Den frie kafeen
Gjest medlem-83883
Et hint som kanskje kan sparke deg enda litt videre i riktig retning:
[thor@thinkpad pm]$ modprobe modprobe
FATAL: Module modprobe not found.
Hvordan ser din rc.conf ut?
Er det forresten en raskere metode å kopiere innhold fra nano og legge det feks ut her.
(Brukte open office her.)
rc.conf:
# /etc/rc.conf - Main Configuration for Arch Linux
# LOCALIZATION
# LOCALE: available languages can be listed with the 'locale -a' command
# HARDWARECLOCK: set to "UTC" or "localtime", any other value will result
#   in the hardware clock being left untouched (useful for virtualization)
# TIMEZONE: timezones are found in /usr/share/zoneinfo
# KEYMAP: keymaps are found in /usr/share/kbd/keymaps
# CONSOLEFONT: found in /usr/share/kbd/consolefonts (only needed for non-US)
# CONSOLEMAP: found in /usr/share/kbd/consoletrans
# USECOLOR: use ANSI color sequences in startup messages
LOCALE="en_US.UTF-8"
HARDWARECLOCK="localtime"
TIMEZONE="Europe/Oslo"
KEYMAP="no"
CONSOLEFONT=
CONSOLEMAP=
USECOLOR="yes"
# HARDWARE
# MOD_AUTOLOAD: Allow autoloading of modules at boot and when needed
# MOD_BLACKLIST: Prevent udev from loading these modules
# MODULES: Modules to load at boot-up. Prefix with a ! to blacklist.
# NOTE: Use of 'MOD_BLACKLIST' is deprecated. Please use ! in the MODULES array.
MOD_AUTOLOAD="yes"
#MOD_BLACKLIST=() #deprecated
MODULES=(modprobe acpi-cpufreq cpufreq_ondemand cpufreq_powersave)
# Scan for LVM volume groups at startup, required if you use LVM
USELVM="no"
# NETWORKING
# HOSTNAME: Hostname of machine. Should also be put in /etc/hosts
HOSTNAME="archeee"
# Use 'ifconfig -a' or 'ls /sys/class/net/' to see all available interfaces.
# Interfaces to start at boot-up (in this order)
# Declare each interface then list in INTERFACES
#   - prefix an entry in INTERFACES with a ! to disable it
#   - no hyphens in your interface names - Bash doesn't like it
# DHCP:     Set your interface to "dhcp" (eth0="dhcp")
# Wireless: See network profiles below
#Static IP example
#eth0="eth0 192.168.0.2 netmask 255.255.255.0 broadcast 192.168.0.255"
eth0="dhcp"
wlan0="dhcp"
INTERFACES=(eth0 wlan0)
# Routes to start at boot-up (in this order)
# Declare each route then list in ROUTES
#   - prefix an entry in ROUTES with a ! to disable it
gateway="default gw 192.168.0.1"
ROUTES=(!gateway)
# Enable these network profiles at boot-up.  These are only useful
# if you happen to need multiple network configurations (ie, laptop users)
#   - set to 'menu' to present a menu during boot-up (dialog package required)
#   - prefix an entry with a ! to disable it
# Network profiles are found in /etc/network.d
# This now requires the netcfg package
NETWORKS=(mynetwork mynetwork2)
# DAEMONS
# Daemons to start at boot-up (in this order)
#   - prefix a daemon with a ! to disable it
#   - prefix a daemon with a @ to start it up in the background
DAEMONS=(syslog-ng dbus hal @network @net-profiles netfs crond cpufreq)
Endret av karl-wilhelm
Da blir denne feilmeldingen borte, noe til å meg jeg antok, men hva hjelper dette, er vel fortsatt et eller annet som mangler?
Men det har kanskje ikke noe å si for min bruk, ville bare tro at dersom jeg prøver under noen tilfeller å legge til eller fjerne en modul fra kernel at den vil påpeke at jeg da mangler modprobe? =)
Modprobe er kommandoen man bruker for å laste inn moduler etter at kjernen har startet. F.eks. hvis du ikke starter blåtann ved oppstart fordi du sjelden bruker den, men trenger den innimellom. Den er nok der fordi du har lagt den til. :p
Gjest Slettet+oiasdf79
Open Suse er nok en OK plass å begynne, men dersom du regner med å trenge mye hjelp kan nok Ubuntu være bedre å satse på ettersom at de har svært mye nyttig hjelp i sine forum. :)
Vurderer å ta en full formatering av linuxpartisjonene mine, inkludert home. Rett og slett for å få vekk alt av gamle configfiler og annet tjafs som har havnet der under all eksperimenteringen som jeg har foretatt meg de siste årene. Og siden jeg skal fjerne alt, så tenkte jeg at jeg likså godt kunne ta å prøve meg på en ny distro hvis jeg finner noe som virker spennende. Per dags dato så kjører jeg ubuntu med gnome/openbox som vindubehandler. Jeg er fullstendig klar over at jeg ikke trenger gnome. Men jeg er plaget av at wicd nekter å koble seg til hjemmenettverket mitt. Så jeg har egentlig bare gitt litt faen og bare kjørt gnome/openbox.
Når det gjelder vindubehandlere, så kommer jeg uten tvil til å fortsette å bruke openbox. For at etter jeg testet det ut for første gang, så alt alt annet virket tregt og tungvindt. Så en evt ny distro kan gjerne komme med openbox som standard, ikke at det er så mye stress å sette det opp på nytt igjen men. Har tidligere testet ut crunchbang, men den sammarbeidet ikke spesielt godt med maskinen min av en eller annen grunn. Har mine misstanker om at det kan komme av gammel config filer. Om distroen er en rolling relase, eller om den f.eks kjører det samme systemet som ubuntu, er akkurat det samme for meg. Så hvis noen har noen gode tips til noe som kunne ha passet. Så tar jeg hjertelig imot tips og råd.
Om du vil ha en Debian basert distro som er rolling release er kanskje sidux noe å sjekke ut. Blant Debian baserte distroer er det den som er mest cutting-edge, hvis det er noe du skulle være interessert i. Den kommer standard med KDE eller XFCE, men det openbox kan lett installeres.
Gjest medlem-83883
Arch tror jeg passer veldig bra. Med en full formatering og en fresh start burde det fungere veldig bra hvis du ikke har utrolig sær maskinvare. Jeg gjorde nettopp en helt ny installering av Arch i forbindelse med bytte av disk (Seagate MomentusXT anbefales), og det var veldig godt å få ryddet opp i systemet etter lang tid med testing og eksperimentering.
Opererer de med samme kommando for installering av programmer som f.eks mint ?
sudo apt- get install
Tror ikke det, pakkebehandleren til openSUSE er YaST, bruker .rpm pakker i stedet for .deb (om det skulle være av betydning).
Sist jeg testet openSUSE (tror det var utgave 11.1) så falt ikke YaST helt i smak, p.g.a. min begrensede linux kompetanse. "Problemet" mitt var at når jeg installere ting og tang, og om noe gikk galt eller det ble noen konflikter så fikk jeg ganske mange valg (ca 5) om hva jeg ville gjøre. Sikkert veldig bra for de som kan nok, men det kunne ikke jeg, og det ble derfor for mange valg og ble dermed veldig usikker på hva som var "rett". Utover dette så fungerte openSUSE helt greit for meg.
Ubuntu har mye god dokumentasjon, men en del av dette er også overførbart til andre distroer. Ett alternativ kan være å teste noen forskjellige distribusjoner virtuelt, før man bestemmer seg.
Endret av Crowly
1+ for Arch.
Min evige distrohopping stoppet på Arch! Openbox :love:
