Den frie kafeen
sources.list:
# deb http://gb.archive.ubuntu.com/ubuntu/ jaunty main restricted
# deb http://gb.archive.ubuntu.com/ubuntu/ jaunty-updates main restricted
# deb http://security.ubuntu.com/ubuntu jaunty-security main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://gb.archive.ubuntu.com/ubuntu/ jaunty universe
deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty universe
deb http://gb.archive.ubuntu.com/ubuntu/ jaunty-updates universe
deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://gb.archive.ubuntu.com/ubuntu/ jaunty multiverse
deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty multiverse
deb http://gb.archive.ubuntu.com/ubuntu/ jaunty-updates multiverse
deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb http://gb.archive.ubuntu.com/ubuntu/ jaunty-backports main restricted universe multiverse
# deb-src http://gb.archive.ubuntu.com/ubuntu/ jaunty-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
# deb http://archive.canonical.com/ubuntu jaunty partner
# deb-src http://archive.canonical.com/ubuntu jaunty partner
deb-src http://security.ubuntu.com/ubuntu jaunty-security main restricted
deb http://security.ubuntu.com/ubuntu jaunty-security universe
deb-src http://security.ubuntu.com/ubuntu jaunty-security universe
deb http://security.ubuntu.com/ubuntu jaunty-security multiverse
deb-src http://security.ubuntu.com/ubuntu jaunty-security multiverse
deb http://ppa.launchpad.net/c-korn/vlc/ubuntu jaunty main
Er den nederste linja jeg la til for at VLC skulle oppdatere seg, fungerte fint i xubuntu og ubuntu. Såvidt jeg har fått med meg er Crunchbang basert på ubuntu 9.0.4.
Når jeg kjører update får jeg denne beskjeden nederst:
W: GPG error: http://ppa.launchpad.net jaunty Release: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D739676F7613768D
W: You may want to run apt-get update to correct these problems
Dette får jeg på show vlc:
eivind@laptop:~$ aptitude show vlc
Package: vlc
State: installed
Automatically installed: yes
Version: 1.0.2-1~ppa1
Priority: optional
Section: video
Maintainer: Ubuntu MOTU Developers <[email protected]>
Uncompressed Size: 3912k
Depends: vlc-nox (= 1.0.2-1~ppa1), libaa1 (>= 1.4p5), libc6 (>= 2.8),
libdbus-1-3 (>= 1.0.2), libfreetype6 (>= 2.2.1), libfribidi0 (>=
0.10.9), libgcc1 (>= 1:4.1.1), libgl1-mesa-glx | libgl1, libglib2.0-0
(>= 2.12.0), libgtk2.0-0 (>= 2.16.0), libnotify1 (>= 0.4.4),
libnotify1-gtk2.10, libqtcore4 (>= 4.5.1), libqtgui4 (>= 4.5.1),
libsdl-image1.2 (>= 1.2.5), libsdl1.2debian (>= 1.2.10-1), libstdc++6
(>= 4.2.1), libtar, libvlccore2 (>= 1.0.0~rc1), libx11-6, libx264-65
(>= 1:0.svn20081230), libxext6, libxinerama1, libxv1, libxxf86vm1,
zlib1g (>= 1:1.2.3.3.dfsg), ttf-dejavu-core
Suggests: mozilla-plugin-vlc, videolan-doc
Conflicts: vlc-nox (< 0.9.2-1)
Replaces: vlc-nox (< 0.9.2-1)
Provides: mp3-decoder
Description: multimedia player and streamer
VLC is the VideoLAN project's media player. It plays MPEG, MPEG2, MPEG4, DivX,
MOV, WMV, QuickTime, mp3, Ogg/Vorbis files, DVDs, VCDs, and multimedia streams
from various network sources.
VLC can also be used as a streaming server that duplicates the stream it reads
and multicasts them through the network to other clients, or serves them
through HTTP.
VLC has support for on-the-fly transcoding of audio and video formats, either
for broadcasting purposes or for movie format transformations. Support for most
output methods is provided by this package, but features can be added by
installing additional audio plugins (vlc-plugin-pulse, vlc-plugin-sdl) or video
plugins (vlc-plugin-sdl, vlc-plugin-ggi, vlc-plugin-svgalib). There is also a
web browser plugin in the mozilla-plugin-vlc package.
edit:
Etter at jeg tok safe upgrade ser det ut til at den oppdaterte seg. Nå er ihvertfall menyen og videoen i samme "bilde". Takk for hjelpen Del, du har redda meg bra et par ganger allerede :)
Endret av Nyhus
Jepsi pepsi:
Fetched 308B in 1s (273B/s)
Reading package lists... Done
eivind@laptop:~$
edit:
Skrev det inn en gang til og nå er beskjeden borte. Jeg bommet sikkert på et av tallene elns i sta. Takk igjen.
Endret av Nyhus
Du kan sjekke over nøklene med Synaptic (og eventuelt fjerne en hvis du har lagt inn noe feil). Bare start Synaptic, gå til Settings->Repositories->Authentication. Der finner du alle nøklene som sikrer at du laster ned fra riktig server.
"Fix graphic ****" i Recovery er i de fleste tilfeller ganske defekt etter min erfaring. Hva slags grafik har du?
Vis du har ati burde "aticonfig --initial" kjørt i kommandolinja i recovery fikse problemet.
Hvet ikke for Intel, eller Nvidea.
No har eg gjort det i "prompt" med og uten nettverk. Veit ikkje om det er det som er kommandolinja, men det fungerte i alle fall ikkje.
Iiiik!
Skrudde på laptopen i dag og merka at den automagisk hadde skifta tema på GDM. Jaja, tenkte eg og logge inn. Då poppa det plutseleg opp ei melding: HDD din er skada, ta backup og skift ut.
Hmm, rart. Kan dette være ein feil? Andre som har opplevd det? Årsaken skal visst nok være mange "bad sectors". Forslag til program som kan dobbeltsjekke dette eventuelt prøve å reparere det?
Iiiik!
Gdm temaet kommer med gnome 2.28, hele greia er helt annerledes enn tidligere, så folk må vel kanskje begynne å lage gdm themes på nytt. Det er den nye disk utility'en i gnome 2.28. Er det feil eller er det masse bad sectors som den sier? Opplever akkurat det samme.
