Jumpere på S-ATA disker?!
Det er som regel en jumper der ja. Men det er ikke en master/slave jumper.
Fra maxtor sine sider:
"Serial ATA interface disc drives are designed for easy installation. It is not necessary to set any jumpers, terminators, or other settings on this drive for proper operation. The jumper block adjacent to the SATA interface connector is for factory use only."
