Den frie kafeen
Hvordan kan jeg finne ut om en .deb er installert? I «man dpkg» fant jeg
  PACKAGE STATES
      installed
              The package is unpacked and configured OK.
men jeg forstår ikke hvordan jeg skal bruke det med dpkg. Den klager over at det trengs et action parameter.
Endret av dabear
hey, så sshfs ble nevnt -- og den fungerte veldig bra i alle applikasjoner untatt Nautilus
..litt snedig i grunn.. spesiellt siden den lukker seg ned med en gang - uten feilmelding
noen som kjenner til dette? (Gentoo btw.)
Edit:
har i grunn mistanke om at den spawner en ny tråd når jeg starter en ny instans á nautilus .. og at dette er grunnen til at jeg ikke får noen feilmelding .. lurer på om meldingen blir rutet ett eller annet sted ...hm
Endret av dayslepr
Hmm, snodig. Hadde noen små problemer med LUFS, men etter jeg gikk over til FUSE så har jeg ikke hatt noe problemer. Den eneste filbehandler jeg har er ROX og der fungerer alt perfekt (og alle andre program jeg bruker).
Fant denne:
I've been using FUSE with the sshfs filesystem for the last couple of
weeks.  So far it's worked flawlessly.  Also, it takes all of 10 minutes
to download and install.  Basically the './configure && make && make
install' for both packages, followed by 'modprobe fuse' and mounting the
filesystems.
The only issue I've had to date are with Nautilus.  For some reason
sshfs reports the UID/GID from the remote host, not the user who mounted
the local fs.  In practice this doesn't matter since most programs just
try to read/write and are successful.  However, Nautilus actually checks
permissions and gets the mistaken impression that you can't write to the
sshfs and so prevents you from doing so, even though in reality it
could.
I've submitted a report to the author of sshfs (and tried unsuccessfully
to patch the code myself).
EDIT:
Quick follow-up.  I heard back from sshfs' author and he informs me that
while Nautilus is stupid, the CVS version of FUSE has uid=N and gid=N
options that can fix this.
I'll be installing the CVS version here and I'll report back in a few
days.
Endret av olear
   PACKAGE STATES
       installed
5082463[/snapback]
dpkg --help gir bl.a. følgende opsjon:
dpkg -s|--status <package-name> ...      display package status details
Og denne gir en del output, men det interessante er linjen ^Status:
$ dpkg -s emacs21
Package: emacs21
Status: install ok installed
Priority: optional
En pakke som ikke er konfigurert helt, ser slik ut:
$ dpkg -s tetex-bin
Package: tetex-bin
Status: install ok half-configured
Priority: optional
Mens pakker som ikke er installert kan gi følgende output som kommer an på om dpkg finner informasjon om pakken eller ikke: (Og jeg vet ikke hvorfor den finner info om pakken kde, men ikke om pakken gnome...)
$ dpkg -s gnome
Package `gnome' is not installed and no info is available.
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
$ dpkg -s kde
Package: kde
Status: purge ok not-installed
Priority: optional
Section: x11
EDIT: Ahh.. Selvfølgelig... gnome er en metapakke, dpkg -s gnome-core ga samme output som kde-pakken.
Endret av Entropi
Denne koden plassert i ~/.xsession gjør at startup tida til gnome blir drastisk redusert. Uheldigvis kræsjer det en del av appletsene mine på panelet. Noen som har noen andre slike scripts?
#!/bin/sh (-)
eval `ssh-agent`
gnome-settings-daemon &
gnome-panel &
nautilus -n &
beagled --bg &
gnome-screensaver &
exec metacity
#!/bin/sh (-)
eval `ssh-agent`
gnome-panel &
nautilus -n &
beagled --bg &
gnome-screensaver &
exec metacity
5086407[/snapback]
Grunnen til at det går raskere er fordi du starter alt parallellt. At dette fører til at enkelte "applets" kræsjer skyldes nok at enkelte avhengigheter ikke kan tilfredstilles. Det er en grunn til at du ikke kan slenge alle daemons og tjenester i bakgrunnen med en gang init får muligheten, for å si det sånn ;)
Jeg kan ikke komme noe som løser problemet ditt, men en stygg "hack" kan være å legge inn "sleep 1" et eller flere steder i skriptet
Endret av Manuel
Japp, det jeg gjør, men parted sier bare 'This ext2 filesystem has a rather strange layout! Parted can't resize this'.
Hadde det vært partisjon nr. 1 hadde det visstnok gått greit, men problemet er at det er to andre partisjoner før den jeg skal ha resized.
Bruker forresten MEPIS sin liveCD jeg også.
http://belenix.sarovar.org/belenix_home.html
LiveCD med OpenSolaris. Noe for dem som vil prøve Solaris, men ikke orker/tørr å installere den.
5084334[/snapback]
Hey , denne her var kul . Alt bortsett fra lyden virka med en gang . Men det jeg syns var merkelig var at den
satt opp mitt X800XT med 1600x1200x100hz uten at jeg trengte configurere noe som helst :hmm:
EDIT , var ikke rare 3d akselrasjonen her da , bare 29 fps paa Supertux :p
Endret av erikoi
5084334[/snapback]
5092822[/snapback]
Belenix bruker X.Org 6.9cvs, så open-source DRI-driverne er ganske oppdatert. Og hvis du installerer OpenSolaris, og så installerer OSS, så er det en stor sjanse for at lyden vil fungere. Vet at OSS har støtte for ganske nye lydkort som f.eks. Audigy 2.
