Den frie kafeen
Selv bruker jeg nå 260.19.44, etter at 260.19.06 produserte følgende interessante resultat:
Ser ut som en feil i rasterizeren det der, men så gjenkjente ikke den driveren GTX 580 heller. 270.26, 270.29 og 270.30 hadde alle problemer med at Xorg fryser i noen sekunder.
Fra Slackware-current changelog:
Sun Mar 27 08:28:47 UTC 2011
There have been quite a few changes so we will have one more release
candidate: Slackware 13.37 RC 3.14159265358979323846264338327950288419716.
Very close now! But we'll likely hold out for 2.6.37.6.
Ser fram til en bit l33t pi3 :)
@rocknrolf77: Ikke noe av dette er feilmeldinger. Kan du poste komplett output av kommandoen "dmesg" rett etter boot?
dmesg :
Initializing cgroup subsys cpuset
Linux version 2.6.37-ARCH (tobias@T-POWA-LX) (gcc version 4.5.2 20110127 (prerelease) (GCC) ) #1 SMP PREEMPT Fri Mar 25 15:10:00 CET 2011
Command line: BOOT_IMAGE=/boot/vmlinuz26 root=/dev/disk/by-uuid/0370433e-7130-40eb-900c-313ba6a113ce ro resume=/dev/sda5
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 0000000000098400 (usable)
BIOS-e820: 0000000000098400 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 00000000cfd81000 (usable)
BIOS-e820: 00000000cfde0000 - 00000000cfde3000 (ACPI NVS)
BIOS-e820: 00000000cfde3000 - 00000000cfdf0000 (ACPI data)
BIOS-e820: 00000000cfdf0000 - 00000000cfe00000 (reserved)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
BIOS-e820: 0000000100000000 - 0000000130000000 (usable)
NX (Execute Disable) protection: active
DMI 2.4 present.
DMI: Gigabyte Technology Co., Ltd. GA-MA78G-DS3H/GA-MA78G-DS3H, BIOS F9d 05/13/2010
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
No AGP bridge found
last_pfn = 0x130000 max_arch_pfn = 0x400000000
MTRR default type: uncachable
MTRR fixed ranges enabled:
00000-9FFFF write-back
A0000-BFFFF uncachable
C0000-C7FFF write-protect
C8000-FFFFF uncachable
MTRR variable ranges enabled:
0 base 000000000000 mask FFFF80000000 write-back
1 base 000080000000 mask FFFFC0000000 write-back
2 base 0000C0000000 mask FFFFF0000000 write-back
3 base 0000CFE00000 mask FFFFFFE00000 uncachable
4 base 000100000000 mask FFFFE0000000 write-back
5 base 000120000000 mask FFFFF0000000 write-back
6 disabled
7 disabled
TOM2: 0000000130000000 aka 4864M
x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
e820 update range: 00000000cfe00000 - 0000000100000000 (usable) ==> (reserved)
last_pfn = 0xcfd81 max_arch_pfn = 0x400000000
found SMP MP-table at [ffff8800000f5800] f5800
initial memory mapped : 0 - 20000000
Using GB pages for direct mapping
init_memory_mapping: 0000000000000000-00000000cfd81000
0000000000 - 00c0000000 page 1G
00c0000000 - 00cfc00000 page 2M
00cfc00000 - 00cfd81000 page 4k
kernel direct mapping tables up to cfd81000 @ 1fffd000-20000000
init_memory_mapping: 0000000100000000-0000000130000000
0100000000 - 0130000000 page 2M
kernel direct mapping tables up to 130000000 @ cfd7f000-cfd81000
RAMDISK: 37e3a000 - 37ff0000
ACPI: RSDP 00000000000f7180 00014 (v00 GBT )
ACPI: RSDT 00000000cfde3000 00038 (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
ACPI: FACP 00000000cfde3040 00074 (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
ACPI: DSDT 00000000cfde30c0 06BBA (v01 GBT GBTUACPI 00001000 MSFT 03000000)
ACPI: FACS 00000000cfde0000 00040
ACPI: SSDT 00000000cfde9d40 00544 (v01 PTLTD POWERNOW 00000001 LTP 00000001)
ACPI: HPET 00000000cfdea2c0 00038 (v01 GBT GBTUACPI 42302E31 GBTU 00000098)
ACPI: MCFG 00000000cfdea300 0003C (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
ACPI: APIC 00000000cfde9c80 000BC (v01 GBT GBTUACPI 42302E31 GBTU 01010101)
ACPI: Local APIC address 0xfee00000
[ffffea0000000000-ffffea00043fffff] PMD -> [ffff8800c0000000-ffff8800c39fffff] on node 0
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
DMA32 0x00001000 -> 0x00100000
Normal 0x00100000 -> 0x00130000
Movable zone start PFN for each node
early_node_map[3] active PFN ranges
0: 0x00000010 -> 0x00000098
0: 0x00000100 -> 0x000cfd81
0: 0x00100000 -> 0x00130000
On node 0 totalpages: 1047817
DMA zone: 56 pages used for memmap
DMA zone: 6 pages reserved
DMA zone: 3914 pages, LIFO batch:0
DMA32 zone: 14280 pages used for memmap
DMA32 zone: 832953 pages, LIFO batch:31
Normal zone: 2688 pages used for memmap
Normal zone: 193920 pages, LIFO batch:31
ACPI: PM-Timer IO Port: 0x4008
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] enabled)
ACPI: LAPIC (acpi_id[0x04] lapic_id[0x04] disabled)
ACPI: LAPIC (acpi_id[0x05] lapic_id[0x05] disabled)
ACPI: LAPIC (acpi_id[0x06] lapic_id[0x06] disabled)
ACPI: LAPIC (acpi_id[0x07] lapic_id[0x07] disabled)
ACPI: LAPIC_NMI (acpi_id[0x00] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x04] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x05] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x06] dfl dfl lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x07] dfl dfl lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x10b9a201 base: 0xfed00000
SMP: Allowing 8 CPUs, 4 hotplug CPUs
nr_irqs_gsi: 40
PM: Registered nosave memory: 0000000000098000 - 0000000000099000
PM: Registered nosave memory: 0000000000099000 - 00000000000a0000
PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
PM: Registered nosave memory: 00000000cfd81000 - 00000000cfde0000
PM: Registered nosave memory: 00000000cfde0000 - 00000000cfde3000
PM: Registered nosave memory: 00000000cfde3000 - 00000000cfdf0000
PM: Registered nosave memory: 00000000cfdf0000 - 00000000cfe00000
PM: Registered nosave memory: 00000000cfe00000 - 00000000e0000000
PM: Registered nosave memory: 00000000e0000000 - 00000000f0000000
PM: Registered nosave memory: 00000000f0000000 - 00000000fec00000
PM: Registered nosave memory: 00000000fec00000 - 0000000100000000
Allocating PCI resources starting at cfe00000 (gap: cfe00000:10200000)
Booting paravirtualized kernel on bare hardware
setup_percpu: NR_CPUS:64 nr_cpumask_bits:64 nr_cpu_ids:8 nr_node_ids:1
PERCPU: Embedded 27 pages/cpu @ffff8800cfa00000 s81664 r8192 d20736 u262144
pcpu-alloc: s81664 r8192 d20736 u262144 alloc=1*2097152
pcpu-alloc: [0] 0 1 2 3 4 5 6 7
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1030787
Kernel command line: BOOT_IMAGE=/boot/vmlinuz26 root=/dev/disk/by-uuid/0370433e-7130-40eb-900c-313ba6a113ce ro resume=/dev/sda5
PID hash table entries: 4096 (order: 3, 32768 bytes)
Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
Checking aperture...
