Den frie kafeen
Kan noen poste sin /etc/apt/sources.list her? Jeg har litt problemer med flere av serverne mine...
5022890[/snapback]
Breezy?
http://www.objorkum.com/files/sources.txt
5022903[/snapback]
Nei, Hoary... (:
5022953[/snapback]
#deb cdrom:[ubuntu 5.04 _Hoary Hedgehog_ - Release i386 (20050407)]/ hoary main restricted
## Uncomment the following two lines to fetch updated software from the network
deb http://no.archive.ubuntu.com/ubuntu hoary main restricted
deb-src http://no.archive.ubuntu.com/ubuntu hoary main restricted
## Uncomment the following two lines to fetch major bug fix updates produced
## after the final release of the distribution.
deb http://no.archive.ubuntu.com/ubuntu hoary-updates main restricted
deb-src http://no.archive.ubuntu.com/ubuntu hoary-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://no.archive.ubuntu.com/ubuntu hoary universe
deb-src http://no.archive.ubuntu.com/ubuntu hoary universe
deb http://security.ubuntu.com/ubuntu hoary-security main restricted
deb-src http://security.ubuntu.com/ubuntu hoary-security main restricted
deb http://security.ubuntu.com/ubuntu hoary-security universe
deb-src http://security.ubuntu.com/ubuntu hoary-security universe
deb http://archive.ubuntu.com/ubuntu hoary multiverse
deb-src http://archive.ubuntu.com/ubuntu hoary multiverse
## Backports
#deb http://ubuntu-backports.mirrormax.net/ hoary-backports main universe multiverse restricted
#deb http://ubuntu-backports.mirrormax.net/ hoary-extras main universe multiverse restricted
Bruker ikke backports lenger grunnet litt dill jeg støtte på forleden dag, men du kan godt skru dem på om du vil. :)
Er det ikke noe greier med at apt ikke takler multilib, dvs. kombinerte 64 og 32-bits arkitekturer? Tror det var derfor RedHat (videre)utviklet yum isteden for å bruke apt...
5026597[/snapback]
Apt takler multilibs, men pakkene må ha forskjellig navn, det er derfor apt klarer SUSEs multilibs, siden de heter noe annerledes når de er 64bit, apt klarer det ikke når pakkene har likt navn men forskjellig arch.
Gotta love linux! :love:
Jeg har noe jobb på den stasjonære PC'en jeg skal gjøre, men var lei av å sitte der. Så jeg tenkte jeg skulle logge på den fra laptoppen via XDMCP. En grei jobb jeg har gjort før, og en kjapp endring i en av KDM's konfigurasjonsfiler fikset det.
Men det jeg ikke var klar over er muligheten for å ha både en lokal X-sesjon gående samtidig som man har en ekstern sesjon. Så nå sitter jeg og veksler fort og greit mellom å bruke X på laptoppen med CTRL-ALT-F7 og på den stasjonære med CTRL-ALT-F8. :thumbup:
XDMCP er genialt.
Om ein f.eks har ein gamal Pentium 200 MHz ståande, og ein rask P4, så kan den gamle PCen logge seg på den nye med XDMCP, og då merkar ein ikkje at det er ein gamal PC meir, for å sei det slik.
Er den nye kratig nok, kan fint fleire personar bruke den.
Dersom ein køyrer GDM (og ikkje KDM, der ein må redigere konfigurasjonsfila), så kan ein skru på XDMCP med det grafiske verktøyet ("gdmsetup", Login screen setup i menyen)
Endret av objorkum
Dette høres lovende ut, husker jeg prøvde xdmcp en gang, men jeg hadde ikke mer enn éi maskin som kjørte linux. Hvordan får jeg det slik at jeg kan «logge inn» på den andre maskina dersom jeg trykker ctrl + f9 da (ctrl + f8 er opptatt, viser informasjon om siste boot ) da?
Hvor kjapt er forresten dette? Vil det gå fint å spille på over xdmcp dersom vertsmaskina er kraftignok?
(ubuntu breezy, 54MB/s nettverk, bruker gdm)
Endret av dabear
Hvordan det er å spille, hvordan video og opengl akselerasjon fungerer, det vet jeg ikke. Kan tenke meg det blir en viss reduksjon i hastighet. Har ikke prøvd. Men som arbeidsmaskin fungerer det fint. Jeg har et relativt dårlig fungerende trådløst nettverk, så det er ikke så mye vits i å teste her.
Om man kan starte en sesjon på en annen maskin automatisk, eller via GUI, vet jeg heller ikke. Jeg gikk ut i tekstmodus (ctrl+alt+f1), logget på som bruker og skrev:
X -ac -query ipadresse :1
Du kan også bytte ut '-query ipadresse' med '-broadcast'. Det siste vil søke på lokalnettet etter maskiner som er villige til å være server, og automatisk velge en av dem.
5028900[/snapback]
Nei, gløym spel. OpenGL og slikt vert ikkje rendra på maskina som køyrer XDMCP, men på maskina du sit på. F.eks, om du skriv "glxinfo" når du sit på klienten, men brukar verten sin terminal, så vil du få opp informasjon for klienten sin X-server.
Klienten brukar tross alt sin eigen xorg.conf.
Endret av objorkum
