Den frie kafeen
iperf er et fint program. Trenger to maskiner du kan teste mellom.
Har du noen kommando-forslag? :p
b-real@ubuntu:~$ iperf -c 10.0.0.116 -p 1 -i 1 -p 5001 -f -m -t 100
[Client connecting to 10.0.0.116, TCP port 5001
TCP window size: 131 Kbit (default)
[ 3] local 10.0.0.58 port 45013 connected with 10.0.0.116 port 5001
[[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 1.0 sec 7.34 Mbits 7.34 Mbits/sec
[ 3] 1.0- 2.0 sec 14.7 Mbits 14.7 Mbits/sec
[ 3] 2.0- 3.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 3.0- 4.0 sec 23.1 Mbits 23.1 Mbits/sec
[ 3] 4.0- 5.0 sec 26.2 Mbits 26.2 Mbits/sec
[ 3] 5.0- 6.0 sec 25.2 Mbits 25.2 Mbits/sec
[ 3] 6.0- 7.0 sec 30.4 Mbits 30.4 Mbits/sec
[ 3] 7.0- 8.0 sec 29.4 Mbits 29.4 Mbits/sec
[ 3] 8.0- 9.0 sec 30.4 Mbits 30.4 Mbits/sec
[ 3] 9.0-10.0 sec 29.4 Mbits 29.4 Mbits/sec
[ 3] 10.0-11.0 sec 30.4 Mbits 30.4 Mbits/sec
[ 3] 11.0-12.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 12.0-13.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 13.0-14.0 sec 30.4 Mbits 30.4 Mbits/sec
[ 3] 14.0-15.0 sec 39.8 Mbits 39.8 Mbits/sec
[ 3] 15.0-16.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 16.0-17.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 17.0-18.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 18.0-19.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 19.0-20.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 20.0-21.0 sec 39.8 Mbits 39.8 Mbits/sec
[ 3] 21.0-22.0 sec 26.2 Mbits 26.2 Mbits/sec
[ 3] 22.0-23.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 23.0-24.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 24.0-25.0 sec 28.3 Mbits 28.3 Mbits/sec
[ 3] 25.0-26.0 sec 48.2 Mbits 48.2 Mbits/sec
[ 3] 26.0-27.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 27.0-28.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 28.0-29.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 29.0-30.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 30.0-31.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 31.0-32.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 32.0-33.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 33.0-34.0 sec 39.8 Mbits 39.8 Mbits/sec
[ 3] 34.0-35.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 35.0-36.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 36.0-37.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 37.0-38.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 38.0-39.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 39.0-40.0 sec 33.6 Mbits 33.6 Mbits/sec
[ 3] 40.0-41.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 41.0-42.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 42.0-43.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 43.0-44.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 44.0-45.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 45.0-46.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 46.0-47.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 47.0-48.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 48.0-49.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 49.0-50.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 50.0-51.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 51.0-52.0 sec 23.1 Mbits 23.1 Mbits/sec
[ 3] 52.0-53.0 sec 28.3 Mbits 28.3 Mbits/sec
[ 3] 53.0-54.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 54.0-55.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 55.0-56.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 56.0-57.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 57.0-58.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 58.0-59.0 sec 40.9 Mbits 40.9 Mbits/sec
[ 3] 59.0-60.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 60.0-61.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 61.0-62.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 62.0-63.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 63.0-64.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 64.0-65.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 65.0-66.0 sec 35.7 Mbits 35.7 Mbits/sec
[ 3] 66.0-67.0 sec 39.8 Mbits 39.8 Mbits/sec
[ 3] 67.0-68.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 68.0-69.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 69.0-70.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 70.0-71.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 71.0-72.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 72.0-73.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 73.0-74.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 74.0-75.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 75.0-76.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 76.0-77.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 77.0-78.0 sec 37.7 Mbits 37.7 Mbits/sec
[ 3] 78.0-79.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 79.0-80.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 80.0-81.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 81.0-82.0 sec 33.6 Mbits 33.6 Mbits/sec
[ 3] 82.0-83.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 83.0-84.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 84.0-85.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 85.0-86.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 86.0-87.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 87.0-88.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 88.0-89.0 sec 33.6 Mbits 33.6 Mbits/sec
[ 3] 89.0-90.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 90.0-91.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 91.0-92.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 92.0-93.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 93.0-94.0 sec 25.2 Mbits 25.2 Mbits/sec
[ 3] 94.0-95.0 sec 31.5 Mbits 31.5 Mbits/sec
[ 3] 95.0-96.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 96.0-97.0 sec 32.5 Mbits 32.5 Mbits/sec
[ 3] 97.0-98.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 98.0-99.0 sec 24.1 Mbits 24.1 Mbits/sec
[ 3] 99.0-100.0 sec 15.7 Mbits 15.7 Mbits/sec
[ 3] 0.0-100.3 sec 3.03 Gbits 30.3 Mbits/sec
[code]
b-real@ubuntu:~$ netstat -s
[code]Ip:
263489 total packets received
3 with invalid addresses
0 forwarded
0 incoming packets discarded
263451 incoming packets delivered
711423 requests sent out
4 outgoing packets dropped
102 dropped because of missing route
Icmp:
17 ICMP messages received
0 input ICMP message failed.