No AGP bridge found
Node 0: aperture @ c4000000 size 32 MB
Aperture pointing to e820 RAM. Ignoring.
Your BIOS doesn't leave a aperture memory hole
Please enable the IOMMU option in the BIOS setup
This costs you 64 MB of RAM
Mapping aperture over 65536 KB of RAM @ c4000000
PM: Registered nosave memory: 00000000c4000000 - 00000000c8000000
Memory: 3983244k/4980736k available (3753k kernel code, 789468k absent, 208024k reserved, 2000k data, 516k init)
SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Preemptable hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:2304
spurious 8259A interrupt: IRQ7.
Console: colour VGA+ 80x25
console [tty0] enabled
allocated 41943040 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
hpet clockevent registered
Fast TSC calibration using PIT
Detected 2612.220 MHz processor.
Calibrating delay loop (skipped), value calculated using timer frequency.. 5226.12 BogoMIPS (lpj=8707400)
pid_max: default: 32768 minimum: 301
Security Framework initialized
AppArmor: AppArmor disabled by boot time parameter
Mount-cache hash table entries: 256
Initializing cgroup subsys ns
ns_cgroup deprecated: consider using the 'clone_children' flag without the ns_cgroup.
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
Initializing cgroup subsys devices
Initializing cgroup subsys freezer
Initializing cgroup subsys net_cls
Initializing cgroup subsys blkio
tseg: 00cfe00000
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
mce: CPU supports 6 MCE banks
using C1E aware idle routine
Performance Events: AMD PMU driver.
... version: 0
... bit width: 48
... generic registers: 4
... value mask: 0000ffffffffffff
... max period: 00007fffffffffff
... fixed-purpose events: 0
... event mask: 000000000000000f
ACPI: Core revision 20101013
Setting APIC routing to flat
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
CPU0: AMD Phenom™ 9950 Quad-Core Processor stepping 03
System has AMD C1E enabled
Switch to broadcast mode on CPU0
NMI watchdog enabled, takes one hw-pmu counter.
Booting Node 0, Processors #1
Switch to broadcast mode on CPU1
#2
Switch to broadcast mode on CPU2
#3
Switch to broadcast mode on CPU3
Brought up 4 CPUs
Total of 4 processors activated (20904.65 BogoMIPS).
devtmpfs: initialized
NET: Registered protocol family 16
node 0 link 0: io port [c000, ffff]
TOM: 00000000d0000000 aka 3328M
Fam 10h mmconf [e0000000, e00fffff]
node 0 link 0: mmio [a0000, bffff]
node 0 link 0: mmio [d0000000, dfffffff]
node 0 link 0: mmio [f0000000, fe02ffff]
node 0 link 0: mmio [e0000000, e03fffff] ==> [e0100000, e03fffff]
bus: [00, 03] on node 0 link 0
bus: 00 index 0 [io 0x0000-0xffff]
bus: 00 index 1 [mem 0x000a0000-0x000bffff]
bus: 00 index 2 [mem 0xd0000000-0xdfffffff]
bus: 00 index 3 [mem 0xe0400000-0xffffffff]
bus: 00 index 4 [mem 0xe0100000-0xe03fffff]
bus: 00 index 5 [mem 0x130000000-0xfcffffffff]
ACPI: bus type pci registered
PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
PCI: Using configuration type 1 for base access
bio: create slab <bio-0> at 0
ACPI: EC: Look up EC in DSDT
ACPI: Interpreter enabled
ACPI: (supports S0 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
ACPI Exception: AE_NOT_FOUND, Evaluating _PRW (20101013/scan-723)
ACPI: No dock devices found.
