Den frie kafeen
Er det noen flere som har opplevd problemer med Buypass? Har ikke brukt det siden April, og nå får jeg bare beskjed om at den ikke får kontakt med kortet, selv om pcsc_scan finner det uten problemer. Det virker også som java-applikasjonen ikke egentlig prøver å få kontakt med kortet, den feiler litt for fort.
Docky og gnome-do kuker med meg:
root@brealorg:/home/b-real# docky
ERROR:mini-codegen.c:1073:mono_local_regalloc: assertion failed: (ins->dreg != -1)
Stacktrace:
Native stacktrace:
mono() [0x80ca6e4]
[0xf9e410]
/lib/tls/i686/cmov/libc.so.6(abort+0x182) [0x72ca82]
/lib/libglib-2.0.so.0(g_assertion_message+0x163) [0x237df3]
/lib/libglib-2.0.so.0(+0x6344d) [0x23844d]
mono() [0x80d18fb]
mono() [0x805e421]
mono() [0x806215b]
mono() [0x8062e68]
mono() [0x80636ed]
mono() [0x815bdfa]
mono() [0x815e092]
mono(mono_runtime_init+0x169) [0x815f149]
mono() [0x805d1cc]
mono(mono_main+0x286) [0x80b1ee6]
mono() [0x805ad25]
/lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6) [0x715bd6]
mono() [0x805ac61]
Debug info from gdb:
[Thread debugging using libthread_db enabled]
[New Thread 0x919b70 (LWP 16721)]
0x00f9e422 in __kernel_vsyscall ()
 2 Thread 0x919b70 (LWP 16721)  0x00f9e422 in __kernel_vsyscall ()
* 1 Thread 0xbde6f0 (LWP 16689)  0x00f9e422 in __kernel_vsyscall ()
Thread 2 (Thread 0x919b70 (LWP 16721)):
#0  0x00f9e422 in __kernel_vsyscall ()
#1  0x00c2b736 in nanosleep () from /lib/tls/i686/cmov/libpthread.so.0
#2  0x081a6af8 in ?? ()
#3  0x00c2396e in start_thread () from /lib/tls/i686/cmov/libpthread.so.0
#4  0x007cca4e in clone () from /lib/tls/i686/cmov/libc.so.6
Thread 1 (Thread 0xbde6f0 (LWP 16689)):
#1  0x00c2af5b in read () from /lib/tls/i686/cmov/libpthread.so.0
#2  0x080ca87e in ?? ()
#3  <signal handler called>
#4  0x00f9e422 in __kernel_vsyscall ()
#5  0x00729651 in raise () from /lib/tls/i686/cmov/libc.so.6
#6  0x0072ca82 in abort () from /lib/tls/i686/cmov/libc.so.6
#7  0x00237df3 in g_assertion_message () from /lib/libglib-2.0.so.0
#8  0x0023844d in g_assertion_message_expr () from /lib/libglib-2.0.so.0
#9  0x080d18fb in ?? ()
#10 0x0805e421 in ?? ()
#11 0x0806215b in ?? ()
#12 0x08062e68 in ?? ()
#13 0x080636ed in ?? ()
#14 0x0815bdfa in ?? ()
#15 0x0815e092 in ?? ()
#16 0x0815f149 in mono_runtime_init ()
#17 0x0805d1cc in ?? ()
#18 0x080b1ee6 in mono_main ()
#19 0x0805ad25 in ?? ()
#20 0x00715bd6 in __libc_start_main () from /lib/tls/i686/cmov/libc.so.6
#21 0x0805ac61 in ?? ()
Got a SIGABRT while executing native code. This usually indicates
a fatal error in the mono runtime or one of the native libraries
used by your application.
Aborted
Noen tanker om why?
Etter i dag og i går er jeg blitt fullstendig overbevist om at laptopen er blitt infiltret av gnomer eller andre små sagnsomsuste vesener. Har aldri vært på plaget med linux før. Enten er det skjermkortdriveren som plutselig finner det for godt å rett å slett dø for å aldri stå opp igjen. Eller er det programer som ikke starter, starter bare for å dø et sekund senere osv. Tror rett og slett at jeg skal krype til korset og formatere / og /home. For å bruke mere tid på dette gidder jeg ikke.
ah, deilig å få det litt av systemet, fatter bare ikke hva som er greia. Ikke engang opera klarer å fungere som det skal.
Jeg har hatt litt av det samme de siste dagene. Først funker ikke smartkortet, trådløsdriveren køddet seg til konstant, og så ble / nesten full da jeg kompilerte xbmc fra svn, så det kan se ut som om jeg trenger en reformat uansett.
Gjest Slettet+oiasdf79
Har hatt en del slike finurlige problemer i Ubuntu i det siste selv også. Aner ikke hvorfor. Men, hver gang resulterer det i Busybox, til og med etter at jeg byttet til en splitter ny Corsair 60GB SSD, så det var ikke disken som hadde skylden. Merkelig oppførsel!
Ubuntu, mint og opensuse. Opensuse er den eneste liveCDen som i det hele tatt ville starte, men hadde store problemer med å får ferdig installasjonen. Etter hjelp på opensuse forumet kom jeg meg endelig inn og fikk installert driveren for skjermkortet. Etter det kan jeg kun kjøre med tekst og får error om jeg prøver å starte GUI. Kjenner jeg er litt lei nå :p