ICMP input histogram:
destination unreachable: 17
14 ICMP messages sent
0 ICMP messages failed
ICMP output histogram:
destination unreachable: 14
IcmpMsg:
InType3: 17
OutType3: 14
Tcp:
691 active connections openings
3 passive connection openings
17 failed connection attempts
1 connections established
262406 segments received
660633 segments send out
878 segments retransmited
0 bad segments received.
93 resets sent
Udp:
1062 packets received
14 packets to unknown port received.
0 packet receive errors
49911 packets sent
SndbufErrors: 4
UdpLite:
TcpExt:
232 TCP sockets finished time wait in fast timer
451 delayed acks sent
1 delayed acks further delayed because of locked socket
Quick ack mode was activated 170 times
16749 packets directly queued to recvmsg prequeue.
49455 bytes directly in process context from backlog
24562404 bytes directly received in process context from prequeue
30468 packet headers predicted
17050 packets header predicted and directly queued to user
14875 acknowledgments not containing data payload received
192948 predicted acknowledgments
7 times recovered from packet loss by selective acknowledgements
13 congestion windows recovered without slow start after partial ack
2 timeouts after SACK recovery
1 timeouts in loss state
8 fast retransmits
163 retransmits in slow start
191 other TCP timeouts
2 SACK retransmits failed
1 times receiver scheduled too late for direct processing
56 DSACKs sent for old packets
117 DSACKs received
32 connections reset due to unexpected data
9 connections reset due to early user close
4 connections aborted due to timeout
TCPDSACKIgnoredOld: 3
TCPDSACKIgnoredNoUndo: 112
TCPSpuriousRTOs: 4
TCPSackShiftFallback: 5042
IpExt:
InMcastPkts: 46
OutMcastPkts: 34
InBcastPkts: 337
OutBcastPkts: 260
InOctets: 88797202
OutOctets: 1014680318
InMcastOctets: 8779
OutMcastOctets: 8265
InBcastOctets: 46127
OutBcastOctets: 35240
[code]
Nå har du jo fått gjort det du var ute etter - teste ytelsen?
Hvis du skal teste mellom to maskiner, en server (eksempelvis router) og en klient (eksempelvis din laptop) kjører du denne på server:
iperf -s -w 65536 -p 12345 -I 5
så kan du kjøre disse på klient:
iperf -c <server> -w 65536 -p 12345 -t 60
iperf -c <server> -w 65536 -p 12345 -t 60 -d
iperf -c <server> -w 65536 -p 12345 -t 60 -P 4
Du kan sikkert justere ned tiden til under 60 hvis du er utålmodig.
Med "make menuconfig" kan du enkelt konfigurere (drivere og funksjoner i) kernelen før kompilering. Du må ikke endre noe, bare sørg for at kernelen støtter maskinen din ;)
Merk at 3.0.1 er siste stabile versjon, 3.1 er fremdeles i RC.
Anbefaler kernelen som følger med distroen du bruker (hvis maskinvaren din er støttet såklart), fordelen med å bruke kernelen som følger med er at den er skikkelig testet og vil få sikkerhetsfikser*.
* Gjelder de fleste store distroer, men ikke alle.
Kei, jeg skal endelig sette opp stasjonærmaskina mi slik at jeg kan få tilgang til den fra laptopen og mobilen for å primært styre Spotify siden det er stasjonærmaskina som har den beste lyden i kåken. Filer og sånt fikser Ubuntu One, så det er null stress.
Hvilken løsning er den beste for dette? Jo mindre å tukle med, jo bedre.
Third party Spotify clients
despotify-simple
The despotify-simple client is a pure textmode client that’s built on top of the libdespotify-simple library.
Features:
Playlists (list tracks, play tracks, rename, set/unset collaboration)
Display information about a Spotify URI
Play an album
Searching for tracks/album/artists
Platforms: Linux, Mac OS X
Author: Björn Stenberg
URL: http://despotify.se/source-code/
Bah, jeg prøver bare å sette opp VNC nå for i kveld, så får vi se hvordan det går. Men faen: Jeg prøver å koble til maskinen fra android-slegga mi ved å dytte inn IP-adressa og portnummer (5900), men får bare VNC Connection Failed! No route to host. Jeg har prøvd å åpne port 5900 på maskina uten hell. Mistenker at det er routeren som trøbler det til for meg? :/ Har selvfølgelig ikke tilgang til den nå i kveld..