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff]
pci_root PNP0A03:00: host bridge window [mem 0xfed40000-0xfed44fff]
pci_root PNP0A03:00: host bridge window [mem 0xcff00000-0xfebfffff]
pci 0000:00:00.0: [1022:9600] type 0 class 0x000600
pci 0000:00:00.0: reg 1c: [mem 0xe0000000-0xffffffff 64bit]
pci 0000:00:02.0: [1022:9603] type 1 class 0x000604
pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
pci 0000:00:02.0: PME# disabled
pci 0000:00:0a.0: [1022:9609] type 1 class 0x000604
pci 0000:00:0a.0: PME# supported from D0 D3hot D3cold
pci 0000:00:0a.0: PME# disabled
pci 0000:00:11.0: [1002:4391] type 0 class 0x000106
pci 0000:00:11.0: reg 10: [io 0xff00-0xff07]
pci 0000:00:11.0: reg 14: [io 0xfe00-0xfe03]
pci 0000:00:11.0: reg 18: [io 0xfd00-0xfd07]
pci 0000:00:11.0: reg 1c: [io 0xfc00-0xfc03]
pci 0000:00:11.0: reg 20: [io 0xfb00-0xfb0f]
pci 0000:00:11.0: reg 24: [mem 0xfe02f000-0xfe02f3ff]
pci 0000:00:12.0: [1002:4397] type 0 class 0x000c03
pci 0000:00:12.0: reg 10: [mem 0xfe02e000-0xfe02efff]
pci 0000:00:12.1: [1002:4398] type 0 class 0x000c03
pci 0000:00:12.1: reg 10: [mem 0xfe02d000-0xfe02dfff]
pci 0000:00:12.2: [1002:4396] type 0 class 0x000c03
pci 0000:00:12.2: reg 10: [mem 0xfe02c000-0xfe02c0ff]
pci 0000:00:12.2: supports D1 D2
pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
pci 0000:00:12.2: PME# disabled
pci 0000:00:13.0: [1002:4397] type 0 class 0x000c03
pci 0000:00:13.0: reg 10: [mem 0xfe02b000-0xfe02bfff]
pci 0000:00:13.1: [1002:4398] type 0 class 0x000c03
pci 0000:00:13.1: reg 10: [mem 0xfe02a000-0xfe02afff]
pci 0000:00:13.2: [1002:4396] type 0 class 0x000c03
pci 0000:00:13.2: reg 10: [mem 0xfe029000-0xfe0290ff]
pci 0000:00:13.2: supports D1 D2
pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
pci 0000:00:13.2: PME# disabled
pci 0000:00:14.0: [1002:4385] type 0 class 0x000c05
pci 0000:00:14.1: [1002:439c] type 0 class 0x000101
pci 0000:00:14.1: reg 10: [io 0x0000-0x0007]
pci 0000:00:14.1: reg 14: [io 0x0000-0x0003]
pci 0000:00:14.1: reg 18: [io 0x0000-0x0007]
pci 0000:00:14.1: reg 1c: [io 0x0000-0x0003]
pci 0000:00:14.1: reg 20: [io 0xfa00-0xfa0f]
pci 0000:00:14.2: [1002:4383] type 0 class 0x000403
pci 0000:00:14.2: reg 10: [mem 0xfe024000-0xfe027fff 64bit]
pci 0000:00:14.2: PME# supported from D0 D3hot D3cold
pci 0000:00:14.2: PME# disabled
pci 0000:00:14.3: [1002:439d] type 0 class 0x000601
pci 0000:00:14.4: [1002:4384] type 1 class 0x000604
pci 0000:00:14.5: [1002:4399] type 0 class 0x000c03
pci 0000:00:14.5: reg 10: [mem 0xfe028000-0xfe028fff]
pci 0000:00:18.0: [1022:1200] type 0 class 0x000600
pci 0000:00:18.1: [1022:1201] type 0 class 0x000600
pci 0000:00:18.2: [1022:1202] type 0 class 0x000600
pci 0000:00:18.3: [1022:1203] type 0 class 0x000600
pci 0000:00:18.4: [1022:1204] type 0 class 0x000600
pci 0000:01:00.0: [1002:9440] type 0 class 0x000300
pci 0000:01:00.0: reg 10: [mem 0xd0000000-0xdfffffff 64bit pref]
pci 0000:01:00.0: reg 18: [mem 0xfdfe0000-0xfdfeffff 64bit]
pci 0000:01:00.0: reg 20: [io 0xee00-0xeeff]
pci 0000:01:00.0: reg 30: [mem 0x00000000-0x0001ffff pref]
pci 0000:01:00.0: supports D1 D2
pci 0000:01:00.1: [1002:aa30] type 0 class 0x000403
pci 0000:01:00.1: reg 10: [mem 0xfdffc000-0xfdffffff 64bit]
pci 0000:01:00.1: supports D1 D2
pci 0000:00:02.0: PCI bridge to [bus 01-01]
pci 0000:00:02.0: bridge window [io 0xe000-0xefff]
pci 0000:00:02.0: bridge window [mem 0xfdf00000-0xfdffffff]
pci 0000:00:02.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
pci 0000:02:00.0: [10ec:8168] type 0 class 0x000200
pci 0000:02:00.0: reg 10: [io 0xde00-0xdeff]
pci 0000:02:00.0: reg 18: [mem 0xfdbff000-0xfdbfffff 64bit pref]
pci 0000:02:00.0: reg 20: [mem 0xfdbe0000-0xfdbeffff 64bit pref]
pci 0000:02:00.0: reg 30: [mem 0x00000000-0x0000ffff pref]
pci 0000:02:00.0: supports D1 D2
pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:02:00.0: PME# disabled
pci 0000:00:0a.0: PCI bridge to [bus 02-02]
pci 0000:00:0a.0: bridge window [io 0xd000-0xdfff]
pci 0000:00:0a.0: bridge window [mem 0xfde00000-0xfdefffff]
pci 0000:00:0a.0: bridge window [mem 0xfdb00000-0xfdbfffff 64bit pref]
pci 0000:03:07.0: [1095:0680] type 0 class 0x000180
pci 0000:03:07.0: reg 10: [io 0xcf00-0xcf07]
pci 0000:03:07.0: reg 14: [io 0xce00-0xce03]
pci 0000:03:07.0: reg 18: [io 0xcd00-0xcd07]
pci 0000:03:07.0: reg 1c: [io 0xcc00-0xcc03]
pci 0000:03:07.0: reg 20: [io 0xcb00-0xcb0f]
pci 0000:03:07.0: reg 24: [mem 0xfddff000-0xfddff0ff]
pci 0000:03:07.0: reg 30: [mem 0x00000000-0x0007ffff pref]
pci 0000:03:07.0: supports D1 D2
pci 0000:00:14.4: PCI bridge to [bus 03-03] (subtractive decode)
pci 0000:00:14.4: bridge window [io 0xc000-0xcfff]
pci 0000:00:14.4: bridge window [mem 0xfdd00000-0xfddfffff]
pci 0000:00:14.4: bridge window [mem 0xfdc00000-0xfdcfffff pref]
pci 0000:00:14.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
pci 0000:00:14.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
pci 0000:00:14.4: bridge window [mem 0x000c0000-0x000dffff] (subtractive decode)
pci 0000:00:14.4: bridge window [mem 0xfed40000-0xfed44fff] (subtractive decode)
pci 0000:00:14.4: bridge window [mem 0xcff00000-0xfebfffff] (subtractive decode)
pci_bus 0000:00: on NUMA node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P_._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCE2._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCEA._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 5 6 7 10 11) *0, disabled.
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 6 7 10 11) *0, disabled.
