å ha musikksamlingen min tilgjengelig mens jeg utforsker Linux.
Har lett litt etter templates for nvu.
For å mekke hjemmesider.
Tenkte å begynne helt på nytt , siden den gamle er laget i frontpage.
Men er såpass grønn at noen templates å ta utgangspunkt i er kjekt.
noen gode nedlastningstips ?
ps god jul til alle pingviner
Endret av vega77
Stemmer det. Men husk å sette windows-disken til slave, slik at du slipper stress med bootloaderen (om ting ligger på hdb istedet for hda, osv).
God jul til alle sammen!
Jeg sitter og fungerer over hvordan jeg best kan effektivisere hjemmenettverket her ...
Har dere noen formening om hvilket WLAN-kort som er best støttet av Linux?
Er det mulig å få et kort til å fungere som aksesspunkt, eller finnes det evt. WLAN-kort med mulighet for å fungere som aksesspunkt?
Endret av G2Petter
God jul folkens.
anyway så skulle eg prøve Debian Sarge no i jula (siden det først er då ein har tid til slikt). Og det gjekk jo greit til eg skulle installere nvidia drivere. Då fant eg ut at den kjørte ein 2.4 kjerne (kvifor?) og dermed funka ikkje nvidia driveren. nokon som har noko tips her?
God jul folkens.
5339083[/snapback]
Du må skrive "linux26", hvis du skal installere 2.6-kjerne ved installasjon. Egil.B har løsningen (antar jeg) for å installere 2.6-kernel i etterkant.
God jul folkens.
5339083[/snapback]
5339150[/snapback]
Jepp, lønner seg å installere med "linux26", men du kan bare smelle inn et kernel image fra apt i etterkant også. "apt-cache search linux-image-2.6" og installer den nyeste linux-image pakken som passer for din PC, samt linux-header pakken som matcher :)
En julehistorie fra groklaw.net:
SCO Sues Santa Claus
"Mr. Claus was an early licensee of Unix and ran his entire operation on Unix systems," SCO representative Blake Stowell said. "About 10 years ago, he stopped sending royalty checks, and we discovered that he had illegally migrated to Linux".
"This will really rock the Christmas gift industry," analyst Laura DiDio said. "Given the cloud hanging over Claus, I'm recommending that people give Microsoft products, and only Microsoft products, as gifts this year".
THAT'S IT!
Cry Open Scoure, let loose the GNUs of war. Deploy the penguin-kamikaze flyers, we're taking down SCO!
thi hi hi :!:
5337362[/snapback]
Kan ikke annet enn å anbefale deg å lære deg HTML og CSS. http://htmldog er et fint sted å begynne.
Du kan bytte font.
Ellers synes jeg default amsn-utseende nå var mye penere enn de forrige versjonene. Kommer nok ikke til å bruke den. Er kjekt å kunne ha noe mer enn msn, siden msn jo titt og ofte er nede.
EDIT: Det var visst et ubuntu-theme som fulgte med ubuntu-pakka. Default skin var veldig lik ja :).
EDIT2: Har prøvd amsn litt nå, og kan konkludere med at den nærmer seg MSN Messenger i fjortis-usability. Nudge, animasjoner og tegnebrett.
Endret av RattleBattle