HEST: Table is not found!
vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
PCI: Using ACPI for IRQ routing
PCI: pci_cache_line_size set to 64 bytes
pci 0000:00:00.0: no compatible bridge window for [mem 0xe0000000-0xffffffff 64bit]
reserve RAM buffer: 0000000000098400 - 000000000009ffff
reserve RAM buffer: 00000000cfd81000 - 00000000cfffffff
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0
hpet0: 4 comparators, 32-bit 14.318180 MHz counter
Switching to clocksource tsc
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:00: [bus 00-ff]
pnp 00:00: [io 0x0cf8-0x0cff]
pnp 00:00: [io 0x0000-0x0cf7 window]
pnp 00:00: [io 0x0d00-0xffff window]
pnp 00:00: [mem 0x000a0000-0x000bffff window]
pnp 00:00: [mem 0x000c0000-0x000dffff window]
pnp 00:00: [mem 0xfed40000-0xfed44fff window]
pnp 00:00: [mem 0xcff00000-0xfebfffff window]
pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
pnp 00:01: [io 0x0010-0x001f]
pnp 00:01: [io 0x0022-0x003f]
pnp 00:01: [io 0x0044-0x004d]
pnp 00:01: [io 0x0050-0x005f]
pnp 00:01: [io 0x0062-0x0063]
pnp 00:01: [io 0x0065-0x006f]
pnp 00:01: [io 0x0074-0x007f]
pnp 00:01: [io 0x0091-0x0093]
pnp 00:01: [io 0x00a2-0x00bf]
pnp 00:01: [io 0x00e0-0x00ef]
pnp 00:01: [io 0x04d0-0x04d1]
pnp 00:01: [io 0x0220-0x0225]
pnp 00:01: [io 0x0290-0x0294]
pnp 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:02: [io 0x4100-0x411f]
pnp 00:02: [io 0x0228-0x022f]
pnp 00:02: [io 0x0238-0x023f]
pnp 00:02: [io 0x040b]
pnp 00:02: [io 0x04d6]
pnp 00:02: [io 0x0c00-0x0c01]
pnp 00:02: [io 0x0c14]
pnp 00:02: [io 0x0c50-0x0c52]
pnp 00:02: [io 0x0c6c-0x0c6d]
pnp 00:02: [io 0x0c6f]
pnp 00:02: [io 0x0cd0-0x0cd1]
pnp 00:02: [io 0x0cd2-0x0cd3]
pnp 00:02: [io 0x0cd4-0x0cdf]
pnp 00:02: [io 0x4000-0x40fe]
pnp 00:02: [io 0x4210-0x4217]
pnp 00:02: [io 0x0b00-0x0b0f]
pnp 00:02: [io 0x0b10-0x0b1f]
pnp 00:02: [io 0x0b20-0x0b3f]
pnp 00:02: [mem 0x00000000-0x00000fff window]
pnp 00:02: [mem 0xfee00400-0xfee00fff window]
pnp 00:02: disabling [mem 0x00000000-0x00000fff window] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:02: disabling [mem 0x00000000-0x00000fff window disabled] because it overlaps 0000:01:00.0 BAR 6 [mem 0x00000000-0x0001ffff pref]
pnp 00:02: disabling [mem 0x00000000-0x00000fff window disabled] because it overlaps 0000:02:00.0 BAR 6 [mem 0x00000000-0x0000ffff pref]
pnp 00:02: disabling [mem 0x00000000-0x00000fff window disabled] because it overlaps 0000:03:07.0 BAR 6 [mem 0x00000000-0x0007ffff pref]
pnp 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:03: [dma 4]
pnp 00:03: [io 0x0000-0x000f]
pnp 00:03: [io 0x0080-0x0090]
pnp 00:03: [io 0x0094-0x009f]
pnp 00:03: [io 0x00c0-0x00df]
pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
pnp 00:04: [irq 0 disabled]
pnp 00:04: [irq 8]
pnp 00:04: [mem 0xfed00000-0xfed003ff]
pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
pnp 00:05: [io 0x0070-0x0073]
pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:06: [io 0x0061]
pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
pnp 00:07: [io 0x00f0-0x00ff]
pnp 00:07: [irq 13]
pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:08: [io 0x03f0-0x03f5]
pnp 00:08: [io 0x03f7]
pnp 00:08: [irq 6]
pnp 00:08: [dma 2]
pnp 00:08: Plug and Play ACPI device, IDs PNP0700 (active)
pnp 00:09: [io 0x03f8-0x03ff]
pnp 00:09: [irq 4]
pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:0a: [io 0x0378-0x037f]
pnp 00:0a: [irq 7]
pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
pnp 00:0b: [mem 0xe0000000-0xefffffff]
pnp 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:0c: [mem 0x000d4400-0x000d7fff]
pnp 00:0c: [mem 0x000f0000-0x000f7fff]
pnp 00:0c: [mem 0x000f8000-0x000fbfff]
pnp 00:0c: [mem 0x000fc000-0x000fffff]
pnp 00:0c: [mem 0xcfde0000-0xcfdeffff]
pnp 00:0c: [mem 0xffff0000-0xffffffff]
pnp 00:0c: [mem 0x00000000-0x0009ffff]
pnp 00:0c: [mem 0x00100000-0xcfddffff]
pnp 00:0c: [mem 0xcfdf0000-0xcfdfffff]
pnp 00:0c: [mem 0xcfe00000-0xcfefffff]
pnp 00:0c: [mem 0x00000000-0xffffffffffffffff disabled]
pnp 00:0c: [mem 0xfec00000-0xfec00fff]
pnp 00:0c: [mem 0xfee00000-0xfee00fff]
pnp 00:0c: [mem 0xfff80000-0xfffeffff]
pnp 00:0c: disabling [mem 0x000d4400-0x000d7fff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:0c: disabling [mem 0x000f0000-0x000f7fff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:0c: disabling [mem 0x000f8000-0x000fbfff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:0c: disabling [mem 0x000fc000-0x000fffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:0c: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:0c: disabling [mem 0x00100000-0xcfddffff] because it overlaps 0000:00:00.0 BAR 3 [mem 0x00000000-0x1fffffff 64bit]
pnp 00:0c: Plug and Play ACPI device, IDs PNP0c01 (active)
pnp: PnP ACPI: found 13 devices
ACPI: ACPI bus type pnp unregistered
system 00:01: [io 0x04d0-0x04d1] has been reserved
system 00:01: [io 0x0220-0x0225] has been reserved
system 00:01: [io 0x0290-0x0294] has been reserved
system 00:02: [io 0x4100-0x411f] has been reserved
system 00:02: [io 0x0228-0x022f] has been reserved
system 00:02: [io 0x0238-0x023f] has been reserved
system 00:02: [io 0x040b] has been reserved
system 00:02: [io 0x04d6] has been reserved
system 00:02: [io 0x0c00-0x0c01] has been reserved
system 00:02: [io 0x0c14] has been reserved
system 00:02: [io 0x0c50-0x0c52] has been reserved
system 00:02: [io 0x0c6c-0x0c6d] has been reserved
system 00:02: [io 0x0c6f] has been reserved
system 00:02: [io 0x0cd0-0x0cd1] has been reserved
system 00:02: [io 0x0cd2-0x0cd3] has been reserved
system 00:02: [io 0x0cd4-0x0cdf] has been reserved
system 00:02: [io 0x4000-0x40fe] has been reserved
system 00:02: [io 0x4210-0x4217] has been reserved
system 00:02: [io 0x0b00-0x0b0f] has been reserved
system 00:02: [io 0x0b10-0x0b1f] has been reserved
system 00:02: [io 0x0b20-0x0b3f] has been reserved
system 00:02: [mem 0xfee00400-0xfee00fff window] has been reserved
system 00:0b: [mem 0xe0000000-0xefffffff] has been reserved
system 00:0c: [mem 0xcfde0000-0xcfdeffff] could not be reserved
system 00:0c: [mem 0xffff0000-0xffffffff] has been reserved
system 00:0c: [mem 0xcfdf0000-0xcfdfffff] has been reserved
system 00:0c: [mem 0xcfe00000-0xcfefffff] could not be reserved
system 00:0c: [mem 0xfec00000-0xfec00fff] could not be reserved
system 00:0c: [mem 0xfee00000-0xfee00fff] could not be reserved
system 00:0c: [mem 0xfff80000-0xfffeffff] has been reserved
pci 0000:01:00.0: BAR 6: assigned [mem 0xfdf00000-0xfdf1ffff pref]
pci 0000:02:00.0: BAR 6: assigned [mem 0xfdb00000-0xfdb0ffff pref]
pci 0000:03:07.0: BAR 6: assigned [mem 0xfdc00000-0xfdc7ffff pref]
pci 0000:00:02.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
pci 0000:00:02.0: setting latency timer to 64
pci 0000:00:0a.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
pci 0000:00:0a.0: setting latency timer to 64
pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000dffff]
pci_bus 0000:00: resource 8 [mem 0xfed40000-0xfed44fff]
pci_bus 0000:00: resource 9 [mem 0xcff00000-0xfebfffff]
pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
pci_bus 0000:01: resource 1 [mem 0xfdf00000-0xfdffffff]
pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
pci_bus 0000:02: resource 1 [mem 0xfde00000-0xfdefffff]
pci_bus 0000:02: resource 2 [mem 0xfdb00000-0xfdbfffff 64bit pref]
pci_bus 0000:03: resource 0 [io 0xc000-0xcfff]
pci_bus 0000:03: resource 1 [mem 0xfdd00000-0xfddfffff]
pci_bus 0000:03: resource 2 [mem 0xfdc00000-0xfdcfffff pref]
pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
pci_bus 0000:03: resource 7 [mem 0x000c0000-0x000dffff]
pci_bus 0000:03: resource 8 [mem 0xfed40000-0xfed44fff]
pci_bus 0000:03: resource 9 [mem 0xcff00000-0xfebfffff]
NET: Registered protocol family 2
IP route cache hash table entries: 131072 (order: 8, 1048576 bytes)
TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
TCP: Hash tables configured (established 262144 bind 65536)
TCP reno registered
UDP hash table entries: 2048 (order: 4, 65536 bytes)
UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
pci 0000:01:00.0: Boot video device
PCI: CLS mismatch (64 != 4), using 64 bytes
Unpacking initramfs...
Freeing initrd memory: 1752k freed
PCI-DMA: Disabling AGP.
PCI-DMA: aperture base @ c4000000 size 65536 KB
PCI-DMA: using GART IOMMU.
PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
audit: initializing netlink socket (disabled)
type=2000 audit(1301172536.816:1): initialized
HugeTLB registered 2 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
msgmni has been set to 7912
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
ERST: Table is not found!
Linux agpgart interface v0.103
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
rtc_cmos 00:05: RTC can wake from S4
rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one month, 242 bytes nvram, hpet irqs
cpuidle: using governor ladder
cpuidle: using governor menu
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
PM: Checking hibernation image partition /dev/sda5
PM: Hibernation image not present or could not be loaded.
registered taskstats version 1
rtc_cmos 00:05: setting system clock to 2011-03-26 20:48:58 UTC (1301172538)
Initalizing network drop monitor service
Freeing unused kernel memory: 516k freed
udev[44]: starting version 166
SCSI subsystem initialized
libata version 3.00 loaded.
ahci 0000:00:11.0: version 3.0
ahci 0000:00:11.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
ahci 0000:00:11.0: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part ccc
scsi0 : ahci
scsi1 : ahci
scsi2 : ahci
scsi3 : ahci
ata1: SATA max UDMA/133 irq_stat 0x00400000, PHY RDY changed irq 22
ata2: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f180 irq 22
ata3: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f200 irq 22
ata4: SATA max UDMA/133 abar m1024@0xfe02f000 port 0xfe02f280 irq 22
pata_atiixp 0000:00:14.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
scsi4 : pata_atiixp
scsi5 : pata_atiixp
ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xfa00 irq 14
ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xfa08 irq 15
pata_sil680 0000:03:07.0: version 0.4.9
pata_sil680 0000:03:07.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
sil680: 133MHz clock.
scsi6 : pata_sil680
scsi7 : pata_sil680
ata7: PATA max UDMA/133 cmd 0xcf00 ctl 0xce00 bmdma 0xcb00 irq 21
ata8: PATA max UDMA/133 cmd 0xcd00 ctl 0xcc00 bmdma 0xcb08 irq 21
ata6.00: ATAPI: PLDS DVD+/-RW DH-16A6S, YD12, max UDMA/100
ata6.00: configured for UDMA/100
ata3: SATA link down (SStatus 0 SControl 300)
ata2: SATA link down (SStatus 0 SControl 300)
ata4: softreset failed (device not ready)
ata4: applying SB600 PMP SRST workaround and retrying
ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata4.00: HPA detected: current 2930275055, native 2930277168
ata4.00: ATA-8: ST31500341AS, CC1G, max UDMA/133
ata4.00: 2930275055 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata4.00: configured for UDMA/133
ata1: softreset failed (device not ready)
ata1: applying SB600 PMP SRST workaround and retrying
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: HPA detected: current 781420655, native 781422768
ata1.00: ATA-7: SAMSUNG HD401LJ, ZZ100-15, max UDMA7
ata1.00: 781420655 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA SAMSUNG HD401LJ ZZ10 PQ: 0 ANSI: 5
scsi 3:0:0:0: Direct-Access ATA ST31500341AS CC1G PQ: 0 ANSI: 5
scsi 5:0:0:0: CD-ROM PLDS DVD+-RW DH-16A6S YD12 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 781420655 512-byte logical blocks: (400 GB/372 GiB)
sd 3:0:0:0: [sdb] 2930275055 512-byte logical blocks: (1.50 TB/1.36 TiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sd 3:0:0:0: [sdb] Write Protect is off
sd 3:0:0:0: [sdb] Mode Sense: 00 3a 00 00
sd 3:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdb: sdb1 sdb2 sdb3 < sdb5 sdb6 sdb7 >
sda: sda1 sda2 < sda5 sda6 > sda3 sda4
sd 3:0:0:0: [sdb] Attached SCSI disk
sd 0:0:0:0: [sda] Attached SCSI disk
sr0: scsi3-mmc drive: 62x/125x writer dvd-ram cd/rw xa/form2 cdda tray
cdrom: Uniform CD-ROM driver Revision: 3.20
sr 5:0:0:0: Attached scsi CD-ROM sr0
EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
Clocksource tsc unstable (delta = 7870809987 ns)
Switching to clocksource hpet
CE: hpet increased min_delta_ns to 20113 nsec
udev[606]: starting version 166
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
wmi: Mapper loaded
k10temp 0000:00:18.3: unreliable CPU thermal sensor; monitoring disabled
lp: driver loaded but no devices found
ACPI: acpi_idle registered with cpuidle
ACPI: processor limited to max C-state 1
input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0
ACPI: Power Button [PWRB]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
ACPI: Power Button [PWRF]
IT8718 SuperIO detected.
parport_pc 00:0a: reported by Plug and Play ACPI
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
ACPI: resource piix4_smbus [io 0x0b00-0x0b07] conflicts with ACPI region SOR1 [io 0x0b00-0x0b0f 64bit]
ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
ppdev: user-space parallel port driver
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 3:0:0:0: Attached scsi generic sg1 type 0
sr 5:0:0:0: Attached scsi generic sg2 type 5
lp0: using parport0 (interrupt-driven).
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
shpchp 0000:00:02.0: HPC vendor_id 1022 device_id 9603 ss_vid 1022 ss_did 9600
shpchp 0000:00:02.0: Cannot reserve MMIO region
shpchp 0000:00:0a.0: HPC vendor_id 1022 device_id 9609 ss_vid 1022 ss_did 9600
shpchp 0000:00:0a.0: Cannot reserve MMIO region
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
ehci_hcd 0000:00:12.2: EHCI Host Controller
ehci_hcd 0000:00:12.2: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:12.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
ehci_hcd 0000:00:12.2: applying AMD SB600/SB700 USB freeze workaround
ehci_hcd 0000:00:12.2: debug port 1
ehci_hcd 0000:00:12.2: irq 17, io mem 0xfe02c000
MCE: In-kernel MCE decoding enabled.
EDAC MC: Ver: 2.1.0 Mar 25 2011
EDAC amd64_edac: Ver: 3.3.0 Mar 25 2011
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ehci_hcd 0000:00:12.2: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 6 ports detected
ehci_hcd 0000:00:13.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
ehci_hcd 0000:00:13.2: EHCI Host Controller
ehci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 2
ehci_hcd 0000:00:13.2: applying AMD SB700/SB800/Hudson-2/3 EHCI dummy qh workaround
ehci_hcd 0000:00:13.2: applying AMD SB600/SB700 USB freeze workaround
ehci_hcd 0000:00:13.2: debug port 1
ehci_hcd 0000:00:13.2: irq 19, io mem 0xfe029000
ehci_hcd 0000:00:13.2: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 6 ports detected
EDAC amd64: This node reports that Memory ECC is currently disabled, set F3x44[22] (0000:00:18.3).
EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
(Note that use of the override may cause unknown side effects.)
amd64_edac: probe of 0000:00:18.2 failed with error -22
ohci_hcd 0000:00:12.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
ohci_hcd 0000:00:12.0: OHCI Host Controller
ohci_hcd 0000:00:12.0: new USB bus registered, assigned bus number 3
ohci_hcd 0000:00:12.0: irq 16, io mem 0xfe02e000
usbcore: registered new interface driver snd-usb-audio
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 3 ports detected
ohci_hcd 0000:00:12.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
ohci_hcd 0000:00:12.1: OHCI Host Controller
ohci_hcd 0000:00:12.1: new USB bus registered, assigned bus number 4
ohci_hcd 0000:00:12.1: irq 16, io mem 0xfe02d000
[drm] Initialized drm 1.1.0 20060810
[drm] radeon defaulting to kernel modesetting.
[drm] radeon kernel modesetting enabled.
radeon 0000:01:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
radeon 0000:01:00.0: setting latency timer to 64
[drm] initializing kernel modesetting (RV770 0x1002:0x9440).
[drm] register mmio base: 0xFDFE0000
[drm] register mmio size: 65536
ATOM BIOS: RV770XT
radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
radeon 0000:01:00.0: GTT: 512M 0x0000000020000000 - 0x000000003FFFFFFF
[drm] Detected VRAM RAM=512M, BAR=256M
[drm] RAM width 256bits DDR
[TTM] Zone kernel: Available graphics memory: 2025732 kiB.
[TTM] Initializing pool allocator.
[drm] radeon: 512M of VRAM memory ready
[drm] radeon: 512M of GTT memory ready.
radeon 0000:01:00.0: irq 40 for MSI/MSI-X
radeon 0000:01:00.0: radeon: using MSI.
[drm] radeon: irq initialized.
[drm] GART: num cpu pages 131072, num gpu pages 131072
[drm] Loading RV770 Microcode
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 3 ports detected
ohci_hcd 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
ohci_hcd 0000:00:13.0: OHCI Host Controller
ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 5
ohci_hcd 0000:00:13.0: irq 18, io mem 0xfe02b000
r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
r8169 0000:02:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
r8169 0000:02:00.0: setting latency timer to 64
r8169 0000:02:00.0: irq 41 for MSI/MSI-X
r8169 0000:02:00.0: eth0: RTL8168c/8111c at 0xffffc90000038000, 00:1f:d0:56:67:d3, XID 1c4000c0 IRQ 41
hub 5-0:1.0: USB hub found
hub 5-0:1.0: 3 ports detected
ohci_hcd 0000:00:13.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
ohci_hcd 0000:00:13.1: OHCI Host Controller
ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 6
fuse init (API version 7.15)
ohci_hcd 0000:00:13.1: irq 18, io mem 0xfe02a000
loop: module loaded
usb 1-2: new high speed USB device using ehci_hcd and address 2
hub 6-0:1.0: USB hub found
hub 6-0:1.0: 3 ports detected
ohci_hcd 0000:00:14.5: PCI INT C -> GSI 18 (level, low) -> IRQ 18
ohci_hcd 0000:00:14.5: OHCI Host Controller
ohci_hcd 0000:00:14.5: new USB bus registered, assigned bus number 7
ohci_hcd 0000:00:14.5: irq 18, io mem 0xfe028000
hub 7-0:1.0: USB hub found
hub 7-0:1.0: 2 ports detected
HDA Intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
radeon 0000:01:00.0: WB enabled
hub 1-2:1.0: USB hub found
hub 1-2:1.0: 4 ports detected
[drm] ring test succeeded in 1 usecs
[drm] radeon: ib pool ready.
[drm] ib test succeeded in 0 usecs
[drm] Enabling audio support
failed to evaluate ATIF got AE_BAD_PARAMETER
[drm] Radeon Display Connectors
[drm] Connector 0:
[drm] DVI-I
[drm] HPD2
[drm] DDC: 0x7e60 0x7e60 0x7e64 0x7e64 0x7e68 0x7e68 0x7e6c 0x7e6c
[drm] Encoders:
[drm] DFP1: INTERNAL_UNIPHY
[drm] CRT2: INTERNAL_KLDSCP_DAC2
[drm] Connector 1:
[drm] DIN
[drm] Encoders:
[drm] TV1: INTERNAL_KLDSCP_DAC2
[drm] Connector 2:
[drm] DVI-I
[drm] HPD1
[drm] DDC: 0x7e20 0x7e20 0x7e24 0x7e24 0x7e28 0x7e28 0x7e2c 0x7e2c
[drm] Encoders:
[drm] CRT1: INTERNAL_KLDSCP_DAC1
[drm] DFP2: INTERNAL_KLDSCP_LVTMA
[drm] Internal thermal controller with fan control
[drm] radeon: power management initialized
[drm] fb mappable at 0xD0142000
[drm] vram apper at 0xD0000000
[drm] size 7258112
[drm] fb depth is 24
[drm] pitch is 6912
usb 4-1: new low speed USB device using ohci_hcd and address 2
usb 1-2.1: new low speed USB device using ehci_hcd and address 4
Console: switching to colour frame buffer device 160x64
usb 1-2.2: new high speed USB device using ehci_hcd and address 5
fb0: radeondrmfb frame buffer device
drm: registered panic notifier
[drm] Initialized radeon 2.7.0 20080528 for 0000:01:00.0 on minor 0
HDA Intel 0000:01:00.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
HDA Intel 0000:01:00.1: irq 42 for MSI/MSI-X
HDA Intel 0000:01:00.1: setting latency timer to 64
usb 1-2.3: new high speed USB device using ehci_hcd and address 6
input: Chicony Saitek Eclipse II Keyboard as /devices/pci0000:00/0000:00:12.1/usb4/4-1/4-1:1.0/input/input2
generic-usb 0003:06A3:8021.0001: input,hidraw0: USB HID v1.11 Keyboard [Chicony Saitek Eclipse II Keyboard] on usb-0000:00:12.1-1/input0
input: Chicony Saitek Eclipse II Keyboard as /devices/pci0000:00/0000:00:12.1/usb4/4-1/4-1:1.1/input/input3
generic-usb 0003:06A3:8021.0002: input,hiddev0,hidraw1: USB HID v1.11 Device [Chicony Saitek Eclipse II Keyboard] on usb-0000:00:12.1-1/input1
input: A4Tech PS/2+USB Mouse as /devices/pci0000:00/0000:00:12.2/usb1/1-2/1-2.1/1-2.1:1.0/input/input4
generic-usb 0003:09DA:000E.0003: input,hidraw2: USB HID v1.10 Mouse [A4Tech PS/2+USB Mouse] on usb-0000:00:12.2-2.1/input0
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
usb 1-2.2: selecting invalid altsetting 1
usb 1-2.3: selecting invalid altsetting 1
usbcore: registered new interface driver uas
Initializing USB Mass Storage driver...
scsi8 : usb-storage 1-2.2:1.0
scsi9 : usb-storage 1-2.3:1.0
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
scsi 8:0:0:0: Direct-Access WD Ext HDD 1021 2002 PQ: 0 ANSI: 4
sd 8:0:0:0: Attached scsi generic sg3 type 0
sd 8:0:0:0: [sdc] 2930272256 512-byte logical blocks: (1.50 TB/1.36 TiB)
sd 8:0:0:0: [sdc] Test WP failed, assume Write Enabled
sd 8:0:0:0: [sdc] Assuming drive cache: write through
scsi 9:0:0:0: Direct-Access RDP8 SD/microSD 1.00 PQ: 0 ANSI: 0
sd 9:0:0:0: Attached scsi generic sg4 type 0
sdc: sdc1
scsi 9:0:0:1: Direct-Access RDP8 MS/M2 1.00 PQ: 0 ANSI: 0
sd 9:0:0:1: Attached scsi generic sg5 type 0
sd 8:0:0:0: [sdc] Attached SCSI disk
sd 9:0:0:0: [sdd] Attached SCSI removable disk
scsi 9:0:0:2: Direct-Access RDP8 CF 1.00 PQ: 0 ANSI: 0
sd 9:0:0:2: Attached scsi generic sg6 type 0
sd 9:0:0:1: [sde] Attached SCSI removable disk
sd 9:0:0:2: [sdf] Attached SCSI removable disk
EXT4-fs (sda4): re-mounted. Opts: user_xattr
Adding 2144640k swap on /dev/sda5. Priority:-1 extents:1 across:2144640k
IPv6: Loaded, but administratively disabled, reboot required to enable
r8169 0000:02:00.0: eth0: link up
Edit : Sorry for at jeg poster saa lang post med kode, men jeg faar av en eller annen grunn ikke spoiler til aa funke. Si ifra hvis det funker hos andre, saa skal jeg fjerne kodedelen.
[/b][/size][/color]Initializing cgroup subsys cpuset
DMI 2.4 present.
No AGP bridge found
 6 disabled
 7 disabled
Zone PFN ranges:
nr_irqs_gsi: 40
No AGP bridge found
NR_IRQS:2304
tseg: 00cfe00000
... version:            	0
... bit width:          	48
CPU0: AMD Phenom(tm) 9950 Quad-Core Processor stepping 03
#2
#3
Brought up 4 CPUs
vgaarb: loaded
pnp: PnP ACPI init
pnp 00:03: [dma 4]
pnp 00:04: [irq 8]
pnp 00:07: [irq 13]
pnp 00:08: [irq 6]
pnp 00:08: [dma 2]
pnp 00:09: [irq 4]
pnp 00:0a: [irq 7]
TCP reno registered
scsi0 : ahci
scsi1 : ahci
scsi2 : ahci
scsi3 : ahci
scsi4 : pata_atiixp
scsi5 : pata_atiixp
scsi6 : pata_sil680
scsi7 : pata_sil680
wmi: Mapper loaded
ATOM BIOS: RV770XT
loop: module loaded
[drm] Connector 0:
[drm]   DVI-I
[drm]   HPD2
[drm]   Encoders:
[drm] Connector 1:
[drm]   DIN
[drm]   Encoders:
[drm] Connector 2:
[drm]   DVI-I
[drm]   HPD1
[drm]   Encoders:
[drm] size 7258112
[drm]	pitch is 6912
sdc: sdc1
[color="#1C2837"][size="2"][b]
Kan du starte maskinen med minimalt tilkoblet perifert utstyr og ta en dmesg, dvs helst kun tastatur og display. Prøv også å disable alle funksjonene i BIOS du ikke bruker. Feks om du ikke bruker FireWire så kan du deaktivere dette. Samme gjelder for interne skjermkort, diskkontrollere, lydkort osv.
Ok, nå er det like før jeg klikker i vinkel.
Jeg prøver å få en tredjeparts spotifyplugin til squeezebox til å funke. Den krever at jeg har squeezeboxserver installert, og squeezeboxserver krever mysql 4.0, 5.0 eller 5.1. Jeg får installert alt, og følger instruksjonene for å installere pluginen. Jeg får opp pluginen på squeezeboxen, og jeg får koblet til kontoen min. Alt funker, tilsynelatende. Men når jeg prøver å spille musikk får jeg bare "connection timeout". Jeg fikk lokalisert problemet til mysql som ikke starter, uvisst av hvilken grunn. Etter mye rart og et forsøk på å fjerne alt som har med mysql å gjøre får jeg nå ikke lenger engang installert mysql. Jeg har purget, cleanet, tømt bensin og tent på alt som har med mysql å gjøre, men ikke f om jeg får installert mysql igjen. Derfor sitter jeg nå uten squeezeboxserver, uten spotifyplugin, bortsett fra den offisielle som ikke funker på min spiller.
HNNGH!
Jeg vurderer å kjøre en helt ren install igjen. Heldigvis ser det ikke ut til at mysql har sneket inn noen filer i hjemmemappa mi, så den blir ikke berørt, thank Buddha.
Anyways, hva må jeg gjøre for å få mysql til å starte under boot, samtidig med, eller når kallet av squeezeboxserver? Alle guider sier bare "installer mysql", men det funket åpenbart ikke..
Noen ideer?
Btw, Ubuntu 11.04, 64 bit.
Har hørt at filsystemene som brukes i forbindelse med Linux stort sett ikke har behov for defragmentering og at det er et vanlig n00b-spørsmål å spørre etter defrag-programvare :p Leste også et sted om hvordan ext-filsystemene plasserer filer på disken slik at defragmentering blir sjelden nødvendig.
Men, nå har jeg en 712 GB stor partisjon (ext4) som har vært helt full, bokstavlig talt, flere ganger. Så det jeg lurer på er hvordan jeg kan få sjekket om det er behov for defragmentering og hvordan man i så fall gjør det.
Foreløpig har jeg funnet ut at fsck.ext4 -E fragcheck /dev/sdb1 burde funke, men fsck har så mange options at jeg ikke blir klok på det.
Kjørte dette nå på laptopen:
fsck.ext4 -n -E fragcheck /dev/mapper/vg_macpenguin-homevol
for å gjøre en read-only (-n) sjekk.
Siste linje av output :
/dev/mapper/vg_macpenguin-homevol: 58319/2564096 files (2.7% non-contiguous), 8089973/10240000 blocks
"2.7% non-contiguous" burde være nøyaktig det samme som 2.7% fragmenterte filer, hvis mine engelskkunnskaper er til å stole på.
Denne linja dukker dog opp uansett om "-E fragcheck" er spesifisert eller ei.
Kan problemet ligge i 11.04? Noen grunn til at du bruker den? Funker det i, say, 10.04?
Det kan jo hende, men slikt skal jo egentlig være distrouavhengig.. Jeg lurer mer på om det kan være 64-bit som gjør det. Squeezeboxserver er vel kun 32-bit, men med ia32-libs skal det ikke være noe problem egentlig.
Jeg har ikke prøvd med eldre distroer siden jeg allerede har oppgradert det jeg har til 11.04. Jeg liker å ligge på den blødende kanten :p
Det som er spennende er at Ubuntu Software Center ikke godtar squeezeboxserver-pakka, sier den er "bad package", men når jeg bruker dpkg -i får jeg ingen feilmeldinger..
